It gives this error. Otherwise driver works perfectly:
Starting NVIDIA Persistence Daemon
nvidia-persistenced failed to initialize. Check syslog for more details.
invoke-rc.d: initscript nvidia-persistenced, action "start" failed.
dpkg: nvidia-persistenced paketi işlenirken sorun yaşandı (--configure):
nvidia-persistenced paketi post-installation betiği kuruldu alt süreci 1 hatalı çıkış kodu ile sona erdi
Usually not.
$ sudo apt purge nvidia-persistencedIt took me a lot of time to come to that point.
Or, if you want to keep it:
$ sudo /etc/init.d/nvidia-persistenced stop
$ sudo apt install Then apt should be happy again.
Make it shitty!
Breaking is now a premium feature. Please insert your credit card.
https://www.youtube.com/watch?v=T4Upf_B9RLQ
