I installed Ungoogled Chromium, but then deleted it because I didn't like it. Obviously I did not clear its repository because I got the below error when doing "apt update":
47 packages can be upgraded. Run 'apt list --upgradable' to see them.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/home:/ungoogled_chromium/Debian_Bullseye InRelease: The following signatures were invalid: EXPKEYSIG 02456C79B2FD48BF home:ungoogled_chromium OBS Project <home:ungoogled_chromium@build.opensuse.org>
W: Failed to fetch http://download.opensuse.org/repositories/home:/ungoogled_chromium/Debian_Bullseye/InRelease The following signatures were invalid: EXPKEYSIG 02456C79B2FD48BF home:ungoogled_chromium OBS Project <home:ungoogled_chromium@build.opensuse.org>
W: Some index files failed to download. They have been ignored, or old ones used instead.Okay, so I thought I'd use Synaptic to eliminate that repository, but I got the below error after selecting Repositories:
An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://download.opensuse.org/repositories/home:/ungoogled_chromium/Debian_Bullseye InRelease: The following signatures were invalid: EXPKEYSIG 02456C79B2FD48BF home:ungoogled_chromium OBS Project <home:ungoogled_chromium@build.opensuse.org>Failed to fetch http://download.opensuse.org/repositories/home:/ungoogled_chromium/Debian_Bullseye/InRelease The following signatures were invalid: EXPKEYSIG 02456C79B2FD48BF home:ungoogled_chromium OBS Project <home:ungoogled_chromium@build.opensuse.org>Some index files failed to download. They have been ignored, or old ones used insteadHow do I remove that repository?
I recommend using appimage if the repo stopped working
(you might need to hard delete it in the config file)
___________________________
Error in your config file
it points to HOME not HTTP
_________
Download appimage for UGC from
https://ungoogled-software.github.io/un … -binaries/
binaries are generally here : https://ungoogled-software.github.io/un … -binaries/
appimage is updated, debian package is still older..
repo error is about expired gpg signing, url is correct.
Thanks for the replies, but we seem to be talking past each other. I know about appimage, but that won't help me now, as apt won't run. What is the full pathname for the config file I need to edit?
UPDATE: I went to /etc/apt/trusted.gpg.d and deleted home-ungoogled_chromium.gpg, which allowed me to do update/upgrade, but I still see errors on update. I think I'll wipe the drive and reinstall.
Just find the file containing the repository:
grep -R 'download.opensuse.org' /etc/apt/sources.list{,.d/*}Then edit the file and remove the repository line. Or just delete the file if it only has one line.
No need to reinstall.
@Head_on_a_Stick
Thanks so much for that. I was rooting around in /etc/apt, but I never looked in /etc/apt/sources.list.d, which is where the offending file was.
