#1 2023-04-21 06:37:39
ami1200
[SOLVED] HP Color LaserJet CM1312 Multifunction Printer drivers
Hello,
How to install Devuan HP Color LaserJet CM1312 Multifunction Printer drivers ?
Printer and scanner.
Thanks if somebody can help me.
#2 2023-04-21 08:51:11
Ron
Re: [SOLVED] HP Color LaserJet CM1312 Multifunction Printer drivers
Do you have hplip and cups from the repositories installed?
Since you're new to the forums, let me ask, how much experience do you have with Linux?
#3 2023-04-21 12:11:24
ami1200
Yes i have.
About over 20 years ago i worked before systemd linux project.
Testing KDE,Gnome etc. desktop systems and booting them from floppydisk.
So,i forget many things with linux shell command.
I used linux mint 32 bit system,but suppose ending now.
Anyway,something i stil remeber linux systems but not very mutch,
#4 2023-04-21 12:15:56
ami1200
Printer works,but scanner not.
#5 2023-04-21 13:53:43
ami1200
Hello Ron,
I get to working both.Printer and scanner.
I forget how to do it.
Thank you.Problem solved.
