#1 2022-05-02 10:13:14
Stian
[SOLVED] Touchpad doesn't work after waking up from suspend
Touchpad doesn't work after waking up from suspend. This seems to be a long standing kernel issue, and I don't expect it to ever be fixed. See e.g. https://bugzilla.redhat.com/show_bug.cgi?id=1485013
However, as a workaround, modprobe -r rmi_smbus;modprobe rmi_smbus works. Is there a way to have these commands run automatically after waking up?
#2 2022-05-02 13:57:04
Re: [SOLVED] Touchpad doesn't work after waking up from suspend
https://dev1galaxy.org/viewtopic.php?id=4483
Please search the boards before posting...
#3 2022-05-02 14:14:35
Stian
Thank you!
