#1 2022-04-26 08:16:26
amaro
[SOLVED] daedalus apt upgrade you have requested an impossible situation
Hello everybody!
a couple of days ago changed repos from 'chimaera' to 'daedalus'
now 'apt upgrade' gives
# apt upgrade
Calculating upgrade... Done
 libwacom9 : Depends: libwacom-common (= 2.2.0-1) but 1.8-2 is to be installed
E: Broken packages
is this ok cause 'apt-get upgrade' works without warnings or issues?
#2 2022-04-26 08:30:10
Re: [SOLVED] daedalus apt upgrade you have requested an impossible situation
Please post the output of
apt policy
grep -v '^$\|^#' /etc/apt/sources.list{,.d/*}
#3 2022-04-26 08:38:11
amaro
# apt policy
Package files:
 100 /var/lib/dpkg/status
     release a=now
 500 https://repo.skype.com/deb unstable/main amd64 Packages
     release o=. unstable,a=unstable,n=unstable,l=. unstable,c=main,b=amd64
     origin repo.skype.com
 500 http://devuan.ipacct.com/devuan/merged daedalus/contrib amd64 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=contrib,b=amd64
     origin devuan.ipacct.com
 500 http://devuan.ipacct.com/devuan/merged daedalus/main amd64 Packages
     release v=5.0,o=Devuan,a=testing,n=daedalus,l=Devuan,c=main,b=amd64
Pinned packages:
/etc/apt/sources.list:deb     http://devuan.ipacct.com/devuan/merged daedalus main contrib
/etc/apt/sources.list:deb-src http://devuan.ipacct.com/devuan/merged daedalus main contrib
/etc/apt/sources.list.d/skype-unstable.list:deb [arch=amd64] https://repo.skype.com/deb unstable main
#4 2022-04-26 08:51:02
Try
# apt update
# apt upgrade
# apt full-upgrade
EDIT: might be best to remove Skype and it's repository beforehand though. You can (try to) add them back afterwards.
#5 2022-04-27 12:00:07
amaro
@Head_on_a_Stick
'apt full-upgrade' works.
thank you!
