#1 2022-08-30 16:12:34
wingcommander1999
[HowTo] Recover Dual Boot on DEVUAN 5
By default under DEVUAN 5 os-prober is missing from the grub file.
We'll add it back and then update grub to support dual boot:
sudo nano /etc/default/grub
In the grub file add the line below:
GRUB_DISABLE_OS_PROBER=false
Update grub:
sudo update-grub
After the reboot the dual boot is available again.
Source
AMD Ryzen 7 5700X - Gigabyte B550 AORUS ELITE V2 - 32Gb Vengeance Pro RGB White - NVME/SSD 2,5To - RTX4060TI 6Gb White - PSU Corsair 750w White - Case Corsair 5000D AirFlox Case fan x7 White - AIO 240 Corssair RGB White
Daedalus / W11
