#1 2022-08-27 23:50:07
torquebar
avatar upload
I reduced the size of an image 5 times before giving up; the upload dialog would be the best place to display the size limit.
Who, has loved us more?
#2 2022-08-28 09:09:17
Re: avatar upload
Avatar upload page wrote:
An avatar is a small image that will be displayed under your username in your posts. It must not be any bigger than 60 x 60 pixels and 10,240 bytes (10 KiB).
(Added emphasis.)
EDIT: I use this to generate a 60x60 .png from a larger size .svg image:
inkscape --export-width=60 --export-height=60 --export-filename=avatar.png Anarchist_black_cat.svg
#3 2022-11-02 14:01:07
zephyr
Re: avatar upload
HoaS wrote: I use this to generate a 60x60 .png from a larger size .svg image:
Works as advertised, I like it! smile
Thank you...for everything you do!
zephyr
CROWZ
#4 2022-11-02 14:32:27
xinomilo
Unknown
Re: avatar upload
always wondered about avatars here big_smile
thx smile
