#1 2022-11-22 18:06:42
[SOLVED] How is a 6700XT graphics card supposed to perform?
Just upgraded my Ryzen 9/X570 system from a 5500XT to a 6700XT graphics card, and I must say I am disappointed about the performance. Not speed itself, now I am seeing drawing artifacts.
Basics: Chimaera, Cinnamon desktop, Lightdm, Chimaera backports kernel and latest amd firmware from same backports. inxi -F shows:
Graphics:
  Device-1: AMD Navi 22 driver: amdgpu v: kernel
  Display: x11 server: X.Org v: 1.20.11 driver: X: loaded: amdgpu
    unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi gpu: amdgpu
    resolution: 2560x1440~60Hz
  API: OpenGL v: 4.6 Mesa 20.3.5 renderer: AMD NAVY_FLOUNDER (DRM 3.48.0
    6.0.0-0.deb11.2-amd64 LLVM 11.0.1)
The artifacts are different depending on the application. Firefox and Tor browser seem to work alright, haven't seen any issues. In Evolution I got some square green blocks in the menu and black ones in the footer. In others I see a pattern of square black boxes. Text display in the system protocol viewer partially is getting scrambled mainly when scrolling back up, some coloured artifacts are also present. When I move the mouse out of the window and try to make a screenshot the contents seems to be re-drawn and the problems are gone.
Prepared this thread with the text editor. Square blocks half colored half white overwrite parts of the text in the line that being edited. Again when I call up the screen capture program the artifacts go away. Addtional effects: square blocks appear in the lower part of the window. When I wait some seconds the pattern changes.
In some games I could identify transparent blocks that instead of the window background show the desktop background (proven by moving the window on the screen). Anyhow, I can't show the artifacts by taking a screen capture, as soon as the mouse activates another window the screen seems to be redrawn correctly.
It is hard to re-produce the issues. I could easily create artifacts with the system protocol viewer this morning, now as I try to prepare my screen for taking a picture with my camera, the viewer seems to be working fine.
I have swapped the two display ports on the card, no real difference. A HDMI cable to test a different route reduces the resolution, but same type of issues.
What do I need to conclude from that behaviour? Is that a defective new card? Or a driver issue, i.e. is the HW not fully supported yet? Do I need to go up to Daedalus?
I know my description is vage. I will try to put together something with gimp from my pictures. This will take a while.
Edith: picture with artifacts from different sources: 6700XT.png
This picture will be deleted within 31 days  from postimg.org
#2 2022-11-22 18:32:00
Re: [SOLVED] How is a 6700XT graphics card supposed to perform?
Can we see
glxinfo -B
dmesg|grep firmware
vulkaninfo
vainfo
VDPAU_DRIVER=radeonsi vdpauinfo
The last three commands are provided by the vulkan-tools, vainfo & vdpauinfo packages.
For that card I would try a newer kernel than 6.0.0 and a newer Mesa than 20.3.5. Upstream are on 6.0.9 & 22.2.3, respectively. Unstable has the graphics firmware from two weeks ago, which is probably recent enough, and that package can be safely installed from a .deb (it has no dependencies).
In respect of the specific problem try disabling the compositor. And check the X. Org log.
