Pages: 1
personally i am using gruvbox theme from my neovim and works perfectly fine with newest version of neovim that debian / devuan stable provideos ..
how to install the stable version of neovim . (currenlty is v9.1)
cd /usr/local/bin/
sudo wget https://github.com/neovim/neovim/releases/download/stable/nvim-linux64.tar.gz
sudo tar zxfv nvim-linux64.tar.gz
sudo rm -rf nvim-linux64.tar.gz
sudo ln -sf /usr/local/bin/nvim-linux64/bin/nvim /usr/local/bin/and then you have the latest nvim .
if you want use nvim with editor and be the latest one .
simply .
sudo apt install -y neovim
sudo rm /usr/bin/nvim
sudo ln -sf /usr/local/bin/nvim-linux64/bin/nvim /usr/bin Last edited by jemadux (2023-07-08 18:30:51)
Dev1 Stable | openrc | MATE
Greetings from Greece
Pages: 1
