#1 2024-01-23 15:43:23
cbraxton
Error installing chromium browser
Although Firefox works fine for most sites, occasionally there will be one that works better in Chrome/Chromium. I attempted to install the Chromium Browser through Synaptic in Devuan Daedalus but downloading of the packages failed. Do different repositories need to be enabled?
W: Failed to fetch http://repo.jing.rocks/debian-security/pool/updates/main/c/chromium/chromium-common_114.0.5735.198-1~deb12u1_amd64.deb
  404  Not Found [IP: 106.178.112.231 80]
W: Failed to fetch http://repo.jing.rocks/debian-security/pool/updates/main/c/chromium/chromium_114.0.5735.198-1~deb12u1_amd64.deb
W: Failed to fetch http://repo.jing.rocks/debian-security/pool/updates/main/c/chromium/chromium-sandbox_114.0.5735.198-1~deb12u1_amd64.deb
I have not changed anything in the default "/etc/apt/sources.list" file, which looks like this:
# Package repositories
deb http://deb.devuan.org/merged daedalus main non-free-firmware
deb http://deb.devuan.org/merged daedalus-updates main non-free-firmware
deb http://deb.devuan.org/merged daedalus-security main non-free-firmware
#deb http://deb.devuan.org/merged daedalus-proposed-updates main non-free-firmwa
re
#deb http://deb.devuan.org/merged daedalus-backports main non-free-firmware
# Source repositories
#deb-src http://deb.devuan.org/merged daedalus main non-free-firmware
#deb-src http://deb.devuan.org/merged daedalus-updates main non-free-firmware
#deb-src http://deb.devuan.org/merged daedalus-security main non-free-firmware
#deb-src http://deb.devuan.org/merged daedalus-backports main non-free-firmware
(There is nothing in "/etc/apt/sources.list.d/".)
#2 2024-01-23 16:07:35
Re: Error installing chromium browser
Looks like Synaptic wants to fetch version 114, while I get
# apt list chromium
Auflistung… Fertig
chromium/stable-security 120.0.6099.224-1~deb12u1 amd64
chromium/stable-security 120.0.6099.224-1~deb12u1 i386
# apt policy chromium
chromium:
  Installiert:           (keine)
  Installationskandidat: 120.0.6099.224-1~deb12u1
  Versionstabelle:
     120.0.6099.224-1~deb12u1 500
        500 http://deb.devuan.org/merged daedalus-security/main amd64 Packages
     119.0.6045.199-1~deb12u1 500
        500 http://deb.devuan.org/merged daedalus/main amd64 Packages
Maybe you just need to run an apt update on the root console before, or tell Synaptic to refresh the repos.
#3 2024-01-23 16:33:50
cbraxton
Ah, what I had to do was use the "--allow-release-info-change" option when updating the repositories due to changing from "testing" to "stable". Rookie mistake! After doing that chromium installed OK.