#3 2022-11-22 19:01:47
# glxinfo -B
name of display: :0
display: :0  screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: AMD (0x1002)
    Device: AMD NAVY_FLOUNDER (DRM 3.48.0, 6.0.0-0.deb11.2-amd64, LLVM 11.0.1) (0x73df)
    Version: 20.3.5
    Accelerated: yes
    Video memory: 12288MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 4.6
    Max compat profile version: 4.6
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
Memory info (GL_ATI_meminfo):
    VBO free memory - total: 11311 MB, largest block: 11311 MB
    VBO free aux. memory - total: 32031 MB, largest block: 32031 MB
    Texture free memory - total: 11311 MB, largest block: 11311 MB
    Texture free aux. memory - total: 32031 MB, largest block: 32031 MB
    Renderbuffer free memory - total: 11311 MB, largest block: 11311 MB
    Renderbuffer free aux. memory - total: 32031 MB, largest block: 32031 MB
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 12288 MB
    Total available memory: 44400 MB
    Currently available dedicated video memory: 11311 MB
OpenGL vendor string: AMD
OpenGL renderer string: AMD NAVY_FLOUNDER (DRM 3.48.0, 6.0.0-0.deb11.2-amd64, LLVM 11.0.1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.3.5
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.3.5
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.3.5
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
# dmesg|grep firmware
[    0.232156] Spectre V2 : Enabling Restricted Speculation for firmware calls
[   12.536382] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_sos.bin
[   12.536756] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_ta.bin
[   14.604015] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_smc.bin
[   14.604417] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_dmcub.bin
[   14.604420] [drm] Loading DMUB firmware via PSP: version=0x02020013
[   14.604818] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_pfp.bin
[   14.605207] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_me.bin
[   14.605523] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_ce.bin
[   14.605731] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_rlc.bin
[   14.606046] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_mec.bin
[   14.606450] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_mec2.bin
[   14.606917] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_sdma.bin
[   14.607582] amdgpu 0000:0c:00.0: firmware: direct-loading firmware amdgpu/navy_flounder_vcn.bin
[   14.607584] [drm] Found VCN firmware Version ENC: 1.24 DEC: 2 VEP: 0 Revision: 0
[   14.607590] amdgpu 0000:0c:00.0: amdgpu: Will use PSP to load VCN firmware
# vainfo
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.10.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_10
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.10 (libva 2.10.0)
vainfo: Driver version: Mesa Gallium driver 20.3.5 for AMD NAVY_FLOUNDER (DRM 3.48.0, 6.0.0-0.deb11.2-amd64, LLVM 11.0.1)
vainfo: Supported profile and entrypoints
      VAProfileMPEG2Simple            :	VAEntrypointVLD
      VAProfileMPEG2Main              :	VAEntrypointVLD
      VAProfileVC1Simple              :	VAEntrypointVLD
      VAProfileVC1Main                :	VAEntrypointVLD
      VAProfileVC1Advanced            :	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:	VAEntrypointEncSlice
      VAProfileH264Main               :	VAEntrypointVLD
      VAProfileH264Main               :	VAEntrypointEncSlice
      VAProfileH264High               :	VAEntrypointVLD
      VAProfileH264High               :	VAEntrypointEncSlice
      VAProfileHEVCMain               :	VAEntrypointVLD
      VAProfileHEVCMain               :	VAEntrypointEncSlice
      VAProfileHEVCMain10             :	VAEntrypointVLD
      VAProfileHEVCMain10             :	VAEntrypointEncSlice
      VAProfileJPEGBaseline           :	VAEntrypointVLD
      VAProfileVP9Profile0            :	VAEntrypointVLD
      VAProfileVP9Profile2            :	VAEntrypointVLD
      VAProfileNone                   :	VAEntrypointVideoProc
# VDPAU_DRIVER=radeonsi vdpauinfo
API version: 1
Information string: G3DVL VDPAU Driver Shared Library version 1.0
Video surface:
name   width height types
420    16384 16384  NV12 YV12
422    16384 16384  UYVY YUYV
444    16384 16384  Y8U8V8A8 V8U8Y8A8
420_16 16384 16384
422_16 16384 16384
444_16 16384 16384
Decoder capabilities:
