#1 2023-08-20 00:30:00
neilgunton
Unknown
Deluge no longer showing progress bars on individual torrent lines
Does anyone know if it's possible to configure Deluge so that it shows the graphic progress bar (behind the 80% etc), on the individual torrent lines? It used to do this under Stretch, and even on Debian Bookworm (which I was trying just recently before fleeing to Devuan) it did still show the graphical progress. I know Devuan is based directly off Debian, so I guess it should be possible here too?
I know there's a separate progress bar in the bottom status pane, for the currently selected torrent, and that does work. But I like the individual progress bars, so I can see "who's winning" etc.
Any tips? I have a feeling it's something to do with theme or colors or whatever, but I can't find anywhere to set it. Hopefully it's not related to something that was taken out due to systemd (don't see how, since there is the other progress bar which still works). I like the default overall theme on Daedalus. Oh, and this is on XFCE, if that matters.
Thanks.
