Pages: 1
Someone help me to make Wayland devuan work, because when I open some applications they don't start (it appears on the screen) for example Firefox doesn't open in Wayland but in xorg it opens because that It happens and how to solve this error in Devuan Linux
Remembering that I'm using gnome-shell Wayland I don't know if kde also has this error in Wayland
Second this , tried this recently on Daedalus with gnome on amd gpu.
And could not open Firefox, Chromium or LibreOffice nor xeyes
(no errors in shell, nor wayland logs anywhere to be found)
think this was any non native application that required Xwayland compatibility
(xwayland was installed)
I also need this, I am running gnome with nvidia 525 driver. I uncommented the WaylandEnable=true line. Also, I commented the lines at /lib/udev/rules.d/61-gdm.rules, which were these lines:
LABEL="gdm_prefer_xorg"
#RUN+="/usr/libexec/gdm-runtime-config set daemon PreferredDisplayServer xorg"
GOTO="gdm_end"
LABEL="gdm_disable_wayland"
#RUN+="/usr/libexec/gdm-runtime-config set daemon WaylandEnable false"
GOTO="gdm_end"
LABEL="gdm_end"
Wayland supposedly works(!) but when I click firefox, it seems to be loading but it won't open, and finally will shutdown later.
FWIW Firefox-esr works fine on Debian Sid On SwayWM and Wayfire.
Pax vobiscum,
Mark Rabideau - ManyRoads
i3wm, bspwm, dkwm, dwm, openbox on Sid/ ceres ~ Linux #449130
Pages: 1
