#1 2022-08-05 08:31:38
SpongeBOB
[SOLVED] What is that UDP traffic ?
Hi everyone,
I see the following in my nftable log (that has been dropped) -->
IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:****** SRC=192.168.0.1 DST=255.255.255.255 LEN=138 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=33295 DPT=5678 LEN=118
**** = mac address removed
the SRC, it the IP of this machine so I guess my machine launch a broadcast ? but which one ? from which application ?
Any idea what generate this ? I get it ~every minute.
Thanks.
#2 2022-08-05 13:13:07
auanta
Re: [SOLVED] What is that UDP traffic ?
192.168.0.1 is usually a router address. Verify that 192.168.0.1 the local router IP address for your internal network by looking in your network settings for "default gateway".
So what that line tells me is iptables is saying is that your router is broadcasting UDP packets to all devices on the network, including into your machine through the ethernet connection.
What is the port information of the UDP packets?
Are you or anyone else on your network having any problems connecting to the internet?
I wouldn't worry about it, these broadcasts are normal in a local area network. The router will happily forward UDP packets from several protocols by design: TFTP, DNS, Time, NetBIOS, ND, BOOTP or DHCP, TACACS, IEN-116
Unless you are having issues connecting to the internet, or you just want to tinker with iptables to learn how it all works, you can safely ignore it.
Devuan GNU/Linux, the sysadmin secret sauce
> "I use Hyperbola btw" my favorite BSD wink
Disclaimer: If I give you any technical advice, always double check it, because even though I used GNU/Linux many years, I'm still learning, just like you. I try to help, but I could be wrong! Empower yourself!
#3 2022-08-05 13:31:04
SpongeBOB
Thank you Auanta,
192.168.0.1 is the IP of the machine (not the router, there are none, this is a VM network )
I'm not using iptables but NFtables.
#4 2022-08-05 14:34:05
auanta
SpongeBOB wrote:
Thank you Auanta,
Oh yeah, it's a vm so that makes sense. Also iptables and nftables, both firewalls so same info, I misspoke
Have you tried browsing the internet from within your Devuan VM?
As for what type of UDP traffic it is, it's harmless, but if you want to know then you'd have to look at the port number and correspond it to the protocol.
#5 2022-08-05 15:38:53
SpongeBOB
I have many network, but that working when I need yes.
You mean to look-up with --> https://en.wikipedia.org/wiki/List_of_T … rt_numbers
Port 5678 is not assigned to anything...
#6 2022-08-05 17:38:23
auanta
That mystery will take you a little bit of a dive into networking theory, I'd say if it's an unassigned port then one of the protocols chose it at random. So which of the above protocols choose a random UDP port? I'll let you do that one haha
Yep, so you're not having any problems with the internet so you can definitely ignore it or just research for curiosity.
#7 2022-08-06 10:19:37
SpongeBOB
I will "mute" this rules for the moement and when I have the time I will investigate for sure.
Thanks for your guidance.
