#1 2022-11-03 14:41:36
thierrybo
Nvidia drivers : No login console updating 470 to 510.85.2
I post this just to know if someone have any clue what is going on.
I use Devuan testing with no Display Manager. I boot in console mode then "startx". I use Debian official "nvidia-driver" since several years now. I use two monitors.
This week "nvidia-driver" updated from 470 to 510 version. After the Nvidia driver update, i can't see the login console. I mean I see the detailed boot process after Grub screen, but at the moment the login prompt should appear, the screen goes in suspend mode. So there is no "X" involved yet.
If I blindly enter my username/password and "startx", I can enter on my X desktop normally. From there i can logout and return to my tty login console normally.  If I plug only any one monitor, the console login screen is displayed normally. But in this case, if I plug the second monitor, both instantly goes in sleep mode. I tried to change the cable connection (DVI/DP/HDMI) with no change. Switching to Nouveau I do not have this issue.
I tried to record this on my phone (sorry for the poor quality)
#2 2022-11-17 20:44:55
ajw99uk
Re: Nvidia drivers : No login console updating 470 to 510.85.2
If the machine has on-board graphics output, what happens if you connect one monitor to that? Have you tried / can you try with different BIOS settings to select onboard/discrete graphics?
I used to find that updates to the Nvidia drivers would take a couple of reboots to sort themselves out, and in the meantime only the onboard output was OK. But if you can get X ok, there's something more persistent going on ...
#3 2022-11-17 22:21:00
thierrybo wrote:
... boot in console mode then "startx".
... no "X" involved yet.
The first thing I'd do would be to check the logs.
/var/log/Xorg.0.log in particular.
I use a pair of older nvidia cards (Quadro FX580) with three monitors and legacy 340.108 drivers from nvidia.
Although it is supposed to be able to work without it, I have never been able to do it without a properly configured xorg.conf.
To the extent of using the same xorg.conf for the last seven years or so and over three different distributions.
With Devuan since 2017.
#4 2022-11-19 11:54:16
thierrybo
Thanks, I have no discrete/onboard graphics to test, only an "Nvidia GTX 1060 3GB" card.
I have no error in /var/log/Xorg.0.log. Honestly this is just annoying so I gave up searching about it. It will be annoying the day X does not load but in this case I just have to unplug one of the monitors.
[    46.279]
X.Org X Server 1.21.1.4
[    46.279] Current Operating System: Linux thierrybo-desk 6.0.0-4-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.0.8-1 (2022-11-11) x86_64
[    46.279] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.0.0-4-amd64 root=UUID=d1c7d15d-3d38-4d78-8825-4151f05bd639 ro quiet mitigations=off
[    46.280] xorg-server 2:21.1.4-2 (https://www.debian.org/support)
[    46.280] Current version of pixman: 0.42.2
[    46.280] 	Before reporting problems, check http://wiki.x.org
[    46.281] Markers: (--) probed, (**) from config file, (==) default setting,
[    46.282] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 19 12:31:07 2022
[    46.283] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    46.283] (==) No Layout section.  Using the first Screen section.
[    46.283] (==) No screen section available. Using defaults.
[    46.283] (**) |-->Screen "Default Screen Section" (0)
[    46.283] (**) |   |-->Monitor "<default monitor>"
[    46.284] (==) No monitor specified for screen "Default Screen Section".
[    46.284] (==) Automatically adding devices
[    46.284] (==) Automatically enabling devices
[    46.284] (==) Automatically adding GPU devices
[    46.284] (==) Automatically binding GPU devices
[    46.284] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    46.286] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    46.286] 	Entry deleted from font path.
[    46.288] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    46.288] (==) ModulePath set to "/usr/lib/xorg/modules"
[    46.288] (II) The server relies on udev to provide the list of input devices.
