Pages: 1
installed gnome packages gives start up error
error output
sudo startx launch
xinit connecting to x server waiting for x server to shut down
internal details output
(EE) Failed to load /usr/lib/xorg/modules/imput/libinput_drv.so:libinput.so.10:cannot
open shared object file: no such file or directory failed to load module libinput (loader failed 0)
In recovery mode all gnome packages were removed. no access to graphical recovery mode.
unsuccesful at nmcli wifi connect in recovery mode, no apt update, upgrade net access to fix.
nmcli error
nmcli dev wifi connect <name>
Error: could not creat NMclient: object could not connect: no such file or directory
nmcli con up <name>
error connection activation failed no suitable device found for this connection
(device etho not available because profile is not compatiable with device (missmatching interface name)
all nmcli trouble shooting forum command lines fail to connect.
new stable libinput debian packages are installed in /home/usr
dpkg -i and tar xf fail
sudo startx launch
Don't do that.
In recovery mode
Use "rescue mode" from the Devuan ISO image instead:
https://www.debian.org/releases/bullsey … 06.en.html
I can't make much sense of the rest of the post though. Sorry.
“Et ignotas animum dimittit in artes.” — Ovid, Metamorphoses, VIII, 18.
sudo fsck -p fails to fix with recovery mode, live iso and live iso rescue mode.
booting into grub rescue mode with shift key, init=/bin/bash, F10
not showing grub rescue menu, command line only in large font. rescue and rescue/enable=true not launching rescue menu.
rescue mode not detecting wlan0.
So the problem is not caused by filesystem corruption then. No surprise there.
A soname error would suggest a FrankenDevuan. Have you been mixing stable with testing/unstable?
The rescue/enable=true parameter only works in the live ISO and that would only detect wlan0 if you used a version which includes non-free firmware. Did you try that?
Using init=/bin/bash would not start any services so a lack of network would be expected in that case.
mixing stable with newer kernels from sysnaptic, which get patch updates upgrades. no testing or rolling config
rescue/enable=true in live iso not lauching grub rescue graphical interface, launch command line grub
That could very well have broken your system, depending on the exact commands used. Please provide those commands.
I have no idea what this means, sorry. Can you not ask about this on a forum in your native language?
Pages: 1
