#1 2022-04-02 04:41:43
SpongeBOB
[SOLVED] Generate a sound / beep / tts from CLI ?
Hi everyone,
I'm testing a script and a beep (or any sound would help in my debugging ) beep seem not to be installed by default.
is there any other command than can generate a sound from the CLI  ? (a beep, playing a file, speaking trough TTS..)
Thanks..
#2 2022-04-02 04:44:30
SpongeBOB
Re: [SOLVED] Generate a sound / beep / tts from CLI ?
Oh ! I found already one method !
spd-say "The text to be TTS"
smile
#3 2022-04-02 09:29:59
For a simple beep try
printf '\a'
There's also aplay(1) & speaker-test(1) from the alsa-utils package for music files and random noise, respectively.
#4 2022-04-07 08:26:11
sudo
echo -e "\a"
It's as simple as that!
