Hi!
I installed Devuan 4 by minimal-live Iso and has a LXDE environment.
Some programs continue in English.
In the installation in Generate additional locales I chose pt_BR UTF-8.
How to leave Devuan in Brazilian Portuguese?
Greetings!
Hello :-)
Have you tried
# dpkg-reconfigure localesWhich programs are you having problems with?
Hi!
Hello :-)
Have you tried
Thanks for the tip, I haven't tried this command yet.
Hello :-)
With PCManFM, Gparted, Gnome Disks, Synaptic.
I was able to configure Devuan in Brazilian Portuguese.
I did the following procedures:
If Local PT_BR.UTF-8 does not appear on the list, you will have to install.
# locale-gen pt_BR.UTF-8
Enter the dpkg-reconfigure to reconfigure packages after they are already installed.
Updates the default language.
# update-locale LANG=pt_BR.UTF-8
Consult the defined value in LANG.
# cat /etc/default/locale
LANG=pt_BR.utf8
I hope it helps other users.
