#1 2023-12-03 01:53:00
penguin
After upgrading to Daedalus pusleaudio stopped working.
The motherboard is ASUS Pro WS X570-ACE. Audio controller is Realtek S1220A
$ sudo aplay -L
[sudo] password for penguin:
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=NVidia_1,DEV=3
    HDA NVidia, HDMI 0
    Direct hardware device without any conversions
hw:CARD=NVidia_1,DEV=7
    HDA NVidia, HDMI 1
hw:CARD=NVidia_1,DEV=8
    HDA NVidia, HDMI 2
hw:CARD=NVidia_1,DEV=9
    HDA NVidia, HDMI 3
plughw:CARD=NVidia_1,DEV=3
    HDA NVidia, HDMI 0
    Hardware device with all software conversions
plughw:CARD=NVidia_1,DEV=7
    HDA NVidia, HDMI 1
plughw:CARD=NVidia_1,DEV=8
    HDA NVidia, HDMI 2
plughw:CARD=NVidia_1,DEV=9
    HDA NVidia, HDMI 3
hdmi:CARD=NVidia_1,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia_1,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia_1,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia_1,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
dmix:CARD=NVidia_1,DEV=3
    HDA NVidia, HDMI 0
    Direct sample mixing device
dmix:CARD=NVidia_1,DEV=7
    HDA NVidia, HDMI 1
dmix:CARD=NVidia_1,DEV=8
    HDA NVidia, HDMI 2
dmix:CARD=NVidia_1,DEV=9
    HDA NVidia, HDMI 3
usbstream:CARD=NVidia_1
    HDA NVidia
    USB Stream Output
hw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
hw:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
hw:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
plughw:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
plughw:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
plughw:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
dmix:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=7
    HDA NVidia, HDMI 1
dmix:CARD=NVidia,DEV=8
    HDA NVidia, HDMI 2
dmix:CARD=NVidia,DEV=9
    HDA NVidia, HDMI 3
    HDA NVidia
    USB Stream Output
hw:CARD=Generic,DEV=0
    HD-Audio Generic, ALC1220 Analog
hw:CARD=Generic,DEV=1
    HD-Audio Generic, ALC1220 Digital
plughw:CARD=Generic,DEV=0
plughw:CARD=Generic,DEV=1
default:CARD=Generic
    Default Audio Device
sysdefault:CARD=Generic
front:CARD=Generic,DEV=0
    Front output / input
surround21:CARD=Generic,DEV=0
    2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
    4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
    4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
    5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
    5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
    7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Generic,DEV=0
    IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Generic,DEV=0
dmix:CARD=Generic,DEV=1
usbstream:CARD=Generic
    HD-Audio Generic
    USB Stream Output
lspci shows
0b:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Pulseaudio can't see HD-Audio Generic, ALC1220 like ALSA. It assigns Starship/Matisse HD Audio Controller that does not play sound.
I use LXQt and the Volume Control Setting has ALSA and PulseAudio. I chose ALSA as Device to control,  hw:2 - Master on the dropdown list box.
#2 2023-12-03 18:32:30
andyp67
Re: After upgrading to Daedalus pusleaudio stopped working.
If I was using pulse audio I would use pavucontrol.