name                        level macbs width height
MPEG1                          --- not supported ---
MPEG2_SIMPLE                    3 65536  4096  4096
MPEG2_MAIN                      3 65536  4096  4096
H264_BASELINE                  52 65536  4096  4096
H264_MAIN                      52 65536  4096  4096
H264_HIGH                      52 65536  4096  4096
VC1_SIMPLE                      1 65536  4096  4096
VC1_MAIN                        2 65536  4096  4096
VC1_ADVANCED                    4 65536  4096  4096
MPEG4_PART2_SP                  3 65536  4096  4096
MPEG4_PART2_ASP                 5 65536  4096  4096
DIVX4_QMOBILE                  --- not supported ---
DIVX4_MOBILE                   --- not supported ---
DIVX4_HOME_THEATER             --- not supported ---
DIVX4_HD_1080P                 --- not supported ---
DIVX5_QMOBILE                  --- not supported ---
DIVX5_MOBILE                   --- not supported ---
DIVX5_HOME_THEATER             --- not supported ---
DIVX5_HD_1080P                 --- not supported ---
H264_CONSTRAINED_BASELINE       0 65536  4096  4096
H264_EXTENDED                  --- not supported ---
H264_PROGRESSIVE_HIGH          --- not supported ---
H264_CONSTRAINED_HIGH          --- not supported ---
H264_HIGH_444_PREDICTIVE       --- not supported ---
VP9_PROFILE_0                  --- not supported ---
VP9_PROFILE_1                  --- not supported ---
VP9_PROFILE_2                  --- not supported ---
VP9_PROFILE_3                  --- not supported ---
HEVC_MAIN                      186 139264  8192  4352
HEVC_MAIN_10                   186 139264  8192  4352
HEVC_MAIN_STILL                --- not supported ---
HEVC_MAIN_12                   --- not supported ---
HEVC_MAIN_444                  --- not supported ---
HEVC_MAIN_444_10               --- not supported ---
HEVC_MAIN_444_12               --- not supported ---
Output surface:
name              width height nat types
B8G8R8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 A8I8 I8A8
R8G8B8A8         16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 A8I8 I8A8
R10G10B10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 A8I8 I8A8
B10G10R10A2      16384 16384    y  NV12 YV12 UYVY YUYV Y8U8V8A8 V8U8Y8A8 P010 P016 A8I8 I8A8
Bitmap surface:
name              width height
A8               16384 16384
Video mixer:
feature name                    sup
DEINTERLACE_TEMPORAL             y
DEINTERLACE_TEMPORAL_SPATIAL     -
INVERSE_TELECINE                 -
NOISE_REDUCTION                  y
SHARPNESS                        y
LUMA_KEY                         y
HIGH QUALITY SCALING - L1        y
HIGH QUALITY SCALING - L2        -
HIGH QUALITY SCALING - L3        -
HIGH QUALITY SCALING - L4        -
HIGH QUALITY SCALING - L5        -
HIGH QUALITY SCALING - L6        -
HIGH QUALITY SCALING - L7        -
HIGH QUALITY SCALING - L8        -
HIGH QUALITY SCALING - L9        -
parameter name                  sup      min      max
VIDEO_SURFACE_WIDTH              y        48     4096
VIDEO_SURFACE_HEIGHT             y        48     4096
CHROMA_TYPE                      y
LAYERS                           y         0        4
attribute name                  sup      min      max
BACKGROUND_COLOR                 y
CSC_MATRIX                       y
NOISE_REDUCTION_LEVEL            y      0.00     1.00
SHARPNESS_LEVEL                  y     -1.00     1.00
LUMA_KEY_MIN_LUMA                y
LUMA_KEY_MAX_LUMA                y
# vulkaninfo
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/x86_64-linux-gnu/libvulkan_intel.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/x86_64-linux-gnu/libvulkan_radeon.so supports Vulkan 1.2, but only supports loader interface version 4. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
WARNING: [Loader Message] Code 0 : loader_scanned_icd_add: Driver /usr/lib/x86_64-linux-gnu/libvulkan_lvp.so supports Vulkan 1.1, but only supports loader interface version 1. Interface version 5 or newer required to support this version of Vulkan (Policy #LDP_DRIVER_7)
WARNING: [Loader Message] Code 0 : terminator_CreateInstance: Driver /usr/lib/x86_64-linux-gnu/libvulkan_lvp.so supports interface version 1 but still exposes VkSurfaceKHR create/destroy entrypoints (Policy #LDP_DRIVER_8)
WARNING: radv is not a conformant vulkan implementation, testing use only.
WARNING: lavapipe is not a conformant vulkan implementation, testing use only.
