#1 2023-01-16 21:57:16
jue-gen
[SOLVED] No screen after suspend2ram
Maybe someone has a tip for me: my new computer (chimaera) wakes up again after suspend to ram, but the screen does not come back on.
#2 2023-01-17 06:08:40
Re: [SOLVED] No screen after suspend2ram
What is your graphics hardware and driver(s)?
lspci -knn | grep -iA3 'vga\|3d\|display'
If you have an Intel card then remove the xserver-xorg-video-intel package.
#3 2023-01-17 07:03:42
jue-gen
Thanks for the tip, maybe I'll get further that way. I have no plan at the moment.
01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller [1022:43d5] (rev 01)
	Subsystem: ASMedia Technology Inc. 400 Series Chipset USB 3.1 XHCI Controller [1b21:1142]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
0a:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev d9)
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636]
	Kernel modules: amdgpu
0a:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1637]
On my older ThinkPad I had no problems with Chimaera and also now Daedalus.
I was already considering whether upgrading to Daedalus might help on this new machine. Maybe also because of the 6* kernel.
xserver-xorg-video-intel is apparently installed. Can I just uninstall that?
#4 2023-01-17 07:26:16
You can remove the package but it's not being used because you have an AMD card.
However, the card should have a "kernel driver in use" line, which is missing. That is usually caused by conflict with the radeon module but that module isn't listed at all hmm
Please share you X.Org log and the full output of
# dmesg
Run the command as soon after a reboot as possible to keep it brief.
#5 2023-01-17 07:51:35
jue-gen
Oh, that's long anyway:
[    0.000000] Linux version 5.10.0-20-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 SMP Debian 5.10.158-2 (2022-12-13)
[    0.000000] Command line: BOOT_IMAGE=/vmlinuz-5.10.0-20-amd64 root=/dev/mapper/wurm--1--vg-root ro quiet
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009bfefff] usable
[    0.000000] BIOS-e820: [mem 0x0000000009bff000-0x0000000009ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20bfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000000a20c000-0x000000000affffff] usable
[    0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b01ffff] reserved
[    0.000000] BIOS-e820: [mem 0x000000000b020000-0x00000000b8d98fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000b8d99000-0x00000000ba4d9fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ba4da000-0x00000000ba50dfff] ACPI data
[    0.000000] BIOS-e820: [mem 0x00000000ba50e000-0x00000000bbfc0fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000bbfc1000-0x00000000bcd77fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000bcd78000-0x00000000bcdfefff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000bcdff000-0x00000000bdffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000be000000-0x00000000bfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd200000-0x00000000fd2fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fd600000-0x00000000fd6fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041e2fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000041e300000-0x000000043fffffff] reserved
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.70 by American Megatrends
[    0.000000] efi: ACPI=0xbbfaa000 ACPI 2.0=0xbbfaa014 TPMFinalLog=0xbaf74000 SMBIOS=0xbcc25000 SMBIOS 3.0=0xbcc24000 MEMATTR=0xb5478298 ESRT=0xb75c5998
[    0.000000] secureboot: Secure boot disabled
[    0.000000] SMBIOS 3.3.0 present.
[    0.000000] DMI: To Be Filled By O.E.M. B450 Steel Legend/B450 Steel Legend, BIOS P4.30 02/25/2022
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 3700.235 MHz processor
[    0.000457] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000459] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000467] last_pfn = 0x41e300 max_arch_pfn = 0x400000000
[    0.000471] MTRR default type: uncachable
[    0.000472] MTRR fixed ranges enabled:
[    0.000473]   00000-9FFFF write-back
[    0.000473]   A0000-BFFFF write-through
[    0.000474]   C0000-FFFFF write-protect
[    0.000475] MTRR variable ranges enabled:
[    0.000476]   0 base 000000000000 mask FFFF80000000 write-back
[    0.000476]   1 base 000080000000 mask FFFFC0000000 write-back
[    0.000477]   2 disabled
[    0.000477]   3 disabled
[    0.000478]   4 disabled
[    0.000478]   5 disabled
[    0.000478]   6 disabled
[    0.000479]   7 disabled
[    0.000480] TOM2: 0000000440000000 aka 17408M
[    0.000785] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000901] e820: update [mem 0xc0000000-0xffffffff] usable ==> reserved
[    0.000909] last_pfn = 0xbe000 max_arch_pfn = 0x400000000
[    0.004651] esrt: Reserving ESRT space from 0x00000000b75c5998 to 0x00000000b75c59d0.
[    0.004661] e820: update [mem 0xb75c5000-0xb75c5fff] usable ==> reserved
[    0.004710] Using GB pages for direct mapping
[    0.005386] RAMDISK: [mem 0x3423b000-0x36114fff]
[    0.005389] ACPI: Early table checksum verification disabled
[    0.005392] ACPI: RSDP 0x00000000BBFAA014 000024 (v02 ALASKA)
[    0.005395] ACPI: XSDT 0x00000000BBFA9728 0000C4 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.005399] ACPI: FACP 0x00000000BA500000 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.005402] ACPI: DSDT 0x00000000BA4FA000 005FB7 (v02 ALASKA A M I    01072009 INTL 20120913)
[    0.005405] ACPI: FACS 0x00000000BAFA4000 000040
[    0.005406] ACPI: SSDT 0x00000000BA506000 0072B0 (v02 AMD    MYRTLE   00000002 MSFT 04000000)
[    0.005409] ACPI: SSDT 0x00000000BA502000 003AD2 (v01 AMD    AMD AOD  00000001 INTL 20120913)
[    0.005411] ACPI: SSDT 0x00000000BA501000 0000C8 (v02 ALASKA CPUSSDT  01072009 AMI  01072009)
[    0.005413] ACPI: FIDT 0x00000000BA4F9000 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.005415] ACPI: MCFG 0x00000000BA4F8000 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.005417] ACPI: AAFT 0x00000000BA4F7000 0000F1 (v01 ALASKA OEMAAFT  01072009 MSFT 00000097)
[    0.005419] ACPI: HPET 0x00000000BA4F6000 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
[    0.005421] ACPI: BGRT 0x00000000BA4F5000 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.005423] ACPI: TPM2 0x00000000BA4F4000 00004C (v04 ALASKA A M I    00000001 AMI  00000000)
[    0.005425] ACPI: SSDT 0x00000000BA4F1000 002808 (v02 AMD    AmdTable 00000001 AMD  00000001)
[    0.005427] ACPI: CRAT 0x00000000BA4F0000 000BA8 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.005429] ACPI: CDIT 0x00000000BA4EF000 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.005431] ACPI: SSDT 0x00000000BA4EB000 003802 (v01 AMD    MYRTLE   00000001 INTL 20120913)
[    0.005433] ACPI: SSDT 0x00000000BA4EA000 0000BF (v01 AMD    AmdTable 00001000 INTL 20120913)
[    0.005435] ACPI: WSMT 0x00000000BA4E9000 000028 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.005437] ACPI: APIC 0x00000000BA4E8000 00015E (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.005439] ACPI: SSDT 0x00000000BA4E7000 000497 (v01 AMD    MYRTLERN 00000001 INTL 20120913)
[    0.005441] ACPI: SSDT 0x00000000BA4E5000 0010AF (v01 AMD    MYRTLE   00000001 INTL 20120913)
[    0.005443] ACPI: FPDT 0x00000000BA4E4000 000044 (v01 ALASKA A M I    01072009 AMI  01000013)
[    0.005445] ACPI: Reserving FACP table memory at [mem 0xba500000-0xba500113]
[    0.005446] ACPI: Reserving DSDT table memory at [mem 0xba4fa000-0xba4fffb6]
[    0.005447] ACPI: Reserving FACS table memory at [mem 0xbafa4000-0xbafa403f]
[    0.005447] ACPI: Reserving SSDT table memory at [mem 0xba506000-0xba50d2af]
[    0.005448] ACPI: Reserving SSDT table memory at [mem 0xba502000-0xba505ad1]
[    0.005449] ACPI: Reserving SSDT table memory at [mem 0xba501000-0xba5010c7]
[    0.005449] ACPI: Reserving FIDT table memory at [mem 0xba4f9000-0xba4f909b]
[    0.005450] ACPI: Reserving MCFG table memory at [mem 0xba4f8000-0xba4f803b]
[    0.005450] ACPI: Reserving AAFT table memory at [mem 0xba4f7000-0xba4f70f0]
[    0.005451] ACPI: Reserving HPET table memory at [mem 0xba4f6000-0xba4f6037]
[    0.005451] ACPI: Reserving BGRT table memory at [mem 0xba4f5000-0xba4f5037]
[    0.005452] ACPI: Reserving TPM2 table memory at [mem 0xba4f4000-0xba4f404b]
[    0.005453] ACPI: Reserving SSDT table memory at [mem 0xba4f1000-0xba4f3807]
[    0.005453] ACPI: Reserving CRAT table memory at [mem 0xba4f0000-0xba4f0ba7]
[    0.005454] ACPI: Reserving CDIT table memory at [mem 0xba4ef000-0xba4ef028]
[    0.005454] ACPI: Reserving SSDT table memory at [mem 0xba4eb000-0xba4ee801]
[    0.005455] ACPI: Reserving SSDT table memory at [mem 0xba4ea000-0xba4ea0be]
[    0.005456] ACPI: Reserving WSMT table memory at [mem 0xba4e9000-0xba4e9027]
[    0.005456] ACPI: Reserving APIC table memory at [mem 0xba4e8000-0xba4e815d]
[    0.005457] ACPI: Reserving SSDT table memory at [mem 0xba4e7000-0xba4e7496]
[    0.005457] ACPI: Reserving SSDT table memory at [mem 0xba4e5000-0xba4e60ae]
[    0.005458] ACPI: Reserving FPDT table memory at [mem 0xba4e4000-0xba4e4043]
[    0.005469] ACPI: Local APIC address 0xfee00000
[    0.005513] No NUMA configuration found
[    0.005514] Faking a node at [mem 0x0000000000000000-0x000000041e2fffff]
[    0.005521] NODE_DATA(0) allocated [mem 0x41e2d6000-0x41e2fffff]
[    0.005776] Zone ranges:
[    0.005776]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.005777]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.005778]   Normal   [mem 0x0000000100000000-0x000000041e2fffff]
[    0.005779]   Device   empty
[    0.005780] Movable zone start for each node
[    0.005782] Early memory node ranges
[    0.005783]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.005784]   node   0: [mem 0x0000000000100000-0x0000000009bfefff]
