#1 2022-12-06 11:55:39
torquebar
pan2, missing 'locale'?
this MAY be an installation issue ('locale' not installed"?)
~ pan
(process:2816): Gtk-WARNING **: 06:36:15.101: Locale not supported by C library. Using the fallback 'C' locale.
GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name news.pan.NZB was not provided by any .service files
(pan:2816): Gtk-WARNING **: 06:36:15.332: Unable to parse accelerator '<constrol>O' for action 'import-tasks'
Segmentation fault
Who, has loved us more?
#2 2022-12-06 16:22:30
alexkemp
Re: pan2, missing 'locale'?
Did you copy-paste those errors? There is a syntax error in the 2nd (s/b '<control>O', or perhaps 'Ctrl-O', not '<constrol>O').
#3 2022-12-06 18:57:55
torquebar
copy/paste, did another one just to be sure:
# pan
(process:6630): Gtk-WARNING **: 13:54:15.974: Locale not supported by C library.
(pan:6630): Gtk-WARNING **: 13:54:16.102: Unable to parse accelerator '<constrol>O' for action 'import-tasks'
Segmentation fault
#4 2022-12-06 21:52:06
torquebar
here's another BTW, for Thunderbird, a bit different:
/ # thunderbird
(thunderbird-default:4015): Gtk-WARNING **: 16:49:00.902: Locale not supported by C library.
ExceptionHandler::GenerateDump cloned child 4086
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
#5 2022-12-07 15:42:24
did you try to rebuild the locales?
sudo locale-gen
It builds entries listed in /etc/locale.gen
#6 2022-12-07 17:21:53
torquebar
delgado wrote:
sudo locale-gen
# locale-gen
Generating locales (this might take a while)...
  en_US.UTF-8... done
Generation complete.
it took about 1 second :-)
then, thunderbird started without issues, pan started
also but still complaining:
# pan
(pan:3102): Gtk-WARNING **: 12:17:47.232: Unable to parse accelerator '<constrol>O' for action 'import-tasks'
(pan:3102): GLib-GObject-CRITICAL **: 12:17:47.546: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
#7 2022-12-08 07:01:48
They're just systemd & GTK SNAFUs. Is anything actually wrong with the application?
#8 2022-12-08 22:49:05
torquebar
No they both seem to work, I'll be wringing them out more on Tuesday, Devuan day :-)
My answer to EEE: Mondays I boot and update mostly Artix, on Tuesdays Devuan,
on Wednesdays Slackware, on Thursdays Leap, on Fridays Tumbleweed, on Saturdays
AvLinux and on Sundays Ubuntu-Studio.    https://i.imgur.com/iPAKNN5.png
#9 2022-12-08 23:32:55
You should try Alpine Linux. It rocks.
#10 2022-12-08 23:58:06
torquebar
is it systemd-free?
I find Ubuntu-Studio a bit of a pain but really prefer solid 'studio' distros of which I have only 2, the other one being AvLinux, another Debian derivative. The prob with US is their bloody snaps, there ARE workarounds but eventually the devs will have their way. My riggin' uses links for home folders and snaps refuses to accept such 'phoney' paths.
#11 2022-12-09 00:28:37
torquebar wrote:
is it systemd-free?
It is based on musl libc and so is fundamentally incompatible with systemd, which relies on GNU's extensions.
