#1 2023-07-12 21:35:34
sappersap
Official proxy of Devuan package repos to I2P?
Because the project has a mirror of repositories to the Tor network, respectively with .onion addresses, I think it would be reasonable to make a similar proxy to the I2P network
Anticipating comments about "slow speed in I2P", I can say that this problem is relatively easy to solve using small add-ons like apt-fast based on aria2: I tested, and I can say that with a certain setting of parallel loading, you can squeeze out a speed of several hundred kilobytes per second or even megabytes per second, which is quite enough for a comfortable system update and software installation
What do you think?