VULKANINFO
Vulkan Instance Version: 1.3.224
Instance Extensions: count = 19
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 8
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 1
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_portability_enumeration         : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 2
VK_LAYER_MESA_device_select (Linux device selection layer) Vulkan version 1.2.73, layer version 1:
	Layer Extensions: count = 0
	Devices: count = 2
		GPU id = 0 (AMD RADV NAVY_FLOUNDER (ACO))
		Layer-Device Extensions: count = 0
		GPU id = 1 (llvmpipe (LLVM 11.0.1, 256 bits))
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.1.73, layer version 1:
	Devices: count = 2
Presentable Surfaces:
GPU id : 0 (AMD RADV NAVY_FLOUNDER (ACO)):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_SRGB
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_UNORM
	Present Modes: count = 4
		PRESENT_MODE_IMMEDIATE_KHR
		PRESENT_MODE_MAILBOX_KHR
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount       = 3
		maxImageCount       = 0
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform    = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 2
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
			COMPOSITE_ALPHA_INHERIT_BIT_KHR
		supportedUsageFlags: count = 5
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters: count = 0
			None
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
GPU id : 1 (llvmpipe (LLVM 11.0.1, 256 bits)):
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
		SurfaceFormat[1]:
		minImageCount       = 3
		maxImageCount       = 0
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
			None
Device Groups:
Group 0:
	Properties:
		physicalDevices: count = 1
			AMD RADV NAVY_FLOUNDER (ACO) (ID: 0)
		subsetAllocation = 0
	Present Capabilities:
		AMD RADV NAVY_FLOUNDER (ACO) (ID: 0):
			Can present images from the following devices: count = 1
		Present modes: count = 1
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Group 1:
	Properties:
			llvmpipe (LLVM 11.0.1, 256 bits) (ID: 0)
	Present Capabilities = Group does not support VK_KHR_device_group, skipping printing present capabilities
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion     = 4202641 (1.2.145)
	driverVersion  = 83898373 (0x5003005)
	vendorID       = 0x1002
	deviceID       = 0x73df
	deviceType     = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
	deviceName     = AMD RADV NAVY_FLOUNDER (ACO)
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 16384
	maxImageDimension2D                             = 16384
	maxImageDimension3D                             = 2048
	maxImageDimensionCube                           = 16384
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 4294967295
	maxUniformBufferRange                           = 4294967295
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 128
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 65536
	bufferImageGranularity                          = 0x00000040
	sparseAddressSpaceSize                          = 0xfffffffc
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 8388606
	maxPerStageDescriptorUniformBuffers             = 8388606
	maxPerStageDescriptorStorageBuffers             = 8388606
	maxPerStageDescriptorSampledImages              = 8388606
	maxPerStageDescriptorStorageImages              = 8388606
	maxPerStageDescriptorInputAttachments           = 8388606
	maxPerStageResources                            = 8388606
	maxDescriptorSetSamplers                        = 8388606
	maxDescriptorSetUniformBuffers                  = 8388606
	maxDescriptorSetUniformBuffersDynamic           = 16
	maxDescriptorSetStorageBuffers                  = 8388606
	maxDescriptorSetStorageBuffersDynamic           = 8
	maxDescriptorSetSampledImages                   = 8388606
	maxDescriptorSetStorageImages                   = 8388606
	maxDescriptorSetInputAttachments                = 8388606
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 2047
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4096
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 127
	maxGeometryInputComponents                      = 64
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 256
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 8
	maxComputeSharedMemorySize                      = 32768
	maxComputeWorkGroupCount: count = 3
		65535
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		1024
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 16
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		16384
		16384
	viewportBoundsRange: count = 2
		-32768
		32767
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 4096
	minTexelBufferOffsetAlignment                   = 0x00000004
	minUniformBufferOffsetAlignment                 = 0x00000004
	minStorageBufferOffsetAlignment                 = 0x00000004
	minTexelOffset                                  = -32
	maxTexelOffset                                  = 31
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -2
	maxInterpolationOffset                          = 2
	subPixelInterpolationOffsetBits                 = 8
	maxFramebufferWidth                             = 16384
	maxFramebufferHeight                            = 16384
	maxFramebufferLayers                            = 1024
	framebufferColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferNoAttachmentsSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	storageImageSampleCounts: count = 4
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 10