[    0.005784]   node   0: [mem 0x000000000a000000-0x000000000a1fffff]
[    0.005785]   node   0: [mem 0x000000000a20c000-0x000000000affffff]
[    0.005785]   node   0: [mem 0x000000000b020000-0x00000000b8d98fff]
[    0.005786]   node   0: [mem 0x00000000bcdff000-0x00000000bdffffff]
[    0.005787]   node   0: [mem 0x0000000100000000-0x000000041e2fffff]
[    0.005789] Initmem setup node 0 [mem 0x0000000000001000-0x000000041e2fffff]
[    0.005790] On node 0 totalpages: 4029964
[    0.005791]   DMA zone: 64 pages used for memmap
[    0.005791]   DMA zone: 34 pages reserved
[    0.005792]   DMA zone: 3999 pages, LIFO batch:0
[    0.005792]   DMA32 zone: 11822 pages used for memmap
[    0.005793]   DMA32 zone: 756589 pages, LIFO batch:63
[    0.005793]   Normal zone: 51084 pages used for memmap
[    0.005794]   Normal zone: 3269376 pages, LIFO batch:63
[    0.005796] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.005819] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.006024] On node 0, zone DMA32: 1025 pages in unavailable ranges
[    0.006044] On node 0, zone DMA32: 12 pages in unavailable ranges
[    0.011407] On node 0, zone DMA32: 32 pages in unavailable ranges
[    0.011589] On node 0, zone DMA32: 16486 pages in unavailable ranges
[    0.011920] On node 0, zone Normal: 8192 pages in unavailable ranges
[    0.011990] On node 0, zone Normal: 7424 pages in unavailable ranges
[    0.012454] ACPI: PM-Timer IO Port: 0x808
[    0.012456] ACPI: Local APIC address 0xfee00000
[    0.012462] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.012473] IOAPIC[0]: apic_id 13, version 33, address 0xfec00000, GSI 0-23
[    0.012477] IOAPIC[1]: apic_id 14, version 33, address 0xfec01000, GSI 24-55
[    0.012478] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.012480] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.012481] ACPI: IRQ0 used by override.
[    0.012481] ACPI: IRQ9 used by override.
[    0.012483] Using ACPI (MADT) for SMP configuration information
[    0.012484] ACPI: HPET id: 0x10228201 base: 0xfed00000
[    0.012497] e820: update [mem 0xb4a74000-0xb4ab4fff] usable ==> reserved
[    0.012511] smpboot: Allowing 32 CPUs, 20 hotplug CPUs
[    0.012539] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.012540] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.012541] PM: hibernation: Registered nosave memory: [mem 0x09bff000-0x09ffffff]
[    0.012543] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20bfff]
[    0.012544] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b01ffff]
[    0.012545] PM: hibernation: Registered nosave memory: [mem 0xb4a74000-0xb4ab4fff]
[    0.012547] PM: hibernation: Registered nosave memory: [mem 0xb75c5000-0xb75c5fff]
[    0.012548] PM: hibernation: Registered nosave memory: [mem 0xb8d99000-0xba4d9fff]
[    0.012548] PM: hibernation: Registered nosave memory: [mem 0xba4da000-0xba50dfff]
[    0.012549] PM: hibernation: Registered nosave memory: [mem 0xba50e000-0xbbfc0fff]
[    0.012549] PM: hibernation: Registered nosave memory: [mem 0xbbfc1000-0xbcd77fff]
[    0.012550] PM: hibernation: Registered nosave memory: [mem 0xbcd78000-0xbcdfefff]
[    0.012551] PM: hibernation: Registered nosave memory: [mem 0xbe000000-0xbfffffff]
[    0.012552] PM: hibernation: Registered nosave memory: [mem 0xc0000000-0xefffffff]
[    0.012552] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.012553] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfd1fffff]
[    0.012553] PM: hibernation: Registered nosave memory: [mem 0xfd200000-0xfd2fffff]
[    0.012554] PM: hibernation: Registered nosave memory: [mem 0xfd300000-0xfd5fffff]
[    0.012554] PM: hibernation: Registered nosave memory: [mem 0xfd600000-0xfd6fffff]
[    0.012554] PM: hibernation: Registered nosave memory: [mem 0xfd700000-0xfe9fffff]
[    0.012555] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[    0.012555] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[    0.012556] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[    0.012556] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[    0.012556] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.012557] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[    0.012557] PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[    0.012558] PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[    0.012558] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.012559] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[    0.012559] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[    0.012559] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[    0.012560] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[    0.012560] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[    0.012561] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[    0.012561] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[    0.012561] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[    0.012562] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfeffffff]
[    0.012562] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.012564] [mem 0xc0000000-0xefffffff] available for PCI devices
[    0.012565] Booting paravirtualized kernel on bare hardware
[    0.012568] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.015418] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[    0.017246] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[    0.017255] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[    0.017257] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.017263] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[    0.017305] Built 1 zonelists, mobility grouping on.  Total pages: 3966960
[    0.017306] Policy zone: Normal
[    0.017307] Kernel command line: BOOT_IMAGE=/vmlinuz-5.10.0-20-amd64 root=/dev/mapper/wurm--1--vg-root ro quiet
[    0.017346] printk: log_buf_len individual max cpu contribution: 4096 bytes
[    0.017347] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[    0.017347] printk: log_buf_len min size: 131072 bytes
[    0.017537] printk: log_buf_len: 262144 bytes
[    0.017538] printk: early log buf free: 115680(88%)
[    0.019427] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.020372] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.020473] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.037878] Memory: 2980940K/16119856K available (12295K kernel code, 2536K rwdata, 7556K rodata, 2664K init, 5468K bss, 517552K reserved, 0K cma-reserved)
[    0.038479] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[    0.038509] ftrace: allocating 36508 entries in 143 pages
[    0.051008] ftrace: allocated 143 pages with 5 groups
[    0.051257] rcu: Hierarchical RCU implementation.
[    0.051258] rcu: 	RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=32.
[    0.051259] 	Rude variant of Tasks RCU enabled.
[    0.051259] 	Tracing variant of Tasks RCU enabled.
[    0.051260] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.051260] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[    0.054457] NR_IRQS: 524544, nr_irqs: 1224, preallocated irqs: 16
[    0.054707] random: crng init done
[    0.054746] Console: colour dummy device 80x25
[    0.054756] printk: console [tty0] enabled
[    0.054779] ACPI: Core revision 20200925
[    0.054899] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.054915] APIC: Switch to symmetric I/O mode setup
[    0.055036] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.055092] Switched APIC routing to physical flat.
[    0.055661] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.074921] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6aac684028c, max_idle_ns: 881590538088 ns
[    0.074925] Calibrating delay loop (skipped), value calculated using timer frequency.. 7400.47 BogoMIPS (lpj=14800940)
[    0.074927] pid_max: default: 32768 minimum: 301
[    0.077568] LSM: Security Framework initializing
[    0.077579] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.077611] AppArmor: AppArmor initialized
[    0.077612] TOMOYO Linux initialized
[    0.077725] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.077769] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.078116] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[    0.078168] LVT offset 1 assigned for vector 0xf9
[    0.078263] LVT offset 2 assigned for vector 0xf4
[    0.078289] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[    0.078289] Last level dTLB entries: 4KB 2048, 2MB 2048, 4MB 1024, 1GB 0
[    0.078293] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.078295] Spectre V2 : Mitigation: Retpolines
[    0.078296] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.078296] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.078296] Spectre V2 : Enabling Speculation Barrier for firmware calls
[    0.078297] RETBleed: Mitigation: untrained return thunk
[    0.078299] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.078299] Spectre V2 : Selecting STIBP always-on mode to complement retbleed mitigation
[    0.078300] Spectre V2 : User space: Mitigation: STIBP always-on protection
[    0.078300] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.082904] Freeing SMP alternatives memory: 32K
[    0.198254] smpboot: CPU0: AMD Ryzen 5 PRO 4650G with Radeon Graphics (family: 0x17, model: 0x60, stepping: 0x1)
[    0.198381] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.198385] ... version:                0
[    0.198385] ... bit width:              48
[    0.198385] ... generic registers:      6
[    0.198386] ... value mask:             0000ffffffffffff
[    0.198386] ... max period:             00007fffffffffff
[    0.198387] ... fixed-purpose events:   0
[    0.198387] ... event mask:             000000000000003f
[    0.198469] rcu: Hierarchical SRCU implementation.
