#1 2022-06-26 16:45:33
chomwitt
Running a privileged command at login.
I'm using Devuan GNU/Linux 5 with runit.
I want to run a 'sudo' command at login. I guess it needs to be
started as a root command without having to provide a password.
How could i do that?
@ devuanwiki/Chomwitt
#2 2022-06-26 17:03:50
MiyoLinux
Re: Running a privileged command at login.
Are you familiar with cron jobs? That's one way to do it. smile
#3 2022-06-26 17:12:02
Why do you want to do that? What are you trying to achieve?
See also https://xyproblem.info/
#4 2022-06-26 17:16:01
chomwitt
I know it's purpose, not familiar but i'll manage.
I tried that so far:
$ less /etc/profile.d/enableqemunetworking.sh
virsh net-start default   &
but didnt work..
@HeadonStick i try to enable qemu networking but the command only works with sudo.
#5 2022-06-26 17:28:08
The command can be added to /etc/rc.local but that feels hacky af.
Have you tried
# virsh net-autostart default
^ I think that should enable it to auto start without having to run your command.
Reference: https://libvirt.org/sources/virshcmdref … start.html
#6 2022-06-26 17:47:33
chomwitt
@Head_on_a_Stick Thanks! that worked.
I wonder why thought the script in /etc/profile.d/enableqemunetworking.sh  didnt seem to work.
#7 2022-06-26 17:54:57
Was the script executable?
#8 2022-06-27 14:03:09
chomwitt
I made it executable but still nothing.
export TESTPROFILEDOTD=1970
The test var is changed but not the net default state.
I suspect that virt-manager and libvirtd process must have started first.
#9 2022-06-27 14:08:48
xinomilo
Unknown
virsh is a libvirt client, so yes, libvirtd must be started in order for virsh to work..
although this https://dev1galaxy.org/viewtopic.php?pid=36441#p36441 makes your command unnecessary.. (you can also change this from virt-manager/GUI).
#10 2022-06-27 16:17:01
chomwitt
Yes i understand that. But i was curious to see if indeed a 'root' command can be executed in profile.d
So i could make the script wait and poll the processes and when libvirt is executed then to execute the command!
#11 2022-06-27 17:12:32
Sorry, that was a stupid question. Files in /etc/profile.d/ are sourced rather than executed. D'oh!
#12 2022-06-27 17:43:05
chomwitt
That explains why other scripts in profile.d werent executable.
Generaly i realized that profile.d is for preparing the system wide enviroment (of bash only or more generally ?)
So a more sound approach would be to start libvirtd and then make sure the default networking is enabled .
#13 2022-06-27 17:49:15
chomwitt
From where ? From general options or a VM options ? I didnt find anything.
#14 2022-06-27 17:57:44
chomwitt
Reading here https://www.linuxfromscratch.org/blfs/v … ofile.html
it seems that profile.d is for scripts that set up the shell enviroments.
So if i wanted to setup an application and it's initial set up i should do it from somewhere else.
But i've just read an askubuntu post where network config is attempted from a profile.d script.
#15 2022-06-27 17:58:05
xinomilo
Unknown
Connection Options.
if you already connected virt-manager to local libvirtd : choose that (qemu:///system) connection and :
(menu) Edit -> Connection Details -> Virtual Networks tab -> choose network, and check "Autostart On Boot"  on network Details.
#16 2022-06-27 18:02:59
chomwitt
xinomilo wrote:
Connection Options.
I found it. Thanks!
#17 2022-06-27 23:46:50
chomwitt
Interestingly invocation section of man page of bash dont refer to profile.d .
So maybe it started as a distro practice that stuck  and now it's used a a global config-set up space ?
I found an interesting discussion here.
It seems that profile.d is used in some distros that use some shells that parse that folder for application specifics setups.
In my devuan installation:
/etc/profile.d$ ls
bash_completion.sh       flatpak.sh  gawk.sh      vte.csh  gawk.csh    vte-2.91.sh
But that wont work in a case like mine but only if libvirtd was reading some shell enviroment
variable to determine what net setup to enable when started.
So i guess profile.d is one way to setup an 'enviroment' for applications that would look to certain env variables.
If an app looks only to a config file profile.d it's not needed.
In my case i found first here  about a command that fixes
a network error in virt-manager. Now as @xinomilo told me that can be set either with a terminal command or a gui setting   that changes a relative setting.
I propably was unlucky finding only the first 'solution'  that make me understand that a command fixes an error . But now it seems it's just an application
setting that propably sitting in a config file and there are two ways to change that 'file' and propably to edit it by a text editor.
And maybe virt-manager shouldnt either report it as an error! That small detail could have put me into a different fix mentality and not in the 'config' mentality.
To sum it up. It was a setting issue masqueraded as a  pseudo 'correct functioning' issue.