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		0
		8191.88
	lineWidthRange: count = 2
		0
		8191.88
	pointSizeGranularity                            = 0.125
	lineWidthGranularity                            = 0.125
	strictLines                                     = false
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000080
	optimalBufferCopyRowPitchAlignment              = 0x00000080
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = false
	residencyStandard2DMultisampleBlockShape = false
	residencyStandard3DBlockShape            = false
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = false
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0
	maxExtraPrimitiveOverestimationSize         = 0
	extraPrimitiveOverestimationSizeGranularity = 0
	primitiveUnderestimation                    = false
	conservativePointAndLineRasterization       = false
	degenerateTrianglesRasterized               = false
	degenerateLinesRasterized                   = false
	fullyCoveredFragmentShaderInputVariable     = false
	conservativeRasterizationPostDepthCoverage  = false
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
	maxCustomBorderColorSamplers = 4096
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 3
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 67108863
	shaderUniformBufferArrayNonUniformIndexingNative     = false
	shaderSampledImageArrayNonUniformIndexingNative      = false
	shaderStorageBufferArrayNonUniformIndexingNative     = false
	shaderStorageImageArrayNonUniformIndexingNative      = false
	shaderInputAttachmentArrayNonUniformIndexingNative   = false
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 8388606
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 8388606
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 8388606
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 8388606
	maxPerStageUpdateAfterBindResources                  = 8388606
	maxDescriptorSetUpdateAfterBindSamplers              = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 8388606
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindSampledImages         = 8388606
	maxDescriptorSetUpdateAfterBindStorageImages         = 8388606
	maxDescriptorSetUpdateAfterBindInputAttachments      = 8388606
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 4
VkPhysicalDeviceDriverProperties:
	driverID           = DRIVER_ID_MESA_RADV
	driverName         = radv
	driverInfo         = Mesa 20.3.5 (ACO)
	conformanceVersion = 1.2.3.0
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_32_BIT_ONLY
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = true
	shaderDenormPreserveFloat64           = true
	shaderDenormFlushToZeroFloat16        = true
	shaderDenormFlushToZeroFloat32        = true
	shaderDenormFlushToZeroFloat64        = true
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = true
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 00000000-0c00-0000-0000-000000000000
	driverUUID      = 414d442d-4d45-5341-2d44-525600000000
	deviceNodeMask  = 0
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 4194304
	maxPerStageDescriptorInlineUniformBlocks                = 134217728
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 134217728
	maxDescriptorSetInlineUniformBlocks                     = 64
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 64
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 22369621
	maxMemoryAllocationSize = 0xfffffffc
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 8
	maxMultiviewInstanceIndex = 2147483647
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 12
	pciDevice   = 0
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_ALL_CLIP_PLANES
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000004
	robustUniformBufferAccessSizeAlignment = 0x00000004
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 64
	supportedStages: count = 8
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
	supportedOperations: count = 8
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 32
	maxSubgroupSize              = 64
	maxComputeWorkgroupSubgroups = 4294967295
	requiredSubgroupSizeStages: count = 2
		SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000004
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000004
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffff
	maxTransformFeedbackStreamDataSize         = 512
	maxTransformFeedbackBufferDataSize         = 4294967295
	maxTransformFeedbackBufferDataStride       = 512
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = true
	transformFeedbackRasterizationStreamSelect = false
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 0
	subgroupSize                      = 64
	subgroupSupportedStages: count = 8
		SHADER_STAGE_ALL
	subgroupSupportedOperations: count = 8
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	driverName                                           = radv
	framebufferIntegerColorSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
Device Extensions: count = 112
	VK_AMD_buffer_marker                      : extension revision 1
	VK_AMD_device_coherent_memory             : extension revision 1
	VK_AMD_draw_indirect_count                : extension revision 2
	VK_AMD_gcn_shader                         : extension revision 1
	VK_AMD_gpu_shader_half_float              : extension revision 2
	VK_AMD_gpu_shader_int16                   : extension revision 2
	VK_AMD_memory_overallocation_behavior     : extension revision 1
