#1 2023-03-23 11:11:51
SpongeBOB
[SOLVED] Installing certbot-nginx
Hi everyone,
I would to get/generate an SSL (TLS) certificate for a website.
I would like to use Let'sEncrypt and I found this guide that target Devuan smile -->
https://certbot.eff.org/instructions?ws … uanbeowulf
But when I try
sudo apt update
sudo apt install certbot certbot-nginx
I get
E: Unable to locate package certbot-nginx
I don't know if certbot-nginx is required as I will most probably go with the option:
just get a certificate from this guide
certbot.eff.org wrote:
Or, just get a certificate
If you're feeling more conservative and would like to make the changes to your nginx configuration by hand, run this command.
sudo certbot certonly --nginx
So is certbot-nginx required ? Did you already installed a Let's encrypt certificate on your Devuan ?
Thanks
#2 2023-03-23 13:00:37
SpongeBOB
Re: [SOLVED] Installing certbot-nginx
FYI,
I tried to install just the certbot package, but it seem to be required for the next step -->
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Could not choose appropriate plugin: The requested nginx plugin does not appear to be installed
#3 2023-03-23 15:06:39
SpongeBOB
