#1 2022-08-28 16:59:46
penguin
[SOLVED] gimp often crashes during the copy operation.
My desktop manager is LXQT v0.16.0
I use gimp to resize or modify photo images. The current gimp version is 2.10.22
The typical scenario is:
I load a JPG image file on gimp.
Do the selection all operation and Copy to create a new image for resizing or editing work.
I started to experience random crash during copy or paste operation of image selection.
I just installed version 2.10.32 to test the crash of copy operation.
I started gimp by running
flatpak run org.gimp.GIMP//stable
I loaded a JPG image file whose size is 2.0MB, which gimp 2.10.22 was crashing during select and copy operation.
New version of gimp still crashes.
#2 2022-09-02 17:22:37
penguin
Re: [SOLVED] gimp often crashes during the copy operation.
I tested gimp 2.99 that supports GTK3. It did not crash during select and copy operation.