	VK_AMD_mixed_attachment_samples           : extension revision 1
	VK_AMD_shader_ballot                      : extension revision 1
	VK_AMD_shader_core_properties             : extension revision 2
	VK_AMD_shader_core_properties2            : extension revision 1
	VK_AMD_shader_explicit_vertex_parameter   : extension revision 1
	VK_AMD_shader_fragment_mask               : extension revision 1
	VK_AMD_shader_image_load_store_lod        : extension revision 1
	VK_AMD_shader_info                        : extension revision 1
	VK_AMD_shader_trinary_minmax              : extension revision 1
	VK_AMD_texture_gather_bias_lod            : extension revision 1
	VK_EXT_4444_formats                       : extension revision 1
	VK_EXT_buffer_device_address              : extension revision 2
	VK_EXT_calibrated_timestamps              : extension revision 1
	VK_EXT_conditional_rendering              : extension revision 2
	VK_EXT_conservative_rasterization         : extension revision 1
	VK_EXT_custom_border_color                : extension revision 12
	VK_EXT_depth_clip_enable                  : extension revision 1
	VK_EXT_depth_range_unrestricted           : extension revision 1
	VK_EXT_descriptor_indexing                : extension revision 2
	VK_EXT_discard_rectangles                 : extension revision 1
	VK_EXT_display_control                    : extension revision 1
	VK_EXT_extended_dynamic_state             : extension revision 1
	VK_EXT_external_memory_dma_buf            : extension revision 1
	VK_EXT_external_memory_host               : extension revision 1
	VK_EXT_global_priority                    : extension revision 2
	VK_EXT_host_query_reset                   : extension revision 1
	VK_EXT_image_robustness                   : extension revision 1
	VK_EXT_index_type_uint8                   : extension revision 1
	VK_EXT_inline_uniform_block               : extension revision 1
	VK_EXT_line_rasterization                 : extension revision 1
	VK_EXT_memory_budget                      : extension revision 1
	VK_EXT_memory_priority                    : extension revision 1
	VK_EXT_pci_bus_info                       : extension revision 2
	VK_EXT_pipeline_creation_cache_control    : extension revision 3
	VK_EXT_pipeline_creation_feedback         : extension revision 1
	VK_EXT_post_depth_coverage                : extension revision 1
	VK_EXT_private_data                       : extension revision 1
	VK_EXT_queue_family_foreign               : extension revision 1
	VK_EXT_robustness2                        : extension revision 1
	VK_EXT_sampler_filter_minmax              : extension revision 2
	VK_EXT_scalar_block_layout                : extension revision 1
	VK_EXT_shader_atomic_float                : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation : extension revision 1
	VK_EXT_shader_image_atomic_int64          : extension revision 1
	VK_EXT_shader_stencil_export              : extension revision 1
	VK_EXT_shader_subgroup_ballot             : extension revision 1
	VK_EXT_shader_subgroup_vote               : extension revision 1
	VK_EXT_shader_viewport_index_layer        : extension revision 1
	VK_EXT_subgroup_size_control              : extension revision 2
	VK_EXT_texel_buffer_alignment             : extension revision 1
	VK_EXT_transform_feedback                 : extension revision 1
	VK_EXT_vertex_attribute_divisor           : extension revision 3
	VK_EXT_ycbcr_image_arrays                 : extension revision 1
	VK_GOOGLE_decorate_string                 : extension revision 1
	VK_GOOGLE_hlsl_functionality1             : extension revision 1
	VK_GOOGLE_user_type                       : extension revision 1
	VK_KHR_16bit_storage                      : extension revision 1
	VK_KHR_8bit_storage                       : extension revision 1
	VK_KHR_bind_memory2                       : extension revision 1
	VK_KHR_buffer_device_address              : extension revision 1
	VK_KHR_copy_commands2                     : extension revision 1
	VK_KHR_create_renderpass2                 : extension revision 1
	VK_KHR_dedicated_allocation               : extension revision 3
	VK_KHR_depth_stencil_resolve              : extension revision 1
	VK_KHR_descriptor_update_template         : extension revision 1
	VK_KHR_device_group                       : extension revision 4
	VK_KHR_draw_indirect_count                : extension revision 1
	VK_KHR_driver_properties                  : extension revision 1
	VK_KHR_external_fence                     : extension revision 1
	VK_KHR_external_fence_fd                  : extension revision 1
	VK_KHR_external_memory                    : extension revision 1
	VK_KHR_external_memory_fd                 : extension revision 1
	VK_KHR_external_semaphore                 : extension revision 1
	VK_KHR_external_semaphore_fd              : extension revision 1
	VK_KHR_get_memory_requirements2           : extension revision 1
	VK_KHR_image_format_list                  : extension revision 1
	VK_KHR_imageless_framebuffer              : extension revision 1
	VK_KHR_incremental_present                : extension revision 1
	VK_KHR_maintenance1                       : extension revision 2
	VK_KHR_maintenance2                       : extension revision 1
	VK_KHR_maintenance3                       : extension revision 1
	VK_KHR_multiview                          : extension revision 1
	VK_KHR_pipeline_executable_properties     : extension revision 1
	VK_KHR_push_descriptor                    : extension revision 2
