Hi everyone,
I would like to share files between users ( /home/tester )
I would like that only members of the group tester have access to that folder and can only delete their files
I've tried the following
su
groupadd tester
useradd -m -c "John Doe" John
passwd John
usermod -aG tester John
usermod -aG tester Marie
mkdir /home/tester
cd /home/tester
chown :tester .
chmod +t .
chmod -R g+s .
setfacl -Rm g:tester:rwx,d:g:tester;rwx .
so John and Marie have access to /home/tester they can create files, read the files of the others, but can't edit files from others.. any ideas ?
su
getfacl /home/tester/by_john.txt
# file: home/tester/by_John.txt
# owner: John
# group: tester
user::rw-
group::r-x #effective:r--
group:tester:rwx #effective:rw-
mask::rw-
other::---
Linux noob, plz be kind
To obtain a root shell use su -. Using just su will result in "command not found" messages.
Thanks HOAS, I don't understand I beleive my commands cover whats in that link..
btw Marie & John are both in the tester group
cat /etc/group | grep tester
tester:x:1001:John,marie
and the file created by John has it GID as tester
# owner: John
# group: tester
user::rw-
mask::rw-
other::---
and we can see --> group:tester:rwx
So why marie that part of tester can't delete/modify it ?
Additionnaly ls -l on the /home/tester give:
drwxrws--T+ 2 root tester 4.0K Apr 18 11:17 tester
As it should be, right ?
ooh I think I see what going on, The sticky bit prevent everyone else than the owner of the file to delete it, so therefor edit it too
Here's how the file should look:
$ getfacl /home/test/empty
getfacl: Removing leading '/' from absolute path names
# file: home/test/empty
# owner: empty
# group: test
user::rw-
group::r--
other::r--
^ That was after following the linked guide and any user in the test group can delete (but not modify) /home/test/empty. The sequence you have posted does not match the content of my provided link.
