#1 2022-05-20 10:01:53
amaro
[SOLVED] suggestion for new package
Hello everybody!
I would like to suggest one package that is available for 'ubuntu' and 'mxlinux' to be adopted by Devuan and made available in the repos.
'foliate' - e-book reader with many features including highlighting and annotations, nice gui, reads most popular formats
Thank you for the excellent distro!
p.s. if this is not appropriate or not allowed, please delete the post.
#2 2022-05-21 17:45:40
Re: [SOLVED] suggestion for new package
Can you not just install the .deb from MX? Their bullseye base should be compatible with chimaera but don't add their repositories.
http://mxrepo.com/mx/repo/pool/main/f/f … +1_all.deb
#3 2022-05-22 10:13:39
amaro
Thank you!
Was not sure about dependencies and compatibility but your word was enough as a guarantee.
p.s. Works fine.
#4 2022-05-22 10:58:43
As long as you just install the .deb (with gdebi or whatever) then it can only be installed if the dependencies are satisfied by what is available from the Devuan repositories.
Adding the MX repositories would cause problems so don't try that.
#5 2023-10-04 04:02:29
amaro
I would like to suggest another package that is available for Debian
https://packages.debian.org/bullseye/minder
It is a mindmapping tool that I think is better (especially regarding the export option) and more intuitive than 'vym'.
I have just installed it (Chimaera) and it works fine
ain libmarkdown2 libgee-0.8-2  libgranite5
dpkg -i minder_1.9.2-1_amd64.deb
Note: 'ain' is an alias for 'apt install'.
p.s. Is there a thread where suggestions for new packages can be posted?
#6 2023-10-04 11:20:09
boughtonp
Since Devuan is Debian with systemd removed, all packages available for Debian are already available in Devuan, unless they rely on systemd in a way which cannot be resolved (or maybe can be but hasn't yet).
There is no need to manually install a deb file for packages that exist in Debian.
https://pkginfo.devuan.org/minder
3.1415P265E589T932E846R64338
#7 2023-10-04 14:10:56
amaro
Thank you, boughtonp!
I must have missed it in the 'apt search' results.