	VK_KHR_relaxed_block_layout               : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge       : extension revision 3
	VK_KHR_sampler_ycbcr_conversion           : extension revision 14
	VK_KHR_separate_depth_stencil_layouts     : extension revision 1
	VK_KHR_shader_atomic_int64                : extension revision 1
	VK_KHR_shader_clock                       : extension revision 1
	VK_KHR_shader_draw_parameters             : extension revision 1
	VK_KHR_shader_float16_int8                : extension revision 1
	VK_KHR_shader_float_controls              : extension revision 4
	VK_KHR_shader_non_semantic_info           : extension revision 1
	VK_KHR_shader_subgroup_extended_types     : extension revision 1
	VK_KHR_shader_terminate_invocation        : extension revision 1
	VK_KHR_spirv_1_4                          : extension revision 1
	VK_KHR_storage_buffer_storage_class       : extension revision 1
	VK_KHR_swapchain                          : extension revision 70
	VK_KHR_swapchain_mutable_format           : extension revision 1
	VK_KHR_timeline_semaphore                 : extension revision 2
	VK_KHR_uniform_buffer_standard_layout     : extension revision 1
	VK_KHR_variable_pointers                  : extension revision 1
	VK_KHR_vulkan_memory_model                : extension revision 3
	VK_NV_compute_shader_derivatives          : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 1
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		timestampValidBits          = 64
		present support             = true
	queueProperties[1]:
		queueCount                  = 4
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
	memoryHeaps[0]:
		size   = 12616466432 (0x2f0000000) (11.75 GiB)
		budget = 11591921664 (0x2b2eeb000) (10.80 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
	memoryHeaps[1]:
		size   = 33671931904 (0x7d700e800) (31.36 GiB)
		budget = 33592444928 (0x7d2440800) (31.29 GiB)
		flags: count = 0
			None
	memoryHeaps[2]:
		size   = 268435456 (0x10000000) (256.00 MiB)
		budget = 32333824 (0x01ed6000) (30.84 MiB)
		flags: count = 1
memoryTypes: count = 8
	memoryTypes[0]:
		heapIndex     = 0
		propertyFlags = 0x0001: count = 1
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
			IMAGE_TILING_OPTIMAL:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D16_UNORM_S8_UINT
				FORMAT_D32_SFLOAT_S8_UINT
				(non-sparse)
			IMAGE_TILING_LINEAR:
				color images
				(non-sparse)
	memoryTypes[1]:
		heapIndex     = 1
		propertyFlags = 0x0006: count = 2
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[2]:
		heapIndex     = 2
		propertyFlags = 0x0007: count = 3
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[3]:
		heapIndex     = 1
		propertyFlags = 0x000e: count = 3
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[4]:
		heapIndex     = 0
		propertyFlags = 0x00c1: count = 3
			MEMORY_PROPERTY_DEVICE_COHERENT_BIT_AMD
			MEMORY_PROPERTY_DEVICE_UNCACHED_BIT_AMD
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[5]:
		heapIndex     = 1
		propertyFlags = 0x00c6: count = 4
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[6]:
		heapIndex     = 2
		propertyFlags = 0x00c7: count = 5
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	memoryTypes[7]:
		heapIndex     = 1
		propertyFlags = 0x00ce: count = 5
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = false
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = false
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = false
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = false
	sparseResidencyImage2D                  = false
	sparseResidencyImage3D                  = false
	sparseResidency2Samples                 = false
	sparseResidency4Samples                 = false
	sparseResidency8Samples                 = false
	sparseResidency16Samples                = false
	sparseResidencyAliased                  = false
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = true
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = true
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = false
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = false
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
	customBorderColors             = true
	customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImageRobustnessFeaturesEXT:
	robustImageAccess = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = false
	bresenhamLines           = true
	smoothLines              = false
	stippledRectangularLines = false
	stippledBresenhamLines   = true
	stippledSmoothLines      = false
VkPhysicalDeviceMemoryPriorityFeaturesEXT:
	memoryPriority = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = false
	shaderBufferFloat64Atomics   = true
	shaderBufferFloat64AtomicAdd = false
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = true
	shaderSharedFloat64Atomics   = true
	shaderSharedFloat64AtomicAdd = false
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = false
	sparseImageFloat32Atomics    = false
	sparseImageFloat32AtomicAdd  = false
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderImageAtomicInt64FeaturesEXT:
	shaderImageInt64Atomics = true
	sparseImageInt64Atomics = false
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = false
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
GPU1:
	apiVersion     = 4194306 (1.0.2)
	driverVersion  = 1 (0x0001)
	vendorID       = 0x10005
	deviceID       = 0x0000
	deviceType     = PHYSICAL_DEVICE_TYPE_CPU
	deviceName     = llvmpipe (LLVM 11.0.1, 256 bits)