[    0.198770] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.198922] smp: Bringing up secondary CPUs ...
[    0.198922] x86: Booting SMP configuration:
[    0.198922] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6
[    0.209135] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[    0.209135]   #7  #8  #9 #10 #11
[    0.218947] smp: Brought up 1 node, 12 CPUs
[    0.218947] smpboot: Max logical packages: 3
[    0.218947] smpboot: Total of 12 processors activated (88805.64 BogoMIPS)
[    0.242937] node 0 deferred pages initialised in 24ms
[    0.243286] devtmpfs: initialized
[    0.243286] x86/mm: Memory block size: 128MB
[    0.243296] PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20bfff] (49152 bytes)
[    0.243296] PM: Registering ACPI NVS region [mem 0xba50e000-0xbbfc0fff] (27996160 bytes)
[    0.243296] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.243344] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[    0.243443] pinctrl core: initialized pinctrl subsystem
[    0.243611] NET: Registered protocol family 16
[    0.243870] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.244070] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.244283] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.244294] audit: initializing netlink subsys (disabled)
[    0.244306] audit: type=2000 audit(1673941669.188:1): state=initialized audit_enabled=0 res=1
[    0.244306] thermal_sys: Registered thermal governor 'fair_share'
[    0.244306] thermal_sys: Registered thermal governor 'bang_bang'
[    0.244306] thermal_sys: Registered thermal governor 'step_wise'
[    0.244306] thermal_sys: Registered thermal governor 'user_space'
[    0.244306] thermal_sys: Registered thermal governor 'power_allocator'
[    0.244306] cpuidle: using governor ladder
[    0.244306] cpuidle: using governor menu
[    0.244306] ACPI: bus type PCI registered
[    0.244306] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.244306] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.244306] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.244306] PCI: Using configuration type 1 for base access
[    0.246964] Kprobes globally optimized
[    0.246968] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.246968] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.323862] ACPI: Added _OSI(Module Device)
[    0.323862] ACPI: Added _OSI(Processor Device)
[    0.323862] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.323862] ACPI: Added _OSI(Processor Aggregator Device)
[    0.323862] ACPI: Added _OSI(Linux-Dell-Video)
[    0.323862] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.323862] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.328630] ACPI: 9 ACPI AML tables successfully acquired and loaded
[    0.329402] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.331227] ACPI: Interpreter enabled
[    0.331238] ACPI: (supports S0 S3 S4 S5)
[    0.331238] ACPI: Using IOAPIC for interrupt routing
[    0.331428] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.331648] ACPI: Enabled 4 GPEs in block 00 to 1F
[    0.336864] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.336868] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.336956] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
[    0.337039] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.337046] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[    0.337212] PCI host bridge to bus 0000:00
[    0.337213] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.337213] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.337214] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.337215] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.337215] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.337216] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.337217] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xfec2ffff window]
[    0.337218] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.337219] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.337228] pci 0000:00:00.0: [1022:1630] type 00 class 0x060000
[    0.337302] pci 0000:00:01.0: [1022:1632] type 00 class 0x060000
[    0.337356] pci 0000:00:02.0: [1022:1632] type 00 class 0x060000
[    0.337406] pci 0000:00:02.1: [1022:1634] type 01 class 0x060400
[    0.337426] pci 0000:00:02.1: enabling Extended Tags
[    0.337456] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[    0.337521] pci 0000:00:02.2: [1022:1634] type 01 class 0x060400
[    0.337540] pci 0000:00:02.2: enabling Extended Tags
[    0.337568] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[    0.337639] pci 0000:00:08.0: [1022:1632] type 00 class 0x060000
[    0.337690] pci 0000:00:08.1: [1022:1635] type 01 class 0x060400
[    0.337708] pci 0000:00:08.1: enabling Extended Tags
[    0.337736] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.337801] pci 0000:00:08.2: [1022:1635] type 01 class 0x060400
[    0.337819] pci 0000:00:08.2: enabling Extended Tags
[    0.337847] pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
[    0.337929] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.338030] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.338137] pci 0000:00:18.0: [1022:1448] type 00 class 0x060000
[    0.338169] pci 0000:00:18.1: [1022:1449] type 00 class 0x060000
[    0.338199] pci 0000:00:18.2: [1022:144a] type 00 class 0x060000
[    0.338229] pci 0000:00:18.3: [1022:144b] type 00 class 0x060000
[    0.338259] pci 0000:00:18.4: [1022:144c] type 00 class 0x060000
[    0.338291] pci 0000:00:18.5: [1022:144d] type 00 class 0x060000
[    0.338322] pci 0000:00:18.6: [1022:144e] type 00 class 0x060000
[    0.338352] pci 0000:00:18.7: [1022:144f] type 00 class 0x060000
[    0.338438] pci 0000:01:00.0: [1022:43d5] type 00 class 0x0c0330
[    0.338454] pci 0000:01:00.0: reg 0x10: [mem 0xfcda0000-0xfcda7fff 64bit]
[    0.338489] pci 0000:01:00.0: enabling Extended Tags
[    0.338542] pci 0000:01:00.0: PME# supported from D3hot D3cold
[    0.338626] pci 0000:01:00.1: [1022:43c8] type 00 class 0x010601
[    0.338669] pci 0000:01:00.1: reg 0x24: [mem 0xfcd80000-0xfcd9ffff]
[    0.338676] pci 0000:01:00.1: reg 0x30: [mem 0xfcd00000-0xfcd7ffff pref]
[    0.338681] pci 0000:01:00.1: enabling Extended Tags
[    0.338718] pci 0000:01:00.1: PME# supported from D3hot D3cold
[    0.338778] pci 0000:01:00.2: [1022:43c6] type 01 class 0x060400
[    0.338817] pci 0000:01:00.2: enabling Extended Tags
[    0.338858] pci 0000:01:00.2: PME# supported from D3hot D3cold
[    0.338931] pci 0000:00:02.1: PCI bridge to [bus 01-08]
[    0.338934] pci 0000:00:02.1:   bridge window [io  0xd000-0xefff]
[    0.338935] pci 0000:00:02.1:   bridge window [mem 0xfca00000-0xfcdfffff]
[    0.339006] pci 0000:02:00.0: [1022:43c7] type 01 class 0x060400
[    0.339049] pci 0000:02:00.0: enabling Extended Tags
[    0.339102] pci 0000:02:00.0: PME# supported from D3hot D3cold
[    0.339180] pci 0000:02:01.0: [1022:43c7] type 01 class 0x060400
[    0.339222] pci 0000:02:01.0: enabling Extended Tags
[    0.339275] pci 0000:02:01.0: PME# supported from D3hot D3cold
[    0.339357] pci 0000:02:04.0: [1022:43c7] type 01 class 0x060400
[    0.339400] pci 0000:02:04.0: enabling Extended Tags
[    0.339452] pci 0000:02:04.0: PME# supported from D3hot D3cold
[    0.339530] pci 0000:02:05.0: [1022:43c7] type 01 class 0x060400
[    0.339573] pci 0000:02:05.0: enabling Extended Tags
[    0.339625] pci 0000:02:05.0: PME# supported from D3hot D3cold
[    0.339705] pci 0000:02:06.0: [1022:43c7] type 01 class 0x060400
[    0.339748] pci 0000:02:06.0: enabling Extended Tags
[    0.339801] pci 0000:02:06.0: PME# supported from D3hot D3cold
[    0.339881] pci 0000:02:07.0: [1022:43c7] type 01 class 0x060400
[    0.339923] pci 0000:02:07.0: enabling Extended Tags
[    0.339976] pci 0000:02:07.0: PME# supported from D3hot D3cold
[    0.340062] pci 0000:01:00.2: PCI bridge to [bus 02-08]
[    0.340066] pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
[    0.340069] pci 0000:01:00.2:   bridge window [mem 0xfca00000-0xfccfffff]
[    0.340105] pci 0000:02:00.0: PCI bridge to [bus 03]
[    0.340147] pci 0000:02:01.0: PCI bridge to [bus 04]
[    0.340188] pci 0000:02:04.0: PCI bridge to [bus 05]
[    0.340257] pci 0000:06:00.0: [8086:2723] type 00 class 0x028000
[    0.340285] pci 0000:06:00.0: reg 0x10: [mem 0xfcc00000-0xfcc03fff 64bit]
