#1 2023-12-17 17:32:42
uhmzilighase
[SOLVED] # CONFIG_SND_SOC_INTEL_AVS is not set
uname -a
Linux devuan 6.5.0-5-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.5.13-1 (2023-11-29) x86_64 GNU/Linux
Possible to build just those modules against that kernel or should I recompile the entire kernel?
#2 2023-12-19 23:48:48
uhmzilighase
Re: [SOLVED] # CONFIG_SND_SOC_INTEL_AVS is not set
Turns out Devuan does not modify the kernels in any way.  They're from Debian.
Solution: Install a liquorix kernel!
https://liquorix.net/
