Edit /etc/modprobe.d/iwlwifi.conf and change line
options iwlwifi enable_ini=N
to
options iwlwifi enable_ini=0
Thanks go to Janek, who posted fix to https://bugs.debian.org/cgi-bin/bugrepo … 1057260#76
Hello.
It is already fixed in kernel, version
6.1.67-1 (2023-12-12)
Just update your system
sudo apt update
sudo apt upgrade
and reboot.