[    0.340439] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[    0.340563] pci 0000:02:05.0: PCI bridge to [bus 06]
[    0.340569] pci 0000:02:05.0:   bridge window [mem 0xfcc00000-0xfccfffff]
[    0.340623] pci 0000:07:00.0: [1b21:0612] type 00 class 0x010601
[    0.340645] pci 0000:07:00.0: reg 0x10: [io  0xe050-0xe057]
[    0.340656] pci 0000:07:00.0: reg 0x14: [io  0xe040-0xe043]
[    0.340668] pci 0000:07:00.0: reg 0x18: [io  0xe030-0xe037]
[    0.340680] pci 0000:07:00.0: reg 0x1c: [io  0xe020-0xe023]
[    0.340692] pci 0000:07:00.0: reg 0x20: [io  0xe000-0xe01f]
[    0.340704] pci 0000:07:00.0: reg 0x24: [mem 0xfcb00000-0xfcb001ff]
[    0.340865] pci 0000:02:06.0: PCI bridge to [bus 07]
[    0.340869] pci 0000:02:06.0:   bridge window [io  0xe000-0xefff]
[    0.340872] pci 0000:02:06.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.340938] pci 0000:08:00.0: [10ec:8168] type 00 class 0x020000
[    0.340963] pci 0000:08:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.340998] pci 0000:08:00.0: reg 0x18: [mem 0xfca04000-0xfca04fff 64bit]
[    0.341020] pci 0000:08:00.0: reg 0x20: [mem 0xfca00000-0xfca03fff 64bit]
[    0.341165] pci 0000:08:00.0: supports D1 D2
[    0.341166] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.341329] pci 0000:02:07.0: PCI bridge to [bus 08]
[    0.341333] pci 0000:02:07.0:   bridge window [io  0xd000-0xdfff]
[    0.341335] pci 0000:02:07.0:   bridge window [mem 0xfca00000-0xfcafffff]
[    0.341429] pci 0000:09:00.0: [15b7:5009] type 00 class 0x010802
[    0.341443] pci 0000:09:00.0: reg 0x10: [mem 0xfcf00000-0xfcf03fff 64bit]
[    0.341465] pci 0000:09:00.0: reg 0x20: [mem 0xfcf04000-0xfcf040ff 64bit]
[    0.341592] pci 0000:00:02.2: PCI bridge to [bus 09]
[    0.341595] pci 0000:00:02.2:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.341645] pci 0000:0a:00.0: [1002:1636] type 00 class 0x030000
[    0.341655] pci 0000:0a:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.341661] pci 0000:0a:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
[    0.341665] pci 0000:0a:00.0: reg 0x20: [io  0xf000-0xf0ff]
[    0.341669] pci 0000:0a:00.0: reg 0x24: [mem 0xfc900000-0xfc97ffff]
[    0.341676] pci 0000:0a:00.0: enabling Extended Tags
[    0.341686] pci 0000:0a:00.0: BAR 0: assigned to efifb
[    0.341723] pci 0000:0a:00.0: PME# supported from D1 D2 D3hot D3cold
[    0.341755] pci 0000:0a:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.341792] pci 0000:0a:00.1: [1002:1637] type 00 class 0x040300
[    0.341799] pci 0000:0a:00.1: reg 0x10: [mem 0xfc988000-0xfc98bfff]
[    0.341823] pci 0000:0a:00.1: enabling Extended Tags
[    0.341850] pci 0000:0a:00.1: PME# supported from D1 D2 D3hot D3cold
[    0.341896] pci 0000:0a:00.2: [1022:15df] type 00 class 0x108000
[    0.341910] pci 0000:0a:00.2: reg 0x18: [mem 0xfc800000-0xfc8fffff]
[    0.341921] pci 0000:0a:00.2: reg 0x24: [mem 0xfc98c000-0xfc98dfff]
[    0.341928] pci 0000:0a:00.2: enabling Extended Tags
[    0.342000] pci 0000:0a:00.3: [1022:1639] type 00 class 0x0c0330
[    0.342009] pci 0000:0a:00.3: reg 0x10: [mem 0xfc700000-0xfc7fffff 64bit]
[    0.342030] pci 0000:0a:00.3: enabling Extended Tags
[    0.342059] pci 0000:0a:00.3: PME# supported from D0 D3hot D3cold
[    0.342106] pci 0000:0a:00.4: [1022:1639] type 00 class 0x0c0330
[    0.342115] pci 0000:0a:00.4: reg 0x10: [mem 0xfc600000-0xfc6fffff 64bit]
[    0.342135] pci 0000:0a:00.4: enabling Extended Tags
[    0.342165] pci 0000:0a:00.4: PME# supported from D0 D3hot D3cold
[    0.342211] pci 0000:0a:00.6: [1022:15e3] type 00 class 0x040300
[    0.342219] pci 0000:0a:00.6: reg 0x10: [mem 0xfc980000-0xfc987fff]
[    0.342243] pci 0000:0a:00.6: enabling Extended Tags
[    0.342269] pci 0000:0a:00.6: PME# supported from D0 D3hot D3cold
[    0.342325] pci 0000:00:08.1: PCI bridge to [bus 0a]
[    0.342327] pci 0000:00:08.1:   bridge window [io  0xf000-0xffff]
[    0.342329] pci 0000:00:08.1:   bridge window [mem 0xfc600000-0xfc9fffff]
[    0.342331] pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.342367] pci 0000:0b:00.0: [1022:7901] type 00 class 0x010601
[    0.342392] pci 0000:0b:00.0: reg 0x24: [mem 0xfce01000-0xfce017ff]
[    0.342399] pci 0000:0b:00.0: enabling Extended Tags
[    0.342458] pci 0000:0b:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:08.2 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.342488] pci 0000:0b:00.1: [1022:7901] type 00 class 0x010601
[    0.342512] pci 0000:0b:00.1: reg 0x24: [mem 0xfce00000-0xfce007ff]
[    0.342519] pci 0000:0b:00.1: enabling Extended Tags
[    0.342592] pci 0000:00:08.2: PCI bridge to [bus 0b]
[    0.342595] pci 0000:00:08.2:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.342934] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 11 14 15) *0
[    0.342967] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 7 10 11 14 15) *0
[    0.342994] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 7 10 11 14 15) *0
[    0.343028] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 10 11 14 15) *0
[    0.343059] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 11 14 15) *0
[    0.343084] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 10 11 14 15) *0
[    0.343110] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[    0.343135] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[    0.343531] iommu: Default domain type: Translated
[    0.343537] pci 0000:0a:00.0: vgaarb: setting as boot VGA device
[    0.343537] pci 0000:0a:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.343537] pci 0000:0a:00.0: vgaarb: bridge control possible
[    0.343537] vgaarb: loaded
[    0.343537] EDAC MC: Ver: 3.0.0
[    0.343540] Registered efivars operations
[    0.343540] NetLabel: Initializing
[    0.343540] NetLabel:  domain hash size = 128
[    0.343540] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.343540] NetLabel:  unlabeled traffic allowed by default
[    0.343540] PCI: Using ACPI for IRQ routing
[    0.349773] PCI: pci_cache_line_size set to 64 bytes
[    0.349855] e820: reserve RAM buffer [mem 0x09bff000-0x0bffffff]
[    0.349856] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[    0.349857] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[    0.349857] e820: reserve RAM buffer [mem 0xb4a74000-0xb7ffffff]
[    0.349858] e820: reserve RAM buffer [mem 0xb75c5000-0xb7ffffff]
[    0.349858] e820: reserve RAM buffer [mem 0xb8d99000-0xbbffffff]
[    0.349859] e820: reserve RAM buffer [mem 0xbe000000-0xbfffffff]
[    0.349859] e820: reserve RAM buffer [mem 0x41e300000-0x41fffffff]
[    0.349876] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.349878] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.350962] clocksource: Switched to clocksource tsc-early
[    0.357334] VFS: Disk quotas dquot_6.6.0
[    0.357354] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.357458] AppArmor: AppArmor Filesystem Enabled
[    0.357469] pnp: PnP ACPI init
[    0.357581] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.357585] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.357604] system 00:01: [mem 0xfeb80000-0xfebfffff] has been reserved
[    0.357606] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.357636] system 00:02: [mem 0x420000000-0x43fffffff window] has been reserved
[    0.357638] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.357703] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.357812] system 00:04: [io  0x0280-0x028f] has been reserved
[    0.357813] system 00:04: [io  0x0290-0x029f] has been reserved
[    0.357814] system 00:04: [io  0x02a0-0x02af] has been reserved
[    0.357814] system 00:04: [io  0x02b0-0x02bf] has been reserved
[    0.357816] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.357984] pnp 00:05: [dma 0 disabled]
[    0.358004] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.358141] system 00:06: [io  0x04d0-0x04d1] has been reserved
[    0.358142] system 00:06: [io  0x040b] has been reserved
[    0.358143] system 00:06: [io  0x04d6] has been reserved
[    0.358144] system 00:06: [io  0x0c00-0x0c01] has been reserved
[    0.358144] system 00:06: [io  0x0c14] has been reserved
[    0.358145] system 00:06: [io  0x0c50-0x0c51] has been reserved
[    0.358146] system 00:06: [io  0x0c52] has been reserved
[    0.358146] system 00:06: [io  0x0c6c] has been reserved
[    0.358147] system 00:06: [io  0x0c6f] has been reserved
[    0.358147] system 00:06: [io  0x0cd8-0x0cdf] has been reserved
