#1 2022-05-17 12:28:01
devian
SEGFAULT with i965_dri.so
I am seeing a crash in i965_dri.so while running FreeCAD Appimage. This is the command line output:
$ FreeCAD-asm3-Daily-Conda-Py3-Qt5-20220511-glibc2.12-x86_64.AppImage
/tmp/.mount_FreeCAipF3cg
FreeCAD 0.20, Libs: 2022.511R26244 +4790 (Git)
Program received signal SIGSEGV, Segmentation fault.
#0  /lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7f0646239d60]
#1  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x14c7fa) [0x7f06374097fa]
#2  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x1499ff) [0x7f06374069ff]
#3  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x1e686e) [0x7f06374a386e]
#4  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x1e6ffb) [0x7f06374a3ffb]
#5  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x2206fc) [0x7f06374dd6fc]
#6  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x2155ee) [0x7f06374d25ee]
#7  /usr/lib/x86_64-linux-gnu/dri/i965_dri.so(+0x47b8de) [0x7f06377388de]
#8  0x7f0648a12515 in NaviCubeShared::drawNaviCube(SoCamera*, bool, int, bool) from /tmp/.mount_FreeCAipF3cg/usr/bin/../lib/libFreeCADGui.so+0x15f5
#9  0x7f0648a12816 in NaviCubeImplementation::drawNaviCube(bool) from /tmp/.mount_FreeCAipF3cg/usr/bin/../lib/libFreeCADGui.so+0x46
#10  0x7f06489dc9b5 in Gui::View3DInventorViewer::renderScene() from /tmp/.mount_FreeCAipF3cg/usr/bin/../lib/libFreeCADGui.so+0x515
etc
Apparently this does not occur on normal Debian. Is there a way I can install the debug version of i965_dri.so to find out more about the crash?
Do any Devuan experts have any suggestions how to fix this or how I can investigate?
Many thanks.
