#1 2022-11-09 22:20:31
deepforest
Thunar not show all devices on left panel
Devuan Ceres
After last update. Thunar not show all devices on left panel. Before update i see all my drives on left panel now not, even mounted. Why?
screenshot
https://imgur.com/a/9cVpii1
smile
#2 2022-11-10 07:05:17
Re: Thunar not show all devices on left panel
Can we see
cat /etc/fstab
findmnt
Thanks!
#3 2022-11-10 16:11:19
entropyagent
findmnt
Slightly off-topic, but: Wow...How did I go so many years without knowing about this cool tool? Thanks.
#4 2022-11-10 17:56:18
Yeah, it's hellauseful in scripts — for example, get the UUID of the root partition with findmnt -no uuid /.
#5 2022-11-10 18:30:09
deepforest
Can we see
cat /etc/fstab
findmnt
Thanks!
Thanks! Weird, but today all drives is shown. I am do not nothing.
https://imgur.com/a/U9uQrk5
Here output.
freeartist@devuan:~$ cat /etc/fstab
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# systemd generates mount units based on this file, see systemd.mount(5).
# Please run 'systemctl daemon-reload' after making changes here.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/sdb3 during installation
UUID=b719b471-3b3a-4eda-8fd4-0e5406bf9906 /               ext4    errors=remount-ro 0       1
# swap was on /dev/sdb2 during installation
UUID=5755abdb-a2a3-4387-9469-a23778127f40 none            swap    sw              0       0
# swap was on /dev/sdc2 during installation
#UUID=fbf32798-7cc2-4ffd-8b77-8bd2934d0f6a none            swap    sw              0       0
freeartist@devuan:~$ findmnt
TARGET                    SOURCE     FSTYPE          OPTIONS
/                         /dev/sda3  ext4            rw,relatime,errors=remount-ro
├─/sys                    sysfs      sysfs           rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/security  securityfs securityfs      rw,relatime
│ ├─/sys/fs/pstore        pstore     pstore          rw,relatime
│ └─/sys/fs/cgroup        cgroup2    cgroup2         rw,nosuid,nodev,noexec,relatime,nsdelegate
├─/proc                   proc       proc            rw,nosuid,nodev,noexec,relatime
├─/dev                    udev       devtmpfs        rw,nosuid,relatime,size=1991116k,nr_inodes=497779,mode=755,inode64
│ ├─/dev/pts              devpts     devpts          rw,nosuid,noexec,relatime,gid=5,mode=600,ptmxmode=000
│ └─/dev/shm              tmpfs      tmpfs           rw,nosuid,nodev,noexec,relatime,size=1643280k,inode64
└─/run                    tmpfs      tmpfs           rw,nosuid,nodev,noexec,relatime,size=402220k,mode=755,inode64
  ├─/run/lock             tmpfs      tmpfs           rw,nosuid,nodev,noexec,relatime,size=5120k,inode64
  └─/run/user/1000        tmpfs      tmpfs           rw,nosuid,nodev,relatime,size=402216k,nr_inodes=100554,mode=700,uid=1000,gid=1000,inode64
    ├─/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    └─/run/user/1000/doc  portal     fuse.portal     rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
smile
#6 2022-11-12 01:45:29
deepforest
huh, its happens again( after boot i don't see devices at left in Thunar
root@devuan:/home/freeartist/Downloads# findmnt
/                         /dev/sdc3  ext4            rw,relatime,errors=remount-ro
smile
#7 2022-11-12 09:01:40
When the devices are missing does thunar show any error messages when started from a terminal? How about the X.Org log?
#8 2022-11-12 17:20:31
deepforest
I usually am starting Thunar not from terminal, so cant say. Today is good again. If it happened next time i am try your suggestion.
And what i must look at xorg log than it happened?
smile
#9 2022-12-01 00:31:07
deepforest
Again same happens, no devices after booting
no any errors if start Thunar from console
Xorg log https://pastebin.com/jnQ5STTp
smile
#10 2022-12-08 02:49:41
deepforest
debugging info
freeartist@devuan:~$ thunar -q; thunar .
(thunar:5638): GVFS-RemoteVolumeMonitor-WARNING **: 04:48:14.363: remote volume monitor with dbus name org.gtk.vfs.UDisks2VolumeMonitor is not supported
How to fix that?
similar issue
https://bugzilla.redhat.com/show_bug.cgi?id=1585066
syslog
2022-12-08T04:48:01.747635+02:00 devuan dbus-daemon[5510]: [session uid=0 pid=5508] Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
smile