[    0.358148] system 00:06: [io  0x0800-0x089f] has been reserved
[    0.358149] system 00:06: [io  0x0b00-0x0b0f] has been reserved
[    0.358149] system 00:06: [io  0x0b20-0x0b3f] has been reserved
[    0.358150] system 00:06: [io  0x0900-0x090f] has been reserved
[    0.358151] system 00:06: [io  0x0910-0x091f] has been reserved
[    0.358153] system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.358154] system 00:06: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.358155] system 00:06: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.358155] system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.358156] system 00:06: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.358157] system 00:06: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.358158] system 00:06: [mem 0xff000000-0xffffffff] has been reserved
[    0.358159] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.358553] pnp: PnP ACPI: found 7 devices
[    0.364028] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.364093] NET: Registered protocol family 2
[    0.364320] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.365861] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.365998] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.366189] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.366251] TCP: Hash tables configured (established 131072 bind 65536)
[    0.366320] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.366362] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.366428] NET: Registered protocol family 1
[    0.366432] NET: Registered protocol family 44
[    0.366453] pci 0000:02:00.0: PCI bridge to [bus 03]
[    0.366468] pci 0000:02:01.0: PCI bridge to [bus 04]
[    0.366477] pci 0000:02:04.0: PCI bridge to [bus 05]
[    0.366486] pci 0000:02:05.0: PCI bridge to [bus 06]
[    0.366490] pci 0000:02:05.0:   bridge window [mem 0xfcc00000-0xfccfffff]
[    0.366496] pci 0000:02:06.0: PCI bridge to [bus 07]
[    0.366498] pci 0000:02:06.0:   bridge window [io  0xe000-0xefff]
[    0.366501] pci 0000:02:06.0:   bridge window [mem 0xfcb00000-0xfcbfffff]
[    0.366508] pci 0000:02:07.0: PCI bridge to [bus 08]
[    0.366509] pci 0000:02:07.0:   bridge window [io  0xd000-0xdfff]
[    0.366513] pci 0000:02:07.0:   bridge window [mem 0xfca00000-0xfcafffff]
[    0.366519] pci 0000:01:00.2: PCI bridge to [bus 02-08]
[    0.366520] pci 0000:01:00.2:   bridge window [io  0xd000-0xefff]
[    0.366524] pci 0000:01:00.2:   bridge window [mem 0xfca00000-0xfccfffff]
[    0.366530] pci 0000:00:02.1: PCI bridge to [bus 01-08]
[    0.366531] pci 0000:00:02.1:   bridge window [io  0xd000-0xefff]
[    0.366532] pci 0000:00:02.1:   bridge window [mem 0xfca00000-0xfcdfffff]
[    0.366536] pci 0000:00:02.2: PCI bridge to [bus 09]
[    0.366538] pci 0000:00:02.2:   bridge window [mem 0xfcf00000-0xfcffffff]
[    0.366542] pci 0000:00:08.1: PCI bridge to [bus 0a]
[    0.366542] pci 0000:00:08.1:   bridge window [io  0xf000-0xffff]
[    0.366545] pci 0000:00:08.1:   bridge window [mem 0xfc600000-0xfc9fffff]
[    0.366546] pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.366549] pci 0000:00:08.2: PCI bridge to [bus 0b]
[    0.366551] pci 0000:00:08.2:   bridge window [mem 0xfce00000-0xfcefffff]
[    0.366555] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.366556] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.366557] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.366557] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.366558] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.366559] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.366559] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xfec2ffff window]
[    0.366560] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[    0.366561] pci_bus 0000:01: resource 0 [io  0xd000-0xefff]
[    0.366561] pci_bus 0000:01: resource 1 [mem 0xfca00000-0xfcdfffff]
[    0.366562] pci_bus 0000:02: resource 0 [io  0xd000-0xefff]
[    0.366563] pci_bus 0000:02: resource 1 [mem 0xfca00000-0xfccfffff]
[    0.366563] pci_bus 0000:06: resource 1 [mem 0xfcc00000-0xfccfffff]
[    0.366564] pci_bus 0000:07: resource 0 [io  0xe000-0xefff]
[    0.366565] pci_bus 0000:07: resource 1 [mem 0xfcb00000-0xfcbfffff]
[    0.366565] pci_bus 0000:08: resource 0 [io  0xd000-0xdfff]
[    0.366566] pci_bus 0000:08: resource 1 [mem 0xfca00000-0xfcafffff]
[    0.366567] pci_bus 0000:09: resource 1 [mem 0xfcf00000-0xfcffffff]
[    0.366567] pci_bus 0000:0a: resource 0 [io  0xf000-0xffff]
[    0.366568] pci_bus 0000:0a: resource 1 [mem 0xfc600000-0xfc9fffff]
[    0.366569] pci_bus 0000:0a: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
[    0.366569] pci_bus 0000:0b: resource 1 [mem 0xfce00000-0xfcefffff]
[    0.366770] pci 0000:0a:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.366787] pci 0000:0a:00.1: D0 power state depends on 0000:0a:00.0
[    0.366792] pci 0000:0a:00.3: extending delay after power-on from D3hot to 20 msec
[    0.366878] pci 0000:0a:00.4: extending delay after power-on from D3hot to 20 msec
[    0.366919] PCI: CLS 64 bytes, default 64
[    0.366954] Trying to unpack rootfs image as initramfs...
[    0.679117] Freeing initrd memory: 31592K
[    0.679185] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.679187] software IO TLB: mapped [mem 0x00000000b0045000-0x00000000b4045000] (64MB)
[    0.679224] amd_uncore: 4  amd_df counters detected
[    0.679236] amd_uncore: 6  amd_l3 counters detected
[    0.679376] LVT offset 0 assigned for vector 0x400
[    0.679452] perf: AMD IBS detected (0x000003ff)
[    0.679851] Initialise system trusted keyrings
[    0.679859] Key type blacklist registered
[    0.679919] workingset: timestamp_bits=36 max_order=22 bucket_order=0
[    0.680546] zbud: loaded
[    0.680678] integrity: Platform Keyring initialized
[    0.680679] Key type asymmetric registered
[    0.680680] Asymmetric key parser 'x509' registered
[    0.680686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.680726] io scheduler mq-deadline registered
[    0.681854] pcieport 0000:00:02.1: PME: Signaling with IRQ 25
[    0.681926] pcieport 0000:00:02.2: PME: Signaling with IRQ 26
[    0.681992] pcieport 0000:00:08.1: PME: Signaling with IRQ 27
[    0.682101] pcieport 0000:00:08.2: PME: Signaling with IRQ 28
[    0.682855] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.682862] efifb: probing for efifb
[    0.682878] efifb: framebuffer at 0xd0000000, using 7104k, total 7104k
[    0.682878] efifb: mode is 1680x1050x32, linelength=6912, pages=1
[    0.682879] efifb: scrolling: redraw
[    0.682880] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.682934] Console: switching to colour frame buffer device 210x65
[    0.685148] fb0: EFI VGA frame buffer device
[    0.686007] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.686143] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.686935] Linux agpgart interface v0.103
[    0.687146] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.687557] i8042: PNP: No PS/2 controller found.
[    0.687586] mousedev: PS/2 mouse device common for all mice
[    0.687609] rtc_cmos 00:03: RTC can wake from S4
[    0.687734] rtc_cmos 00:03: registered as rtc0
[    0.687758] rtc_cmos 00:03: setting system clock to 2023-01-17T07:47:50 UTC (1673941670)
[    0.687766] rtc_cmos 00:03: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    0.687827] ledtrig-cpu: registered to indicate activity on CPUs
[    0.687997] NET: Registered protocol family 10
[    0.691408] Segment Routing with IPv6
[    0.691426] mip6: Mobile IPv6
[    0.691427] NET: Registered protocol family 17
[    0.691451] mpls_gso: MPLS GSO support
[    0.691906] microcode: CPU0: patch_level=0x08600106
[    0.691909] microcode: CPU1: patch_level=0x08600106
[    0.691912] microcode: CPU2: patch_level=0x08600106
[    0.691917] microcode: CPU3: patch_level=0x08600106
[    0.691922] microcode: CPU4: patch_level=0x08600106
[    0.691926] microcode: CPU5: patch_level=0x08600106
[    0.691930] microcode: CPU6: patch_level=0x08600106
[    0.691932] microcode: CPU7: patch_level=0x08600106
[    0.691934] microcode: CPU8: patch_level=0x08600106
[    0.691938] microcode: CPU9: patch_level=0x08600106
[    0.691942] microcode: CPU10: patch_level=0x08600106
[    0.691945] microcode: CPU11: patch_level=0x08600106
[    0.691948] microcode: Microcode Update Driver: v2.2.
