#1 2022-06-07 16:45:08
nobodyuknow
[SOLVED] edit music file properties as in Windows
I always rip CDs on a Windows 10 PC because I want the files to be lossless. I do not believe that MP3 represents the pinnacle of music fidelity.
One of the things I do when ripping is to ensure that the metadata is correct. In Windows it's easy, just use Properties. But in Linux, there does not appear to be a way to edit the properties of music files. Is there a way?
#2 2022-06-07 18:11:42
Re: [SOLVED] edit music file properties as in Windows
There are several rippers for Linux, some will automatically add the metadata if you are connected to the internet.
Here's one such program - https://www.systutorials.com/docs/linux/man/1-grip/
#3 2022-06-07 21:54:40
nobodyuknow
@Camtaf
Thanks for the reply. I should have mentioned that my primary music is classical, for which metadata is often wrong, hence why I want to edit it.
#4 2022-06-07 23:58:27
alexkemp
$ apt-cache search kid3
kid3 - KDE audio tag editor
kid3-cli - Command line audio tag editor
kid3-core - Audio tag editor core libraries and data
kid3-qt - Audio tag editor
$ apt-cache showpkg  kid3
Package: kid3
Versions:
3.8.5-3 (/var/lib/apt/lists/deb.devuan.org_merged_dists_chimaera_main_binary-amd64_Packages)
 Description Language:
                 File: /var/lib/apt/lists/deb.devuan.org_merged_dists_chimaera_main_binary-amd64_Packages
                  MD5: 62c283c9a6db1de53afbc80f8d4105f8
 Description Language: en
                 File: /var/lib/apt/lists/deb.devuan.org_merged_dists_chimaera_main_i18n_Translation-en
Reverse Depends:
  kid3-core,kid3 3.8.5-2
  kid3-cli,kid3 3.0.2-2
Dependencies:
3.8.5-3 - kio (0 (null)) libc6 (2 2.14) libgcc-s1 (2 3.0) libkf5configcore5 (2 4.97.0) libkf5configgui5 (2 4.97.0) libkf5configwidgets5 (2 5.23.0) libkf5coreaddons5 (2 4.100.0) libkf5kiocore5 (2 5.69.0) libkf5widgetsaddons5 (2 4.96.0) libkf5xmlgui5 (2 4.98.0) libqt5core5a (2 5.15.1) libqt5gui5 (18 5.7.0) libqt5gui5-gles (2 5.7.0) libqt5widgets5 (2 5.0.2) libstdc++6 (2 4.1.1) kid3-core (5 3.8.5-3)
Provides:
3.8.5-3 -
Reverse Provides:
$ apt-cache search falso
exfalso - audio tag editor for GTK+
quodlibet - audio library manager and player for GTK3
$ apt-cache showpkg exfalso
Package: exfalso
Versions:
4.3.0-1 (/var/lib/apt/lists/deb.devuan.org_merged_dists_chimaera_main_binary-amd64_Packages) (/var/lib/dpkg/status)
                  MD5: fcc2776342ffcd06e76d0d3544249a2e
Reverse Depends:
  quodlibet,exfalso 4.3.0-1
Dependencies:
4.3.0-1 - gir1.2-gtk-3.0 (0 (null)) gir1.2-soup-2.4 (0 (null)) python3 (2 3.5) python3-feedparser (0 (null)) python3-gi (0 (null)) python3-gi-cairo (0 (null)) python3-mutagen (2 1.34) python3:any (0 (null)) libjs-sphinxdoc (2 1.0) sphinx-rtd-theme-common (2 0.4.3+dfsg) quodlibet-plugins (0 (null)) python3-musicbrainzngs (0 (null)) brasero (16 (null)) k3b (16 (null)) xfburn (0 (null)) gir1.2-gstreamer-1.0 (0 (null)) libmodplug1 (0 (null)) quodlibet-plugins (0 (null))
Provides:
4.3.0-1 - quodlibet-plugins (= )
Reverse Provides:
#5 2022-06-08 02:17:11
I'm using easytag
#6 2022-06-08 19:25:34
nobodyuknow
easytag is in the usual repository, but it has strange behavior. I installed it, started it, looked around, and changed the directory, only to be confronted with a message along the lines of: "Files have been modified; save or discard?" Except that I made no changes at all. I uninstalled it.
#7 2022-06-08 19:33:12
nobodyuknow
kid3 looks promising, as it has a GUI somewhat similar to Windows Properties popup. I'll play with that.
#8 2022-06-08 19:34:19
nobodyuknow
I marked the thread as SOLVED because I have some promising leads. Thanks to everyone who responded.
#9 2022-06-08 19:40:09
Any chance you could share them here? I'm sure other people who might face the same problem would find them useful.
#10 2022-06-09 17:47:30
nobodyuknow
Sorry, I was a bit obtuse. The leads were provided by alexkemp: kid3 and exfalso. The former appears to do what I need, so I'm playing around with it.
#11 2022-06-11 00:05:47
I also found easytag had some database lookup and (re)generate actions happening,
but once it's user-settings are configured it doesent hunt around so much.
I still like easytag.
#12 2022-06-25 18:47:54
czeekaj
picard (music brainz) is also a good one. Although bloated
It can be a little tricky but it can automate some things like track order. It queries possible matches and helps tidy up your library.
Album art is not as automated. It can make a mess of things if you are not careful, but then it's more manual anyway. Stops you from having to renumber tracks per album and can allow you to work on a album by album basis rather then track by track.