[    46.288] (II) Loader magic: 0x5595d55f1f00
[    46.288] (II) Module ABI versions:
[    46.288] 	X.Org ANSI C Emulation: 0.4
[    46.288] 	X.Org Video Driver: 25.2
[    46.288] 	X.Org XInput driver : 24.4
[    46.288] 	X.Org Server Extension : 10.0
[    46.288] (++) using VT number 1
[    46.290] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[    46.290] (II) xfree86: Adding drm device (/dev/dri/card0)
[    46.290] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:07:00.0/drm/card0
[    46.291] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[    46.293] (--) PCI:*(7@0:0:0) 10de:1c02:19da:2438 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    46.293] (II) LoadModule: "glx"
[    46.293] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    46.294] (II) Module glx: vendor="X.Org Foundation"
[    46.294] 	compiled for 1.21.1.4, module version = 1.0.0
[    46.294] 	ABI class: X.Org Server Extension, version 10.0
[    46.294] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[    46.294] 	loading driver: nvidia
[    46.513] (==) Matched nvidia as autoconfigured driver 0
[    46.513] (==) Matched nouveau as autoconfigured driver 1
[    46.513] (==) Matched nv as autoconfigured driver 2
[    46.513] (==) Matched modesetting as autoconfigured driver 3
[    46.513] (==) Matched fbdev as autoconfigured driver 4
[    46.513] (==) Matched vesa as autoconfigured driver 5
[    46.513] (==) Assigned the driver to the xf86ConfigLayout
[    46.513] (II) LoadModule: "nvidia"
[    46.514] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    46.520] (II) Module nvidia: vendor="NVIDIA Corporation"
[    46.520] 	compiled for 1.6.99.901, module version = 1.0.0
[    46.520] 	Module class: X.Org Video Driver
[    46.521] (II) LoadModule: "nouveau"
[    46.521] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[    46.523] (II) Module nouveau: vendor="X.Org Foundation"
[    46.523] 	compiled for 1.21.1.3, module version = 1.0.17
[    46.523] 	Module class: X.Org Video Driver
[    46.523] 	ABI class: X.Org Video Driver, version 25.2
[    46.523] (II) LoadModule: "nv"
[    46.524] (WW) Warning, couldn't open module nv
[    46.524] (EE) Failed to load module "nv" (module does not exist, 0)
[    46.524] (II) LoadModule: "modesetting"
[    46.524] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    46.525] (II) Module modesetting: vendor="X.Org Foundation"
[    46.525] 	compiled for 1.21.1.4, module version = 1.21.1
[    46.525] 	Module class: X.Org Video Driver
[    46.525] 	ABI class: X.Org Video Driver, version 25.2
[    46.525] (II) LoadModule: "fbdev"
[    46.525] (WW) Warning, couldn't open module fbdev
[    46.525] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    46.525] (II) LoadModule: "vesa"
[    46.525] (WW) Warning, couldn't open module vesa
[    46.525] (EE) Failed to load module "vesa" (module does not exist, 0)
[    46.525] (II) NVIDIA dlloader X Driver  510.85.02  Tue Jul 12 16:48:58 UTC 2022
[    46.525] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    46.525] (II) NOUVEAU driver Date:   Sat Jan 23 12:24:42 2021 -0500
[    46.525] (II) NOUVEAU driver for NVIDIA chipset families :
[    46.525] 	RIVA TNT            (NV04)
[    46.525] 	RIVA TNT2           (NV05)
[    46.525] 	GeForce 256         (NV10)
[    46.525] 	GeForce 2           (NV11, NV15)
[    46.525] 	GeForce 4MX         (NV17, NV18)
[    46.525] 	GeForce 3           (NV20)
[    46.525] 	GeForce 4Ti         (NV25, NV28)
[    46.525] 	GeForce FX          (NV3x)
[    46.525] 	GeForce 6           (NV4x)
[    46.525] 	GeForce 7           (G7x)
[    46.525] 	GeForce 8           (G8x)
[    46.525] 	GeForce 9           (G9x)
[    46.525] 	GeForce GTX 2xx/3xx (GT2xx)
[    46.525] 	GeForce GTX 4xx/5xx (GFxxx)
[    46.525] 	GeForce GTX 6xx/7xx (GKxxx)
[    46.525] 	GeForce GTX 9xx     (GMxxx)
[    46.525] 	GeForce GTX 10xx    (GPxxx)
[    46.525] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    46.525] (II) systemd-logind: releasing fd for 226:0
[    46.526] (II) Loading sub module "fb"
[    46.526] (II) LoadModule: "fb"
[    46.526] (II) Module "fb" already built-in
[    46.526] (II) Loading sub module "wfb"
[    46.526] (II) LoadModule: "wfb"
[    46.526] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    46.527] (II) Module wfb: vendor="X.Org Foundation"
[    46.527] 	compiled for 1.21.1.4, module version = 1.0.0
[    46.527] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    46.527] (II) Loading sub module "ramdac"
[    46.527] (II) LoadModule: "ramdac"
[    46.527] (II) Module "ramdac" already built-in
[    46.529] (WW) Falling back to old probe method for modesetting
[    46.529] (II) NVIDIA(0): Creating default Display subsection in Screen section
[    46.529] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    46.529] (==) NVIDIA(0): RGB weight 888
[    46.529] (==) NVIDIA(0): Default visual is TrueColor
[    46.529] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    46.529] (**) NVIDIA(0): Enabling 2D acceleration
[    46.529] (II) Loading sub module "glxserver_nvidia"
[    46.529] (II) LoadModule: "glxserver_nvidia"
[    46.529] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    46.577] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    46.577] 	compiled for 1.6.99.901, module version = 1.0.0
[    46.577] 	Module class: X.Org Server Extension
[    46.577] (II) NVIDIA GLX Module  510.85.02  Tue Jul 12 16:46:27 UTC 2022
[    46.579] (II) NVIDIA: The X server supports PRIME Render Offload.