[    0.692035] resctrl: L3 allocation detected
[    0.692035] resctrl: L3DATA allocation detected
[    0.692036] resctrl: L3CODE allocation detected
[    0.692036] resctrl: MB allocation detected
[    0.692036] resctrl: L3 monitoring detected
[    0.692038] IPI shorthand broadcast: enabled
[    0.692042] sched_clock: Marking stable (691797496, 232435)->(725299814, -33269883)
[    0.692092] registered taskstats version 1
[    0.692093] Loading compiled-in X.509 certificates
[    0.708933] Loaded X.509 cert 'Debian Secure Boot CA: 6ccece7e4c6c0d1f6149f3dd27dfcc5cbb419ea1'
[    0.708948] Loaded X.509 cert 'Debian Secure Boot Signer 2022 - linux: 14011249c2675ea8e5148542202005810584b25f'
[    0.709025] zswap: loaded using pool lzo/zbud
[    0.709179] Key type .fscrypt registered
[    0.709180] Key type fscrypt-provisioning registered
[    0.709212] AppArmor: AppArmor sha1 policy hashing enabled
[    0.710659] Freeing unused decrypted memory: 2036K
[    0.711016] Freeing unused kernel image (initmem) memory: 2664K
[    0.728975] Write protecting the kernel read-only data: 22528k
[    0.729699] Freeing unused kernel image (text/rodata gap) memory: 2040K
[    0.729818] Freeing unused kernel image (rodata/data gap) memory: 636K
[    0.759481] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.759491] Run /init as init process
[    0.759492]   with arguments:
[    0.759493]     /init
[    0.759493]   with environment:
[    0.759493]     HOME=/
[    0.759493]     TERM=linux
[    0.759494]     BOOT_IMAGE=/vmlinuz-5.10.0-20-amd64
[    0.794689] udevd[171]: starting version 3.2.9
[    0.795201] udevd[172]: starting eudev-3.2.9
[    0.803521] ACPI: Video Device [VGA1] (multi-head: yes  rom: no  post: no)
[    0.803654] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20200925/psargs-330)
[    0.803689] ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[    0.803715] ACPI Error: Evaluating _BCM failed (20200925/video-357)
[    0.803762] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:15/LNXVIDEO:01/input/input0
[    0.811724] SCSI subsystem initialized
[    0.815318] ACPI: bus type USB registered
[    0.815340] usbcore: registered new interface driver usbfs
[    0.815345] usbcore: registered new interface driver hub
[    0.815367] usbcore: registered new device driver usb
[    0.817254] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[    0.817258] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[    0.817333] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[    0.823548] cryptd: max_cpu_qlen set to 1000
[    0.825132] libata version 3.00 loaded.
[    0.828108] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.828113] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    0.829047] nvme nvme0: pci function 0000:09:00.0
[    0.829238] ahci 0000:01:00.1: version 3.0
[    0.829368] ahci 0000:01:00.1: SSS flag set, parallel bus scan disabled
[    0.829403] ahci 0000:01:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0x33 impl SATA mode
[    0.829405] ahci 0000:01:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    0.829948] scsi host0: ahci
[    0.830060] scsi host1: ahci
[    0.830174] scsi host2: ahci
[    0.830260] scsi host3: ahci
[    0.830334] scsi host4: ahci
[    0.830407] scsi host5: ahci
[    0.830478] scsi host6: ahci
[    0.830553] scsi host7: ahci
[    0.830593] ata1: SATA max UDMA/133 abar m131072@0xfcd80000 port 0xfcd80100 irq 40
[    0.830594] ata2: SATA max UDMA/133 abar m131072@0xfcd80000 port 0xfcd80180 irq 40
[    0.830595] ata3: DUMMY
[    0.830596] ata4: DUMMY
[    0.830597] ata5: SATA max UDMA/133 abar m131072@0xfcd80000 port 0xfcd80300 irq 40
[    0.830599] ata6: SATA max UDMA/133 abar m131072@0xfcd80000 port 0xfcd80380 irq 40
[    0.830600] ata7: DUMMY
[    0.830600] ata8: DUMMY
[    0.830743] ahci 0000:07:00.0: SSS flag set, parallel bus scan disabled
[    0.830782] ahci 0000:07:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    0.830784] ahci 0000:07:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc
[    0.830996] scsi host8: ahci
[    0.831077] scsi host9: ahci
[    0.831117] ata9: SATA max UDMA/133 abar m512@0xfcb00000 port 0xfcb00100 irq 41
[    0.831120] ata10: SATA max UDMA/133 abar m512@0xfcb00000 port 0xfcb00180 irq 41
[    0.831240] ahci 0000:0b:00.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    0.831241] ahci 0000:0b:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    0.831366] scsi host10: ahci
[    0.831408] ata11: SATA max UDMA/133 abar m2048@0xfce01000 port 0xfce01100 irq 43
[    0.831509] ahci 0000:0b:00.1: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    0.831510] ahci 0000:0b:00.1: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part
[    0.831618] scsi host11: ahci
[    0.831662] ata12: SATA max UDMA/133 abar m2048@0xfce00000 port 0xfce00100 irq 45
[    0.832779] AVX2 version of gcm_enc/dec engaged.
[    0.832781] AES CTR mode by8 optimization enabled
[    0.839681] r8169 0000:08:00.0 eth0: RTL8168h/8111h, 70:85:c2:99:3f:f4, XID 541, IRQ 48
[    0.839684] r8169 0000:08:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[    0.847689] nvme nvme0: allocated 32 MiB host memory buffer.
[    0.849034] nvme nvme0: 16/0/0 default/read/poll queues
[    0.852351]  nvme0n1: p1 p2 p3
[    0.883425] xhci_hcd 0000:01:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000000000410
[    0.883648] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    0.883649] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.883650] usb usb1: Product: xHCI Host Controller
[    0.883650] usb usb1: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.883651] usb usb1: SerialNumber: 0000:01:00.0
[    0.883735] hub 1-0:1.0: USB hub found
[    0.883752] hub 1-0:1.0: 10 ports detected
[    0.884115] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    0.884117] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    0.884119] xhci_hcd 0000:01:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    0.884165] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.884176] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    0.884177] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.884177] usb usb2: Product: xHCI Host Controller
[    0.884178] usb usb2: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.884178] usb usb2: SerialNumber: 0000:01:00.0
[    0.884226] hub 2-0:1.0: USB hub found
[    0.884231] hub 2-0:1.0: 4 ports detected
[    0.884506] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[    0.884508] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 3
[    0.884586] xhci_hcd 0000:0a:00.3: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.884731] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    0.884732] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.884732] usb usb3: Product: xHCI Host Controller
[    0.884733] usb usb3: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.884733] usb usb3: SerialNumber: 0000:0a:00.3
[    0.884779] hub 3-0:1.0: USB hub found
[    0.884784] hub 3-0:1.0: 4 ports detected
[    0.884874] xhci_hcd 0000:0a:00.3: xHCI Host Controller
[    0.884876] xhci_hcd 0000:0a:00.3: new USB bus registered, assigned bus number 4
[    0.884877] xhci_hcd 0000:0a:00.3: Host supports USB 3.1 Enhanced SuperSpeed
[    0.884884] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.884894] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    0.884895] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.884896] usb usb4: Product: xHCI Host Controller
[    0.884896] usb usb4: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.884896] usb usb4: SerialNumber: 0000:0a:00.3
[    0.884939] hub 4-0:1.0: USB hub found
[    0.884942] hub 4-0:1.0: 2 ports detected
[    0.885027] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[    0.885029] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 5
[    0.885105] xhci_hcd 0000:0a:00.4: hcc params 0x0268ffe5 hci version 0x110 quirks 0x0000000000000410
[    0.885242] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    0.885243] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.885243] usb usb5: Product: xHCI Host Controller
[    0.885244] usb usb5: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.885244] usb usb5: SerialNumber: 0000:0a:00.4
[    0.885288] hub 5-0:1.0: USB hub found
[    0.885293] hub 5-0:1.0: 4 ports detected
[    0.885378] xhci_hcd 0000:0a:00.4: xHCI Host Controller
[    0.885380] xhci_hcd 0000:0a:00.4: new USB bus registered, assigned bus number 6
[    0.885381] xhci_hcd 0000:0a:00.4: Host supports USB 3.1 Enhanced SuperSpeed
[    0.885388] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    0.885398] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[    0.885399] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.885399] usb usb6: Product: xHCI Host Controller
[    0.885400] usb usb6: Manufacturer: Linux 5.10.0-20-amd64 xhci-hcd
[    0.885400] usb usb6: SerialNumber: 0000:0a:00.4
[    0.885455] hub 6-0:1.0: USB hub found
[    0.885459] hub 6-0:1.0: 2 ports detected
[    1.134929] usb 3-1: new low-speed USB device number 2 using xhci_hcd
[    1.134939] usb 1-6: new high-speed USB device number 2 using xhci_hcd
[    1.138927] usb 5-1: new high-speed USB device number 2 using xhci_hcd
[    1.147728] ata9: SATA link down (SStatus 0 SControl 300)
[    1.149992] ata11: SATA link down (SStatus 0 SControl 300)
[    1.150562] ata12: SATA link down (SStatus 0 SControl 300)
[    1.291252] usb 5-1: New USB device found, idVendor=04a9, idProduct=1912, bcdDevice= 1.00
