#1 2022-09-27 19:16:08
erdos
20-year-old Linux workaround is still slowing down AMD systems
hi  I'm wondering what you guys' take on this if you're on AMD system using Devuan/Debian.
https://arstechnica.com/gadgets/2022/09/20-year-old-linux-workaround-is-still-slowing-down-amd-systems/
#2 2022-09-28 06:21:05
Re: 20-year-old Linux workaround is still slowing down AMD systems
Well here's my processor benchmarked under both Windows & Linux:
https://www.phoronix.com/review/ryzen7p … ws-linux/8
^ That was with the old, "slow" ACPI code. Windows is clearly beaten. The difference should be even greater with the new fix. Yay.
EDIT: and who even uses ACPI anyway?
$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver
amd-pstate
