#1 2022-05-04 04:44:23
greenant
Chimaera install as KVM guest with virsh-install - kernel mismatch
We have been installing KVM machines with Devuan Beowulf successfully but similar settings for Chimaera fail with a kernel mismatch.
The installer throws the error in the log:
no packages matching running kernel 5.10.0-9-amd64 in archive
and the following error in the installer
   ┌────────────────┤ [!!] Download installer components ├─────────────────┐
   │                        No kernel modules found                        │
   │ No kernel modules were found. This probably is due to a mismatch      │
   │ between the kernel used by this version of the installer and the      │
   │ kernel version available in the archive.                              │
   │ You should make sure that your installation image is up-to-date, or - │
   │ if that's the case - try a different mirror, preferably               │
   │ deb.devuan.org.                                                       │
   │     <Go Back>                                          <Continue>
We have tried with the following:
virt-install \
  --virt-type kvm \
  --name=guest \
  --description=desc \
  --vcpus=2,maxvcpus=8 \
  --ram=2048 \
  --disk path=/dev/zvol/zpool1/images/guest,size=40G,format=zfs,io=threads,cache=writeback \
  --memorybacking source.type=memfd,access.mode=shared \
  --location='https://pkgmaster.devuan.org/devuan/dists/chimaera/main/installer-amd64/' \
  --initrd-inject=/zpool1/kvm/preseed/cfg_devuan_chimaera/preseed.cfg \
  --network network=$net_in,mac=$mac_in \
  --os-type=linux \
  --os-variant=debiantesting \
  --graphics=none \
  --extra-args 'console=ttyS0'
We also tried updating the osinfo database:
apt install libosinfo-bin
apt install osinfo-db-tool
wget -O "/tmp/osinfo-db.tar.xz" "https://releases.pagure.org/libosinfo/osinfo-db-20220214.tar.xz"
osinfo-db-import --local "/tmp/osinfo-db.tar.xz"
and using `--os-variant=debian11` but got the same kernel mismatch issue
Any suggestions as to how we can get a Chimaera installation automated with virt-install?
#2 2022-05-04 04:59:30
greenant
Re: Chimaera install as KVM guest with virsh-install - kernel mismatch
We have found a workaround using the netist CD image:
Download the netinst image and mount
cd /zpool1/kvm/ISO
wget -N https://mirror.leaseweb.com/devuan/devuan_chimaera/installer-iso/devuan_chimaera_4.0.0_amd64_netinstall.iso
mount -t iso9660 -o loop ./devuan_chimaera_4.0.0_amd64_netinstall.iso ./mount/
use an alternative location and specify the cdrom disk
--location='/zpool1/kvm/ISO/mount/,kernel=boot/isolinux/linux,initrd=boot/isolinux/initrd.gz' \
--disk path=/dev/loop0,device=cdrom,readonly=on