[    1.291253] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.291254] usb 5-1: Product: LiDE 400
[    1.291255] usb 5-1: Manufacturer: Canon
[    1.291255] usb 5-1: SerialNumber: 48702D
[    1.306941] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    1.308074] ata1.00: ATAPI: HL-DT-ST DVDRAM GH24NSD5, LV00, max UDMA/133
[    1.309487] ata1.00: configured for UDMA/133
[    1.311687] scsi 0:0:0:0: CD-ROM            HL-DT-ST DVDRAM GH24NSD5  LV00 PQ: 0 ANSI: 5
[    1.320946] usb 3-1: New USB device found, idVendor=046a, idProduct=0180, bcdDevice= 1.03
[    1.320947] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.320948] usb 3-1: Product: wired keyboard
[    1.320949] usb 3-1: Manufacturer:
[    1.375178] usb 1-6: New USB device found, idVendor=14cd, idProduct=168a, bcdDevice= 0.01
[    1.375179] usb 1-6: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[    1.375180] usb 1-6: Product: USB Mass Storage Device
[    1.375181] usb 1-6: Manufacturer: USB Device
[    1.375182] usb 1-6: SerialNumber: 816820130806
[    1.510926] usb 1-8: new full-speed USB device number 3 using xhci_hcd
[    1.682938] tsc: Refined TSC clocksource calibration: 3699.981 MHz
[    1.682950] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6aaa87aab62, max_idle_ns: 881590664033 ns
[    1.682984] clocksource: Switched to clocksource tsc
[    1.818950] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.819442] ata2.00: ATA-10: WDC WD10EZEX-00BBHA0, 01.01A01, max UDMA/133
[    1.819443] ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    1.819975] ata2.00: configured for UDMA/133
[    1.820145] scsi 1:0:0:0: Direct-Access     ATA      WDC WD10EZEX-00B 1A01 PQ: 0 ANSI: 5
[    1.845974] usb 1-8: New USB device found, idVendor=8087, idProduct=0029, bcdDevice= 0.01
[    1.845975] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.986931] usb 1-10: new low-speed USB device number 4 using xhci_hcd
[    2.133183] ata5: SATA link down (SStatus 0 SControl 330)
[    2.309119] usb 1-10: New USB device found, idVendor=046d, idProduct=c00c, bcdDevice= 6.20
[    2.309120] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.309121] usb 1-10: Product: USB Mouse
[    2.309122] usb 1-10: Manufacturer: Logitech
[    2.606949] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    2.607438] ata6.00: ATA-10: WDC WD10EZEX-00BBHA0, 01.01A01, max UDMA/133
[    2.607439] ata6.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    2.607965] ata6.00: configured for UDMA/133
[    2.608095] scsi 5:0:0:0: Direct-Access     ATA      WDC WD10EZEX-00B 1A01 PQ: 0 ANSI: 5
[    2.921204] ata10: SATA link down (SStatus 0 SControl 300)
[    2.927629] sd 5:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.927633] sd 5:0:0:0: [sdb] 4096-byte physical blocks
[    2.927650] sd 5:0:0:0: [sdb] Write Protect is off
[    2.927655] sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    2.927656] sd 5:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.927661] sd 1:0:0:0: [sda] 4096-byte physical blocks
[    2.927675] sd 1:0:0:0: [sda] Write Protect is off
[    2.927677] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.927686] sd 5:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.927692] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.930456] sr 0:0:0:0: Attached scsi generic sg0 type 5
[    2.930490] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    2.930517] sd 5:0:0:0: Attached scsi generic sg2 type 0
[    2.931055] usb-storage 1-6:1.0: USB Mass Storage device detected
[    2.931153] scsi host12: usb-storage 1-6:1.0
[    2.931224] usbcore: registered new interface driver usb-storage
[    2.931619] hid: raw HID events driver (C) Jiri Kosina
[    2.974414] sr 0:0:0:0: [sr0] scsi3-mmc drive: 48x/12x writer dvd-ram cd/rw xa/form2 cdda tray
[    2.974418] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.983863]  sdb: sdb1
[    2.992491]  sda: sda1
[    3.019037] sd 5:0:0:0: [sdb] Attached SCSI disk
[    3.035099] sd 1:0:0:0: [sda] Attached SCSI disk
[    3.038128] usbcore: registered new interface driver uas
[    3.066966] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    3.072999] usbcore: registered new interface driver usbhid
[    3.073001] usbhid: USB HID core driver
[    3.074136] input:   wired keyboard as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb3/3-1/3-1:1.0/0003:046A:0180.0001/input/input1
[    3.134997] hid-generic 0003:046A:0180.0001: input,hidraw0: USB HID v1.11 Keyboard [  wired keyboard] on usb-0000:0a:00.3-1/input0
[    3.135113] input:   wired keyboard Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb3/3-1/3-1:1.1/0003:046A:0180.0002/input/input2
[    3.194961] input:   wired keyboard System Control as /devices/pci0000:00/0000:00:08.1/0000:0a:00.3/usb3/3-1/3-1:1.1/0003:046A:0180.0002/input/input3
[    3.194995] hid-generic 0003:046A:0180.0002: input,hidraw1: USB HID v1.11 Device [  wired keyboard] on usb-0000:0a:00.3-1/input1
[    3.195088] input: Logitech USB Mouse as /devices/pci0000:00/0000:00:02.1/0000:01:00.0/usb1/1-10/1-10:1.0/0003:046D:C00C.0003/input/input4
[    3.195145] hid-generic 0003:046D:C00C.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB Mouse] on usb-0000:01:00.0-10/input0
[    3.472836] device-mapper: uevent: version 1.0.3
[    3.472891] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[    3.957984] scsi 12:0:0:0: Direct-Access     USB Mass  Storage Device  1.00 PQ: 0 ANSI: 0
[    3.958240] sd 12:0:0:0: Attached scsi generic sg3 type 0
[    3.999522] sd 12:0:0:0: [sdc] Attached SCSI removable disk
[   12.953547] PM: Image not found (code -22)
[   13.001267] EXT4-fs (dm-1): mounted filesystem with ordered data mode. Opts: (null)
[   13.029335] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[   13.112942] udevd[670]: starting version 3.2.9
[   13.133825] udevd[671]: starting eudev-3.2.9
[   13.153864] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input5
[   13.153906] ACPI: Power Button [PWRB]
[   13.154852] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[   13.155184] acpi_cpufreq: overriding BIOS provided _PSD data
[   13.166968] ACPI: Power Button [PWRF]
[   13.185090] ccp 0000:0a:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[   13.199107] ccp 0000:0a:00.2: tee enabled
[   13.199115] ccp 0000:0a:00.2: psp enabled
[   13.231612] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[   13.231716] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[   13.231792] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[   13.231974] input: PC Speaker as /devices/platform/pcspkr/input/input7
[   13.233901] pstore: Using crash dump compression: deflate
[   13.234273] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[   13.234599] pstore: Registered efi as persistent store backend
[   13.237935] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[   13.237937] RAPL PMU: hw unit of domain package 2^-16 Joules
[   13.244097] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   13.244236] cfg80211: Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[   13.244347] cfg80211: Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[   13.244451] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   13.248260] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[   13.249636] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[   13.263527] Intel(R) Wireless WiFi driver for Linux
[   13.263599] iwlwifi 0000:06:00.0: enabling device (0000 -> 0002)
[   13.293032] iwlwifi 0000:06:00.0: firmware: direct-loading firmware iwlwifi-cc-a0-59.ucode
[   13.293047] iwlwifi 0000:06:00.0: api flags index 2 larger than supported by driver
[   13.293060] iwlwifi 0000:06:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.22
[   13.293302] iwlwifi 0000:06:00.0: loaded firmware version 59.601f3a66.0 cc-a0-59.ucode op_mode iwlmvm
[   13.293327] iwlwifi 0000:06:00.0: firmware: failed to load iwl-debug-yoyo.bin (-2)
[   13.293364] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[   13.414765] Bluetooth: Core ver 2.22
[   13.414801] NET: Registered protocol family 31
[   13.414802] Bluetooth: HCI device and connection manager initialized
[   13.414808] Bluetooth: HCI socket layer initialized
[   13.414812] Bluetooth: L2CAP socket layer initialized
[   13.414817] Bluetooth: SCO socket layer initialized
[   13.424463] kvm: Nested Virtualization enabled
[   13.424490] SVM: kvm: Nested Paging enabled
[   13.424491] SVM: Virtual VMLOAD VMSAVE supported
[   13.424491] SVM: Virtual GIF supported
[   13.446552] MCE: In-kernel MCE decoding enabled.
[   13.446789] usbcore: registered new interface driver btusb
[   13.451164] Bluetooth: hci0: Firmware revision 0.0 build 121 week 7 2021
[   13.455418] EDAC amd64: F17h_M60h detected (node 0).
[   13.455459] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.455676] [drm] amdgpu kernel modesetting enabled.
[   13.455764] Virtual CRAT table created for CPU
[   13.455774] amdgpu: Topology: Add CPU node
[   13.455950] [drm:amdgpu_pci_probe [amdgpu]] *ERROR* amdgpu requires firmware installed
[   13.455977] amdgpu: See https://wiki.debian.org/Firmware for information about missing firmware
[   13.460461] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input8
[   13.460494] input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input9
[   13.460544] input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input10
[   13.460571] input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:0a:00.1/sound/card0/input11
[   13.536149] EDAC amd64: F17h_M60h detected (node 0).
