#1 2022-10-24 13:58:40
spcwingo
New way to install Devuan
Hi all! I just wanted to let y'all know that I have added Devuan support to NetbootCD. I'm just waiting on a merge from Isaac so it can be included in the next release. For those that don't know, NetbootCD is exactly what it sounds like. It's a single CD image capable of net-installing multiple Linux distros.
https://www.lakora.us/netbootcd/
For those that are impatient, you can give it a whirl right now.
https://github.com/spcwingo/netbootcd-reloaded
Just download it from the link (or clone with git), and run Build.sh with root privileges to build NetbootCD (it'll be in the "done" folder). The resulting ISO is a hybrid so it can be burned to an optical disc or written directly to a USB flash drive.
Y'all let me know how it works for you. Cheers!
Disclaimer: This will not boot in UEFI mode!
Disclaimer 2: This is in no way endorsed by the developers of Devuan...I just wanted to put that out there so no toes are stepped on.
#2 2022-10-24 16:31:54
Re: New way to install Devuan
Hello, my compliments on your website, it is utterly gorgeous. Consider your style sheet stolen big_smile
NetbootCD looks wonderful, thanks for sharing this.
I had a quick look through nbscript.sh and I noticed it's using the main pkgmaster.devuan.org server — it would be much better if you could replace that with the recommended deb.devuan.org redirector. It will save a lot of load on the servers. Thanks in advance.
Also, have you considered this method of assigning variables from text file contents:
read VARIABLE < /path/to/file
I find this more elegant than the VARIABLE=$(cat /path/to/file) used in the script but I suppose tastes differ :-)
You might want to run the whole script through https://www.shellcheck.net/ because it shows a number of issues.
Finally did you know that whiptail(1) can do almost everything that dialog can but it's much lighter and smaller? I prefer it myself anyway.
#3 2022-10-25 12:12:06
spcwingo
Oh, no...the only thing that I own is the github repository that I forked from Isaac Schemm just to add Devuan to the list of installable distros. Once I added it I initiated a pull request so that my modified version of nbscript.sh could be merged into the official NetbootCD repository.
Also, I just checked the redirector URL and I couldn't find the netboot kernel & init anywhere. I found the URL that I used on the "get-devuan" page of the main site under netboot just above the mirror list. If you could point me in the direction of where I might be able to find the PXE kernel & init by using the redirector, I'd be much obliged.
#4 2022-10-25 14:14:25
http://deb.devuan.org/devuan/dists/chim … ler/amd64/
#5 2022-10-25 17:40:12
spcwingo
Thank you! I have edited the code. I'm about to submit a pull request to Isaac. I appreciate your help!
#6 2022-10-29 16:15:34
spcwingo
Changes have been merged into Isaac's repo.
