Pages: 1
devuan ascii cold start login to desktop mouse cursor moves but no click right or left, I do ctrl+alt+ f1,takes to terminal and relogin type xstart go to desktop every thing works.
OK I gave up devuan asii and installed devuan boewulf 3.1.1. amd64 same thing , so must be my computer or something I'm doing wrong.!!
thanks for all the help god bless all
don
Did you try Devuan Chimaera 4.0 stable release?
----+- Peter Kropotkin -+----
hi Ogis1975
no not yet. my hp will not start. my dell xps on broad eth not working.
got this toshiba laptop it has does the same with ascii / boewulf
I will try it on toshiba.
don
ok I'm back got a newer computer (i'm on it)
toshiba did not work!
Dell Optiplex 7010 the small desk top with,
Devuan GNU/Linux 3.1 beowulf amd64 do a cold start login, mouse Cursor moves but no right or left click,use keyboard windows key (::) the one between left ctrl Key and alt keys opens panel goto power/session then logout and login.
all works ok! Does this on all start ups!!
I've got two more computers useing Devuan GNU/Linux 3.1 beowulf amd64(they work fine) and I've traded the usb mice(they do the samething on Dell optiplex 7010).
thank you for your help!!
don
Pages: 1