[   13.536190] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.537583] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC892: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[   13.537585] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   13.537587] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   13.537587] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   13.537588] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[   13.537588] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   13.537589] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[   13.537590] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[   13.537591] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[   13.537806] iwlwifi 0000:06:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[   13.557380] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input12
[   13.557420] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input13
[   13.557456] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input14
[   13.557529] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input15
[   13.557615] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input16
[   13.557740] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input17
[   13.557852] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:0a:00.6/sound/card1/input18
[   13.643498] EDAC amd64: F17h_M60h detected (node 0).
[   13.643538] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.711655] EDAC amd64: F17h_M60h detected (node 0).
[   13.711708] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.723356] iwlwifi 0000:06:00.0: base HW address: 7c:21:4a:8d:e3:1b
[   13.735867] thermal thermal_zone0: failed to read out thermal zone (-61)
[   13.795972] EDAC amd64: F17h_M60h detected (node 0).
[   13.796043] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.867809] EDAC amd64: F17h_M60h detected (node 0).
[   13.867871] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.915842] EDAC amd64: F17h_M60h detected (node 0).
[   13.915912] EDAC amd64: Node 0: DRAM ECC disabled.
[   13.963790] EDAC amd64: F17h_M60h detected (node 0).
[   13.963854] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.015720] EDAC amd64: F17h_M60h detected (node 0).
[   14.015784] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.063716] EDAC amd64: F17h_M60h detected (node 0).
[   14.063778] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.115677] EDAC amd64: F17h_M60h detected (node 0).
[   14.115740] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.151645] EDAC amd64: F17h_M60h detected (node 0).
[   14.151707] EDAC amd64: Node 0: DRAM ECC disabled.
[   14.269337] EXT4-fs (dm-1): re-mounted. Opts: errors=remount-ro
[   14.349302] lp: driver loaded but no devices found
[   14.353054] ppdev: user-space parallel port driver
[   14.504103] EXT4-fs (nvme0n1p2): mounting ext2 file system using the ext4 subsystem
[   14.504693] EXT4-fs (nvme0n1p2): mounted filesystem without journal. Opts: (null)
[   14.504696] ext2 filesystem being mounted at /boot supports timestamps until 2038 (0x7fffffff)
[   14.590068] EXT4-fs (sdb1): recovery complete
[   14.590074] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[   14.756280] EXT4-fs (sda1): recovery complete
[   14.776533] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   14.818939] Adding 1003516k swap on /dev/mapper/wurm--1--vg-swap_1.  Priority:-2 extents:1 across:1003516k SSFS
[   14.885054] audit: type=1400 audit(1673941684.832:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=1453 comm="apparmor_parser"
[   14.885126] audit: type=1400 audit(1673941684.832:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=1462 comm="apparmor_parser"
[   14.885201] audit: type=1400 audit(1673941684.832:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=1465 comm="apparmor_parser"
[   14.885655] audit: type=1400 audit(1673941684.832:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=1459 comm="apparmor_parser"
[   14.885723] audit: type=1400 audit(1673941684.832:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=1461 comm="apparmor_parser"
[   14.885731] audit: type=1400 audit(1673941684.832:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=1461 comm="apparmor_parser"
[   14.886168] audit: type=1400 audit(1673941684.832:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=1458 comm="apparmor_parser"
[   14.886172] audit: type=1400 audit(1673941684.832:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=1458 comm="apparmor_parser"
[   14.886173] audit: type=1400 audit(1673941684.832:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=1458 comm="apparmor_parser"
[   14.887674] audit: type=1400 audit(1673941684.836:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cups-browsed" pid=1452 comm="apparmor_parser"
[   15.396284] input: BRLTTY 6.3 Linux Screen Driver Keyboard as /devices/virtual/input/input19
[   15.404673] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input20
[   15.480169] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.480172] Bluetooth: BNEP filters: protocol multicast
[   15.480176] Bluetooth: BNEP socket layer initialized
[   15.484301] NET: Registered protocol family 38
[   15.522189] r8169 0000:08:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[   15.550952] Generic FE-GE Realtek PHY r8169-0-800:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-800:00, irq=IGNORE)
[   15.763339] r8169 0000:08:00.0 eth0: Link is Down
[   18.871784] r8169 0000:08:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   18.871802] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
... and by the way: suspend to disk does not cause problems when waking up.
Addition:
when booting I see the message:
... failed to load iwl-debug-yoyo.bin ...
... *ERROR* amdgpu requieres firmware installed ...
#6 2023-01-17 14:36:27
Re: [SOLVED] No screen after suspend2ram
Not a problem. You don't need the debug stuff. I presume your wireless card works (ie, it is listed in the output of ip link)?
And there's your problem. Without the firmware your graphics chip will probably be using the VESA driver, which will have *terrible* performance and is probably responsible for the screen blanking issue. The X.Org log will show which driver is used. I did ask to see it but hey-ho...
So
# apt install firmware-amd-graphics
Then reboot and check for the 'kernel driver in use' line in the lspci output. The amdgpu module should be used once the firmware is loaded.
#7 2023-01-17 16:47:38
jue-gen
Many thanks to Head_on_a_Stick for the support. I have always found Devuan and this forum here very friendly.
Yes, the screen is back after suspend!
My wireless card works.
It all works now and I will continue to try to optimize the system. I think now I will soon have the best Linux I have ever had. ;-)
Addendum:
But with lspci I can't find any information about 'kernel driver in use' or amdgpu.
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller (rev 01)
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01)
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
02:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
02:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
02:06.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
02:07.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
06:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
07:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
09:00.0 Non-Volatile memory controller: Sandisk Corp WD Blue SN550 NVMe SSD (rev 01)
0a:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev d9)
0a:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
0a:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
0a:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
0a:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1
0a:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
0b:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
0b:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
ip link gives this output:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether 70:85:c2:99:3f:f4 brd ff:ff:ff:ff:ff:ff
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
    link/ether 7c:21:4a:8d:e3:1b brd ff:ff:ff:ff:ff:ff
#8 2023-01-18 17:28:04
To get kernel driver info you need to use lspci -knn (pipe it into less to keep screen output searchable). See the man page for lspci.
#9 2023-01-18 20:14:47
jue-gen
Thank you.I have done it. It will look like this:
lspci -knn
00:00.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex [1022:1630]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex [1022:1630]
00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:02.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge [1022:1634]
	Kernel driver in use: pcieport
00:02.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge [1022:1634]
00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge [1022:1632]
00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus [1022:1635]
00:08.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus [1022:1635]
00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 51)
	Subsystem: ASRock Incorporation FCH SMBus Controller [1849:ffff]
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
	Subsystem: ASRock Incorporation FCH LPC Bridge [1849:ffff]
00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0 [1022:1448]
00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1 [1022:1449]
00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2 [1022:144a]
00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3 [1022:144b]
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4 [1022:144c]
00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5 [1022:144d]
00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6 [1022:144e]
00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7 [1022:144f]
01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller [1022:43d5] (rev 01)
	Subsystem: ASMedia Technology Inc. 400 Series Chipset USB 3.1 XHCI Controller [1b21:1142]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
01:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller [1022:43c8] (rev 01)
	Subsystem: ASMedia Technology Inc. 400 Series Chipset SATA Controller [1b21:1062]
	Kernel driver in use: ahci
	Kernel modules: ahci
01:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge [1022:43c6] (rev 01)
02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
02:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
02:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
02:05.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
02:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
02:07.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port [1022:43c7] (rev 01)
06:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a)
	Subsystem: Intel Corporation Wi-Fi 6 AX200 [8086:0084]
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
07:00.0 SATA controller [0106]: ASMedia Technology Inc. ASM1062 Serial ATA Controller [1b21:0612] (rev 02)
	Subsystem: ASRock Incorporation Motherboard [1849:0612]
08:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 15)
	Subsystem: ASRock Incorporation Motherboard (one of many) [1849:8168]
	Kernel driver in use: r8169
	Kernel modules: r8169
09:00.0 Non-Volatile memory controller [0108]: Sandisk Corp WD Blue SN550 NVMe SSD [15b7:5009] (rev 01)
	Subsystem: Sandisk Corp WD Blue SN550 NVMe SSD [15b7:5009]
	Kernel driver in use: nvme
	Kernel modules: nvme
0a:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636] (rev d9)
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Renoir [1002:1636]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
0a:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1637]
	Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1637]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
0a:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor [1022:15df]
	Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor [1022:15df]
	Kernel driver in use: ccp
	Kernel modules: ccp
0a:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 [1022:1639]
	Subsystem: ASRock Incorporation Renoir USB 3.1 [1849:ffff]
0a:00.4 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 [1022:1639]
0a:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
	Subsystem: ASRock Incorporation Family 17h (Models 10h-1fh) HD Audio Controller [1849:7893]
0b:00.0 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 81)
	Subsystem: ASRock Incorporation FCH SATA Controller [AHCI mode] [1849:ffff]
0b:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 81)
I do not find any error.
However, I am now actually reaching the limit of my understanding. Do you see a problem in this issue?
Tank You and best regards
#10 2023-01-18 20:29:17
Looks fine to me.
#11 2023-01-18 21:34:50
jue-gen
Looks fine to me.
I love Devuan!