[    46.580] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:7:0:0
[    46.580] (--) NVIDIA(0):     DFP-0
[    46.580] (--) NVIDIA(0):     DFP-1
[    46.580] (--) NVIDIA(0):     DFP-2
[    46.580] (--) NVIDIA(0):     DFP-3 (boot)
[    46.580] (--) NVIDIA(0):     DFP-4
[    46.580] (--) NVIDIA(0):     DFP-5
[    46.580] (--) NVIDIA(0):     DFP-6
[    46.580] (--) NVIDIA(0):     DFP-7
[    46.580] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1060 3GB (GP106-A) at PCI:7:0:0
[    46.580] (II) NVIDIA(0):     (GPU-0)
[    46.580] (--) NVIDIA(0): Memory: 3145728 kBytes
[    46.581] (--) NVIDIA(0): VideoBIOS: 86.06.59.00.2c
[    46.581] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    46.581] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    46.581] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    46.581] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    46.581] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): connected
[    46.581] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): Internal DisplayPort
[    46.581] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): 1440.0 MHz maximum pixel clock
[    46.583] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    46.583] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    46.583] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    46.628] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): connected
[    46.628] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): Internal TMDS
[    46.628] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): 600.0 MHz maximum pixel clock
[    46.628] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    46.628] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[    46.628] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[    46.628] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    46.628] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    46.628] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    46.628] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    46.628] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    46.628] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    46.628] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    46.628] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    46.628] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
[    46.642] (==) NVIDIA(0):
[    46.642] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    46.642] (==) NVIDIA(0):     will be used as the requested mode.
[    46.643] (II) NVIDIA(0): Validated MetaModes:
[    46.643] (II) NVIDIA(0):     "DFP-3:nvidia-auto-select,DFP-1:nvidia-auto-select"
[    46.643] (II) NVIDIA(0): Virtual screen size determined to be 4480 x 1440
[    46.650] (--) NVIDIA(0): DPI set to (81, 80); computed from "UseEdidDpi" X config
[    46.650] (--) NVIDIA(0):     option
[    46.650] (II) UnloadModule: "nouveau"
[    46.650] (II) Unloading nouveau
[    46.650] (II) UnloadModule: "modesetting"
[    46.650] (II) Unloading modesetting
[    46.650] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[    46.650] (II) NVIDIA:     access.
[    46.670] (II) NVIDIA(0): Setting mode "DFP-3:nvidia-auto-select,DFP-1:nvidia-auto-select"
[    46.707] (==) NVIDIA(0): Disabling shared memory pixmaps
[    46.707] (==) NVIDIA(0): Backing store enabled
[    46.707] (==) NVIDIA(0): Silken mouse enabled
[    46.709] (==) NVIDIA(0): DPMS enabled
[    46.709] (II) Loading sub module "dri2"
[    46.709] (II) LoadModule: "dri2"
[    46.709] (II) Module "dri2" already built-in
[    46.710] (II) NVIDIA(0): [DRI2] Setup complete
[    46.710] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    46.710] (II) Initializing extension Generic Event Extension
[    46.710] (II) Initializing extension SHAPE
[    46.710] (II) Initializing extension MIT-SHM
[    46.710] (II) Initializing extension XInputExtension
[    46.710] (II) Initializing extension XTEST
[    46.711] (II) Initializing extension BIG-REQUESTS
[    46.711] (II) Initializing extension SYNC
[    46.711] (II) Initializing extension XKEYBOARD
[    46.711] (II) Initializing extension XC-MISC
[    46.711] (II) Initializing extension SECURITY
[    46.711] (II) Initializing extension XFIXES
[    46.711] (II) Initializing extension RENDER
[    46.711] (II) Initializing extension RANDR
[    46.711] (II) Initializing extension COMPOSITE
[    46.711] (II) Initializing extension DAMAGE
[    46.711] (II) Initializing extension MIT-SCREEN-SAVER
[    46.711] (II) Initializing extension DOUBLE-BUFFER
[    46.711] (II) Initializing extension RECORD
[    46.711] (II) Initializing extension DPMS
[    46.711] (II) Initializing extension Present
[    46.711] (II) Initializing extension DRI3
[    46.711] (II) Initializing extension X-Resource
[    46.711] (II) Initializing extension XVideo
[    46.711] (II) Initializing extension XVideo-MotionCompensation
[    46.711] (II) Initializing extension SELinux
[    46.711] (II) SELinux: Disabled on system
[    46.711] (II) Initializing extension GLX
[    46.712] (II) Initializing extension GLX
[    46.712] (II) Indirect GLX disabled.
