#1 2023-04-15 14:11:36
WodeShengli
[SOLVED] Devuan Chimaera,how to upgrade to Devuan Ceres(unstable)?
Using stable(old) software is too bad for me.
Is there a way to upgrade from the commandline in real system?
Just like debian,
go to change the mirror list and:
``` bash
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
#2 2023-04-15 15:12:55
WodeShengli
Re: [SOLVED] Devuan Chimaera,how to upgrade to Devuan Ceres(unstable)?
Oh,It is worked by
``` bash
sudo apt-get update
sudo apt-get full-upgrade
