Pages: 1
Hello! This is a blank text file ".sudo_as_admin_successful" displayed on my $HOME or root very recently everytime i hit "sudo -s user apt-get".
I have never had this file on my home before, and i use sudo for many years just it appears recently of the last update from testing repo.
https://tracker.debian.org/pkg/sudo
https://pkginfo.devuan.org/cgi-bin/poli … o&x=submit
up to sudo 1.9.9-1 i remember haven't had this file on my home, something from current testing version 1.9.10-3 it made it show. If i delete it , it will recreated again once i hit successfully logging in sudo -s
I read too many googling stories about it, saw that this empyt file is present for decade. It is not a concern some people said, it is even common that it should be, but why i haven't had it before and why it appears strangely from nothing? I'm not sure it's a bug, something from the distro, or maybe it's my fault somewhere, but i can not locate it. Well, so far i have read without acting.
There was a ticket about this matter.
In fact doesn't bother me very much, just i wonder what is this? anybody from testing repo have this empty file on his home?
My single line from testing
deb http://deb.devuan.org/merged daedalus main non-free contrib
sudo version
sudo:
Installed: 1.9.10-3
Candidate: 1.9.10-3
Version table:
*** 1.9.10-3 500
500 http://deb.devuan.org/merged daedalus/main amd64 Packages
100 /var/lib/dpkg/status
Thanks for reading it.
Edit: adjusted written and links.
------------- SOLVED -------------
Edit2: Today I dealt with this matter, as early i was just reading, but not seriously.
As the user geekley posted. I disabled admin flag by creating a text file to "/etc/sudoers.d/disable_admin_file_in_home" and i put inside
# Disable ~/.sudo_as_admin_successful file
Defaults !admin_flag
Saved! and the empty file ".sudo_as_admin_successful" does not appear anymore on my home folder.
Perhaps latest sudo is compiled with admin flag active as man sudo says
admin_flag The admin_flag option specifies the path to a file
that is created the first time a user that is a
member of the sudo or admin groups runs sudo. Only
available if sudo is configured with the
--enable-admin-flag option. The default value is
~/.sudo_as_admin_successful.
The forward sudo version must have been "The default value none".
Pages: 1