[    46.712] (II) GLX: Another vendor is already registered for screen 0
[    46.712] (II) Initializing extension XFree86-VidModeExtension
[    46.712] (II) Initializing extension XFree86-DGA
[    46.712] (II) Initializing extension XFree86-DRI
[    46.712] (II) Initializing extension DRI2
[    46.712] (II) Initializing extension NV-GLX
[    46.712] (II) Initializing extension NV-CONTROL
[    46.712] (II) Initializing extension XINERAMA
[    46.770] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    46.770] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    46.770] (II) LoadModule: "evdev"
[    46.770] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    46.772] (II) Module evdev: vendor="X.Org Foundation"
[    46.772] 	compiled for 1.21.1.3, module version = 2.10.6
[    46.772] 	Module class: X.Org XInput Driver
[    46.772] 	ABI class: X.Org XInput driver, version 24.4
[    46.772] (II) Using input driver 'evdev' for 'Power Button'
[    46.773] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 42 paused 0
[    46.773] (**) Power Button: always reports core events
[    46.773] (**) evdev: Power Button: Device: "/dev/input/event3"
[    46.773] (--) evdev: Power Button: Vendor 0 Product 0x1
[    46.773] (--) evdev: Power Button: Found keys
[    46.773] (II) evdev: Power Button: Configuring as keyboard
[    46.773] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    46.773] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    46.773] (**) Option "xkb_rules" "evdev"
[    46.773] (**) Option "xkb_model" "pc105"
[    46.773] (**) Option "xkb_layout" "fr"
[    46.773] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    46.783] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    46.783] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    46.783] (II) Using input driver 'evdev' for 'Power Button'
[    46.784] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 43 paused 0
[    46.784] (**) Power Button: always reports core events
[    46.784] (**) evdev: Power Button: Device: "/dev/input/event2"
[    46.784] (--) evdev: Power Button: Vendor 0 Product 0x1
[    46.784] (--) evdev: Power Button: Found keys
[    46.784] (II) evdev: Power Button: Configuring as keyboard
[    46.784] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    46.784] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[    46.784] (**) Option "xkb_rules" "evdev"
[    46.784] (**) Option "xkb_model" "pc105"
[    46.784] (**) Option "xkb_layout" "fr"
[    46.784] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    46.784] (II) config/udev: Adding input device ROCCAT ROCCAT Lua (/dev/input/event1)
[    46.784] (**) ROCCAT ROCCAT Lua: Applying InputClass "evdev pointer catchall"
[    46.784] (II) Using input driver 'evdev' for 'ROCCAT ROCCAT Lua'
[    46.844] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 44 paused 0
[    46.844] (**) ROCCAT ROCCAT Lua: always reports core events
[    46.844] (**) evdev: ROCCAT ROCCAT Lua: Device: "/dev/input/event1"
[    46.844] (--) evdev: ROCCAT ROCCAT Lua: Vendor 0x1e7d Product 0x2c2e
[    46.844] (--) evdev: ROCCAT ROCCAT Lua: Found 9 mouse buttons
[    46.844] (--) evdev: ROCCAT ROCCAT Lua: Found scroll wheel(s)
[    46.844] (--) evdev: ROCCAT ROCCAT Lua: Found relative axes
[    46.844] (--) evdev: ROCCAT ROCCAT Lua: Found x and y relative axes
[    46.844] (II) evdev: ROCCAT ROCCAT Lua: Configuring as mouse
[    46.844] (II) evdev: ROCCAT ROCCAT Lua: Adding scrollwheel support
[    46.844] (**) evdev: ROCCAT ROCCAT Lua: YAxisMapping: buttons 4 and 5
[    46.844] (**) evdev: ROCCAT ROCCAT Lua: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    46.844] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:01.3/0000:02:00.0/usb1/1-6/1-6:1.0/0003:1E7D:2C2E.0001/input/input1/event1"
[    46.844] (II) XINPUT: Adding extended input device "ROCCAT ROCCAT Lua" (type: MOUSE, id 8)
[    46.844] (II) evdev: ROCCAT ROCCAT Lua: initialized for relative axes.
