Pages: 1
This is a tutorial to get up and running Wireguard VPN on Devuan using Docker.
First, Docker:
sudo apt install -y docker.io docker-compose
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp dockerNext, Composer:
cd /opt
nano docker-compose.ymlInside:
version: "2.1"
services:
wireguard:
container_name: wg-manager
image: perara/wg-manager
restart: always
# sysctls:
# net.ipv6.conf.all.disable_ipv6: 0 # Required for IPV6
cap_add:
- NET_ADMIN
ports:
- 51800-51900:51800-51900/udp
- 8888:8888
volumes:
- ./wg-manager:/config
environment:
HOST: 0.0.0.0
PORT: 8888
ADMIN_USERNAME: admin
ADMIN_PASSWORD: MyS3curEPa$sw0Rd*-+
WEB_CONCURRENCY: 1Save and close.
Run it:
docker-compose up -dOn the browser:
http://URL_of_your_Server:8888Remember:
ADMIN_PASSWORD: MyS3curEPa$sw0Rd*-+Enter web interface and generate as many profiles as you might need. Don't use IPv6 or enable it on compose, but in my experience, has some issues with connection. At least, on Linode.
Enabling it on KDE network manager over console:
nmcli connection import type wireguard file ./Downloads/wireguard_profile.confDone. Adjust and enjoy. Hope that helps. 😎👍
Pages: 1
