#1 2022-08-22 13:11:00
lakesidepark
CHTMAX98090 sound driver not working
Dears i have installed the Devaun live in my acer notebook, it have the chtmax98090 sound card, in /usr/share/alsa/ucm2  have the driver and the codecs but is not recognized.
How  can i enable it,  as I remember in debian need to install and enable backports, how I do it into Devaun.
Thanks
#2 2022-08-22 13:18:53
lakesidepark
Re: CHTMAX98090 sound driver not working
/usr/share/alsa/ucm2/chtmax98090/HiFi.conf
/usr/share/alsa/ucm2/chtmax98090/chtmax98090.conf
/usr/share/alsa/ucm2/codecs/max98090/EnableSeq.conf
/usr/share/alsa/ucm2/codecs/max98090/Headphones.conf
/usr/share/alsa/ucm2/codecs/max98090/HeadsetMic.conf
/usr/share/alsa/ucm2/codecs/max98090/InternalMic.conf
/usr/share/alsa/ucm2/codecs/max98090/Speaker.conf
alsa list
#3 2022-08-22 16:26:16
Same as with Debian but with a different repository:
https://www.devuan.org/os/packages ← see the "Add backports" section.
EDIT: the advice in that section is wrong though because the backports repository should be left enabled to ensure the backported packages are kept updated; this is particularly critical for the kernel metapackage.[1]
The backports repository's InRelease file has these lines:
NotAutomatic: yes
[snip]
ButAutomaticUpgrades: yes
^ Those confer a pin value of 100 and ensures that packages can only be installed explicitly (eg, apt install -t chimaera-backports) but also that they will be kept updated from backports once installed.
[1] I've also had this argument with the MX Linux developers. I am right.
