This is on a HP-8770w Elitebook laptop.
Running Ceres and isn't connecting eth0 to use the wired network.
The wifi does work, though I want the internal nic as its faster for large datasets.
The internal nic and network do indeed work, both run well in bootable Devan Live.
Thanks in advance with your help with this frustrating problem!
The OS:
$ cat /etc/devuan_version
daedalus/ceres
$ cat /etc/debian_version
12.0
$ uname -a
Linux beanz 6.1.0-9-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.27-1 (2023-05-08) x86_64 GNU/LinuxSome info on the nic and config files:
Using as "eth0" in Network Manager.
$ sudo cat /etc/NetworkManager/system-connections/eth0.nmconnection
[connection]
id=eth0
uuid=dc36b218-f0c6-4c3d-bd29-b47860b78a36
type=ethernet
autoconnect-priority=1
interface-name=eth0
[ethernet]
mac-address=XX:XX:XX:XX:XX:XX
[ipv4]
address1=192.168.1.16/24,192.168.1.1
dns=192.168.1.1;
method=manual
[ipv6]
addr-gen-mode=stable-privacy
method=auto
[proxy]lspci
lspci | grep -e "Ethernet\|Network"
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
25:00.0 Network controller: Intel Corporation Centrino Ultimate-N 6300 (rev 3e)dmesg
$ sudo dmesg | grep eth0
[ 3.523956] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) XX:XX:XX:XX:XX:XX
[ 3.523965] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 3.524011] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
[ 350.827143] e1000e 0000:00:19.0 eth0: NIC Link is Down
[ 610.947457] e1000e 0000:00:19.0 eth0: NIC Link is Downifconfig:
$ sudo ifconfig -a
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether XX:XX:XX:XX:XX:XX txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 17 memory 0xd9500000-d9520000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 12524 bytes 1113687 (1.0 MiB)
TX packets 12524 bytes 1113687 (1.0 MiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.109 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 XXXX:XXXX:XXXX:XXXX:XXXX prefixlen 64 scopeid 0x20<link>
RX packets 233843 bytes 298900929 (285.0 MiB)
TX packets 109268 bytes 17173799 (16.3 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0iplink
$ ip link show eth0
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ffethtool
$ sudo ethtool eth0
Settings for eth0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Auto-negotiation: on
Port: Twisted Pair
PHYAD: 2
Transceiver: internal
MDI-X: Unknown (auto)
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00000007 (7)
drv probe link
Link detected: noOffline
Turns out it was the cable was faulty!
cheers
