#1 2022-08-24 18:48:36
shazam
How to change swappiness in Devuan with sysvint ?
How to change swappiness in Devuan with sysvint for reducing swapping in SSD ?
in debian with systemd
i follow  these steps:
pluma admin:///etc/sysctl.conf
then i add the following lines in sysctl.conf
# Reduce the swappiness from 60 default to 10
vm.swappiness=10
how to do this in devuan withsystvint?
#2 2022-08-24 19:20:26
Re: How to change swappiness in Devuan with sysvint ?
vm.swappiness does not control when swap is used. It only mediates what type of swap is used once it is activated.
EDIT: but yes, configuring sysctl.conf is identical under sysvinit (or even runit-init or openrc-init).
