#1 2022-06-06 07:14:09
charliebrownau
Would it be possible please to add 'CoreCtrl' to the repo ?
Gday
CoreCtrl
https://gitlab.com/corectrl/corectrl
Into the repo
I followed the build info on gitlab , yet it failed
Is it possible to remove all the bad stuff,
replace whats needed and
get it going with Dev1 ?
It doesnt have a deb or portable runable install
or appimage
Thanks in advance
Update:
Build issues mentioned here
https://old.reddit.com/r/debian/comment … in_debian/
Thinkfan for Thinkpad fans
https://github.com/vmatare/thinkfan
#2 2022-06-06 13:07:09
Re: Would it be possible please to add 'CoreCtrl' to the repo ?
The Ubuntu .deb packages are here:
https://ppa.launchpadcontent.net/ernstp … /corectrl/
Try to install them with gdebi, it will refuse if they are not compatible.
You can try to build you own Devuan-compatible .debs from the PPA if the Ubuntu versions won't install:
https://wiki.debian.org/CreatePackageFromPPA
#3 2022-06-06 22:08:20
charliebrownau
Thanks for the deb link
It failed to install
It seems this is just too bloated with QT and various extra crap
#4 2022-06-08 11:40:28
If you run gdebi from a terminal it will spit out an error message that you can share here. The dependencies might be correctable.
Did you try building it locally from the PPA source code?
