#1 2022-06-09 12:52:36
devian
External monitor on laptop results in high CPU usage for Xorg
As soon as I attach an external HDMI monitor to my laptop, the CPU usage for Xorg jumps to 100% and stays there.  I have KDE running and all widgets and GUI applications closed.
Edit: xembedsniproxy also suddenly has high CPU usage as soon as the monitor is plugged in so I suspect this is the culprit.
Second edit: a workaround to solve this is simply "killall xembedsniproxy"
Third edit: this removes all my application system tray icons (not normal KDE ones) but I can do "wmsystemtray --non-wmaker --bgcolor white" to see them appear in a new window.
This is a Lenovo laptop with Intel graphics. What info do I need to provide to help debug this?  Thanks.
#2 2022-06-09 13:20:41
Re: External monitor on laptop results in high CPU usage for Xorg
Check the X.Org log. If you're using GDM I think it will be under ~/.local/share/xorg/ or /var/log/ otherwise. ~/.xsession-errors might also have some clues.
If you have xserver-xorg-video-intel installed then try removing that package to force modesetting instead, which is reported to be less buggy.
#3 2022-06-09 14:42:08
devian
.xsession_errors has 400,000 lines of this:
Container window visible, stack below
I think I'm happy with doing killall for now.
#4 2022-06-09 16:27:41
Entering the error message into a search engine throws up https://bugs.kde.org/show_bug.cgi?id=425271 so this is a known bug.
The suggested workaround is given here but it's rubbish.
#5 2022-06-09 17:06:06
devian
Nice spot. I didn't come across that page.
