#1 2023-05-16 01:27:41
Standardpoodle
Thinkpad T14s gen 3 and display backlight (adjustment not working)
I installed Daedalus 20230508 into a fresh Thinkpad T14s gen 3, but no method that I've tried lets me adjust the display brightness.
Directory /sys/class/backlight is empty.
I think xrandr doesn't adjust the backlight at all.
With or without sudo, xbacklight has no effect.
Adjusting the brightness works in Ubuntu 22.04 liveCD. There is /sys/class/backlight/amdgpu_bl0 that is populated.
Installing firmware-amd-graphics 20230210-5 caused the login screen to remain black (with backlight on). The directory under /sys is populated though, and echo 128 > /sys/class/backlight/amdgpu_bl0/brightness works (also without sudo). Removing the firmware package restored the previous situation (I was able to use X again but not adjust the backlight).
#2 2023-05-28 00:14:16
Standardpoodle
Re: Thinkpad T14s gen 3 and display backlight (adjustment not working)
Seems like it suddenly started working. Will write again if there is still a problem.
#3 2023-06-05 22:56:14
bigcat
I vaguely recall configuration in xorg.conf might be needed.  See this for example:  https://unix.stackexchange.com/question … xbacklight
Apologies if this is not relevant.
