#1 2023-02-14 00:29:48
deepforest
Ceres, legacy nvidia 340.108 driver ruins running Qt software
On Ceres same situation that at Sid
https://unix.stackexchange.com/question … t-software
With nouveau all working good. But after installing legacy 340.108 nvidia driver for my gf9800 i have Segmentation Fault at launching all Qt GUI software. And opposite, Qt works again after uninstalling nvidia driver.
But very strange that if i run Qt soft via debugging tools such gdb or strace i have no errors.
gdb ./doomseeker
strace ./doomseeker
Same is with Qbittorrent
https://i.stack.imgur.com/ehbCm.png
and 2048-Qt
https://i.stack.imgur.com/OTV6q.png
Only two Qt application starting normally - CMake GUI and Audacious Qt theme
Segmentation fault
#include <QApplication>
int main(int argc, char **argv)
  QApplication app(argc, argv);
  return 0;
Who can fix this? Debian or Qt developers?
smile
pyzNi 3.14zDa! smile
#2 2023-02-17 18:22:32
F_Sauce
Re: Ceres, legacy nvidia 340.108 driver ruins running Qt software
Hello
Maybe worth a try perhaps: https://www.nvidia.com/Download/Find.aspx?lang=en-uk, downgrade driver version?
Olav
PS
What desktop environment are you on by the way?
I'm on Devuan with KDE
#3 2023-02-17 18:37:03
F_Sauce
According to this thread: https://forums.linuxmint.com/viewtopic. … 3&start=20 it might be the Kernel which has to be downgraded if you insist on getting that card working properly with NVIDIAs drivers (any), (I read through it very briefly so might have missed something).
#4 2023-02-18 12:28:20
F_Sauce
I had a look at the thread mentioned above, and it is now marked as solved. Couple of new threads which i didn't really read through, but if you're still at it it may be worthwhile.
Cheers,
Olav
#5 2023-02-20 23:09:29
deepforest
340.108 last legacy supported driver by linux for this GPU
thouse was my thread at mint forum and there problem was not with Qt
make bug report
https://bugs.debian.org/cgi-bin/bugrepo … ug=1031489
ps Olav,  anyway thank you for attention for my question
smile
