#1 2022-09-07 00:00:43
DandyKenguru
Package speech-dispatcher cannot be properly removed.
Why i cannot properly remove speech-dispatcher on Devuan?
Removing speech-dispatcher (0.10.2-2+deb11u1) ...
opendir /proc: Permission denied
userdel: /etc/subuid.2456: Permission denied
userdel: cannot lock /etc/subuid; try again later.
/usr/sbin/deluser: `/usr/sbin/userdel speech-dispatcher' returned error code 16. Exiting.
dpkg: error processing package speech-dispatcher (--remove):
 installed speech-dispatcher package post-removal script subprocess returned err
or exit status 1
dpkg: too many errors, stopping
 speech-dispatcher
Processing was halted because there were too many errors.
#2 2022-09-07 07:55:49
Re: Package speech-dispatcher cannot be properly removed.
Try
rm /etc/subuid.2456
apt purge speech-dispatcher
If that doesn't work post the full error message and the output of
stat /proc /etc
#3 2022-09-07 09:22:28
DandyKenguru
Doesn't work. sad subuid number change every time when i`m try remove this package. /etc not have any directories /subuid at all.
xxxxx@devuan:~$ sudo apt purge speech-dispatcher
  espeak-ng-data libespeak-ng1 libspeechd2 speech-dispatcher-audio-plugins
  speech-dispatcher
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 18.3 MB disk space will be freed.
(Reading database ... 118075 files and directories currently installed.)
userdel: /etc/subuid.2445: Permission denied
 Exiting.
or exit status 1
 speech-dispatcher
xxxxx@devuan:~$ stat /proc /etc
  File: /proc
  Size: 0         	Blocks: 0          IO Block: 1024   directory
Device: 15h/21d	Inode: 1           Links: 216
Access: (0555/dr-xr-xr-x)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2022-09-07 12:13:46.620000002 +0300
Modify: 2022-09-07 12:13:46.620000002 +0300
Change: 2022-09-07 12:13:46.620000002 +0300
 Birth: -
  File: /etc
  Size: 12288     	Blocks: 24         IO Block: 4096   directory
Device: 802h/2050d	Inode: 389378      Links: 124
Access: (0755/drwxr-xr-x)  Uid: (    0/    root)   Gid: (    0/    root)
Access: 2022-09-06 02:18:45.395999689 +0300
Modify: 2022-09-07 12:15:49.743995811 +0300
Change: 2022-09-07 12:15:49.743995811 +0300
 Birth: 2022-09-06 02:18:45.395999689 +0300
#4 2022-09-07 09:44:16
How about
findmnt
#5 2022-09-07 09:58:07
DandyKenguru
I found solution.
sudo sed -i '/speech-dispatcher/d' /etc/passwd
After this cmd I can remove this package.
PS: Thank You for help.
#6 2022-09-07 10:53:34
I think there might be an underlying problem not addressed by that workaround. Can we see the findmnt output? It will show if everything's mounted correctly.
#7 2022-09-07 11:07:44
DandyKenguru
I think it something to do with how devuan live iso create user(s) in system. Because i cannot use "userdel" command (always something lock without possibility unlock it or delete *.lock) and /etc/subuid have "devuan" string and not my username. Maybe I`m wrong.
TARGET                   SOURCE     FSTYPE  OPTIONS
/                        /dev/sda2  ext4    rw,noatime
├─/sys                   sysfs      sysfs   rw,nosuid,nodev,noexec,relatime
│ ├─/sys/kernel/security securityfs securit rw,relatime
│ ├─/sys/fs/pstore       pstore     pstore  rw,relatime
│ ├─/sys/fs/cgroup       cgroup2    cgroup2 rw,nosuid,nodev,noexec,relatime,nsde
│ ├─/sys/firmware/efi/efivars
│ │                      efivarfs   efivarf rw,nosuid,nodev,noexec,relatime
│ └─/sys/kernel/debug    none       debugfs rw,relatime
│   └─/sys/kernel/debug/tracing
│                        tracefs    tracefs rw,relatime
├─/proc                  proc       proc    rw,nosuid,nodev,noexec,relatime
├─/dev                   udev       devtmpf rw,nosuid,relatime,size=4024320k,nr_
│ ├─/dev/pts             devpts     devpts  rw,nosuid,noexec,relatime,gid=5,mode
│ └─/dev/shm             tmpfs      tmpfs   rw,nosuid,nodev,noexec,relatime,size
├─/run                   tmpfs      tmpfs   rw,nosuid,nodev,noexec,relatime,size
│ ├─/run/lock            tmpfs      tmpfs   rw,nosuid,nodev,noexec,relatime,size
│ └─/run/user/1000       tmpfs      tmpfs   rw,nosuid,nodev,relatime,size=809280
├─/home                  /dev/sda4  ext4    rw,noatime
└─/boot/efi              /dev/sda1  vfat    rw,relatime,fmask=0077,dmask=0077,co
#8 2022-09-07 17:24:31
Everything looks normal to me. Not sure what's going on there.
#9 2022-09-07 17:33:20
DandyKenguru
Damn. I found out what created all this mess. Just one word. "APPARMOR". First time I`m see apparmor vs apt conflict.
sudo aa-disable /etc/apparmor.d/usr.sbin.userdel ; sudo apt purge -y speech-dispatcher ; sudo aa-enforce /etc/apparmor.d/usr.sbin.userdel ; sudo apt -y autoremove