[    46.844] (**) ROCCAT ROCCAT Lua: (accel) keeping acceleration scheme 1
[    46.844] (**) ROCCAT ROCCAT Lua: (accel) acceleration profile 0
[    46.844] (**) ROCCAT ROCCAT Lua: (accel) acceleration factor: 2.000
[    46.844] (**) ROCCAT ROCCAT Lua: (accel) acceleration threshold: 4
[    46.844] (II) config/udev: Adding input device ROCCAT ROCCAT Lua (/dev/input/mouse0)
[    46.844] (II) No input driver specified, ignoring this device.
[    46.844] (II) This device may have been added with another device file.
[    46.844] (II) config/udev: Adding input device HD-Audio Generic Line Out CLFE (/dev/input/event10)
[    46.844] (II) config/udev: Adding input device HD-Audio Generic Line Out Side (/dev/input/event11)
[    46.845] (II) This device may have been added with another device file.
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Front Headphone (/dev/input/event12)
[    46.845] (II) No input driver specified, ignoring this device.
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Front Mic (/dev/input/event5)
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Rear Mic (/dev/input/event6)
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Line (/dev/input/event7)
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Line Out Front (/dev/input/event8)
[    46.845] (II) config/udev: Adding input device HD-Audio Generic Line Out Surround (/dev/input/event9)
[    46.845] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event0)
[    46.845] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    46.845] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    46.845] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 45 paused 0
[    46.845] (**) AT Translated Set 2 keyboard: always reports core events
[    46.845] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event0"
[    46.845] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    46.845] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    46.845] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    46.845] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input0/event0"
[    46.845] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 9)
[    46.845] (**) Option "xkb_rules" "evdev"
[    46.845] (**) Option "xkb_model" "pc105"
[    46.845] (**) Option "xkb_layout" "fr"
[    46.845] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    46.846] (II) config/udev: Adding input device PC Speaker (/dev/input/event4)
[    46.846] (II) No input driver specified, ignoring this device.
[    46.846] (II) This device may have been added with another device file.
[    48.030] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[    48.153] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[    48.186] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1920x1080 +1920+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}, DP-0: 1920x1080 @1920x1080 +0+0 {ViewPortIn=1920x1080, ViewPortOut=1920x1080+0+0}"
[    50.573] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    50.573] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    50.573] (--) NVIDIA(GPU-0): DFP-0: 330.0 MHz maximum pixel clock
[    50.573] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): connected
[    50.573] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): Internal DisplayPort
[    50.573] (--) NVIDIA(GPU-0): AOC Q2790 (DFP-1): 1440.0 MHz maximum pixel clock
[    50.576] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    50.576] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    50.576] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    50.621] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): connected
[    50.621] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): Internal TMDS
[    50.621] (--) NVIDIA(GPU-0): Idek Iiyama PLB2712HDS (DFP-3): 600.0 MHz maximum pixel clock
[    50.621] (--) NVIDIA(GPU-0): DFP-4: disconnected
[    50.621] (--) NVIDIA(GPU-0): DFP-4: Internal DisplayPort
[    50.621] (--) NVIDIA(GPU-0): DFP-4: 1440.0 MHz maximum pixel clock
[    50.622] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    50.622] (--) NVIDIA(GPU-0): DFP-5: Internal TMDS
[    50.622] (--) NVIDIA(GPU-0): DFP-5: 165.0 MHz maximum pixel clock
[    50.622] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    50.622] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    50.622] (--) NVIDIA(GPU-0): DFP-6: 1440.0 MHz maximum pixel clock
[    50.622] (--) NVIDIA(GPU-0): DFP-7: disconnected
[    50.622] (--) NVIDIA(GPU-0): DFP-7: Internal TMDS
[    50.622] (--) NVIDIA(GPU-0): DFP-7: 165.0 MHz maximum pixel clock
