Pages: 1
just in case someone need CDEmu software that is in deb-multimedia, one of its packages has a systemd dependency, cdemu-daemon.
I manually edited this package to be Devuan compatible
To install CDEmu in DAEDALUS:
- setup deb-multimedia repository
create /etc/apt/sources.list.d/multimedia.list
# Multimedia
deb http://www.deb-multimedia.org bookworm main non-freecreate /etc/apt/preferences.d/50multimedia to lower priority.
Package: *
Pin: release o=Unofficial Multimedia Packages
Pin-Priority: 100- Update and keyring
sudo apt update -o Acquire::AllowInsecureRepositories=true
sudo apt install deb-multimedia-keyring
sudo apt update- Download and install the modified cdemu-daemon_3.2.6-dmo1_amd64_NO_SYSTEMD.deb
sudo apt install '<Path to>/cdemu-daemon_3.2.6-dmo1_amd64_NO_SYSTEMD.deb'- Then you can install remaining packages from deb-multimedia:
sudo apt install gcdemu cdemu-client [image-analyzer]- Remove or pin the deb-multimedia repository.
This is not ideal because I will have to do that for each new version, but this software saves my life for protected old games CD.
Pages: 1
