Pages: 1
Hello.
I have pepared a simple openrc script to run OpenWebRX. Here it is:
#!/sbin/openrc-run
OWRX_PATH="/home/openwebrx/openwebrx"
PATH=$PATH:/home/openwebrx/openwebrx/
name="OpenWebRX"
#procname=python3
command_user="openwebrx:openwebrx"
command="/usr/bin/python3 /home/openwebrx/openwebrx/openwebrx.py"
command_args=">> /home/openwebrx/log/owrx.log 2>&1"
#output_log="$OWRX_PATH/../log/owrx.std"
#error_log=$OWRX_PATH/../log/owrx.err
command_background=true
pidfile="/run/${RC_SVCNAME}.pid"
The problem is that openrc doesn't obey the
command_user
parameter and the proccess is ran by root.
Would you please give me a hint on how to solve this?
PS: By the way, the command_args seem not to be included also, when I check with
ps
Im not real sure if this will help but i run artixlinux openrc and openrc scripts are called using the below shebang. Does devuan openrc have that script in /usr/bin ?
#!/usr/bin/openrc-run
I confirm that openrc-run is located in /sbin
Pages: 1