	maxImageDimension3D                             = 4096
	maxImageDimensionCube                           = 32768
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 65536
	maxStorageBufferRange                           = 134217728
	maxMemoryAllocationCount                        = 4096
	maxSamplerAllocationCount                       = 32768
	sparseAddressSpaceSize                          = 0x00000000
	maxBoundDescriptorSets                          = 8
	maxPerStageDescriptorSamplers                   = 32
	maxPerStageDescriptorUniformBuffers             = 16
	maxPerStageDescriptorStorageBuffers             = 16
	maxPerStageDescriptorSampledImages              = 128
	maxPerStageDescriptorStorageImages              = 128
	maxPerStageResources                            = 128
	maxDescriptorSetSamplers                        = 32768
	maxDescriptorSetUniformBuffers                  = 256
	maxDescriptorSetUniformBuffersDynamic           = 256
	maxDescriptorSetStorageBuffers                  = 256
	maxDescriptorSetStorageBuffersDynamic           = 256
	maxDescriptorSetSampledImages                   = 256
	maxDescriptorSetStorageImages                   = 256
	maxDescriptorSetInputAttachments                = 256
	maxTessellationControlPerPatchOutputComponents  = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryOutputVertices                       = 1024
	maxFragmentDualSrcAttachments                   = 2
		65535
		65535
		65535
		1024
		1024
		1024
	maxViewports                                    = 16
		16384
		16384
		-32768
		32768
	viewportSubPixelBits                            = 0
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000010
	minStorageBufferOffsetAlignment                 = 0x00000010
	maxTexelOffset                                  = 31
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferDepthSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferStencilSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	framebufferNoAttachmentsSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageColorSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageIntegerSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageDepthSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	sampledImageStencilSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	storageImageSampleCounts: count = 2
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
	timestampPeriod                                 = 1
		0
		255
		1
		1
	strictLines                                     = false
VkPhysicalDeviceDriverPropertiesKHR:
	driverID           = DRIVER_ID_MESA_LLVMPIPE
	driverName         = llvmpipe
	driverInfo         = Mesa 20.3.5 (LLVM 11.0.1)
	conformanceVersion = 1.0.0.0
VkPhysicalDeviceIDPropertiesKHR:
	deviceUUID      = 00000000-0000-0000-0000-000000000000
	driverUUID      = 00000000-0000-0000-0000-000000000000
	deviceNodeMask  = 0
Device Extensions: count = 14
	VK_KHR_dedicated_allocation         : extension revision 1
	VK_KHR_maintenance1                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge : extension revision 1
	VK_KHR_swapchain                    : extension revision 68
	queueProperties[0]:
		queueCount                  = 1
memoryHeaps: count = 1
	memoryHeaps[0]:
		size   = 2147483648 (0x80000000) (2.00 GiB)
		budget = 0 (0x00000000) (0.00 B)
		flags: count = 1
memoryTypes: count = 1
	memoryTypes[0]:
		heapIndex     = 0
		propertyFlags = 0x000f: count = 4
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_X8_D24_UNORM_PACK32
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D24_UNORM_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
	dualSrcBlend                            = true
	logicOp                                 = true
	depthClamp                              = true
	depthBounds                             = false
	wideLines                               = false
	largePoints                             = true
	alphaToOne                              = true
	samplerAnisotropy                       = false
	shaderStorageImageExtendedFormats       = false
	shaderStorageImageReadWithoutFormat     = false
	shaderUniformBufferArrayDynamicIndexing = false
	shaderSampledImageArrayDynamicIndexing  = false
	shaderStorageBufferArrayDynamicIndexing = false
	shaderStorageImageArrayDynamicIndexing  = false
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceMinLod                    = false
	sparseBinding                           = false
	variableMultisampleRate                 = false
	inheritedQueries                        = false
	privateData = true
#4 2022-11-22 19:09:35
The X.org log is also quite long. I checked for EE entries, there are none. Just a few WW entries about a missing cyrrilic directory and other of that sort.
How do I disable the compositor? I am using a default Cinnamon installation.
BTW: is there a howto how to post an image?
#5 2022-11-22 19:20:16
Nice card :-)
I should have asked for vulkaninfo --summary but nevermind. Looks like VA-API, VDPAU-API, Vulkan & OpenGL are all supported.
Looks like Cinnamon might not have such an option. How silly. Do you see the artefacts with, for example, plain openbox?
Upload the image to https://postimages.org/ and paste the "thumbnail for forums" URL here.
#6 2022-11-22 21:03:37
Openbox isn't installed, never used it.
#7 2022-11-25 14:35:10
I have added a Daedalus installation in parallel to the older stuff with Cinnamon as DE. Looks like this is working perfectly, the artifacts seen under Chimaera are gone.
