#1 2022-03-30 20:17:31
deepforest
[SOLVED] PulseAudio issues on Ceres
Devuan Ceres
After boot, AWAYS, volume is turned off and output port at audio mixer always sets "Headfones" instead of "Line out".
I need always fix that manually. How fix that?
https://ibb.co/mCHVt6P
smile
pyzNi 3.14zDa! smile
#2 2022-03-31 08:22:57
Re: [SOLVED] PulseAudio issues on Ceres
deepforest wrote:
Devuan sid
I presume you mean Devuan ceres? The Debian sid repository should not be mixed with Devuan unless you know what you're doing.
deepforest wrote:
How fix that?
Copy the init script in this post to /etc/init.d/alsa-restore then run
# update-rc.d alsa-restore defaults
#3 2022-04-01 18:40:58
deepforest
deepforest wrote:
Devuan sid
deepforest wrote:
How fix that?
I did according your instructions. But its same.
root@devuan:/etc/init.d# ls -l /etc/init.d/alsa-restore
-rwxrwxrwx 1 root root 700 Apr  1 21:23 /etc/init.d/alsa-restore
/etc/init.d/alsa-restore        700/700               100%
# Generated by sysd2v v0.3  --  http://www.trek.eu.org/devel/sysd2v
# kFreeBSD do not accept scripts as interpreters, using #!/bin/sh and sourcing.
if [ true != "$INIT_D_SCRIPT_SOURCED" ] ; then
    set "$0" "$@"; INIT_D_SCRIPT_SOURCED=true . /lib/init/init-d-script
fi
### BEGIN INIT INFO
# Provides:       alsa-restore
# Required-Start: $remote_fs
# Required-Stop:  $remote_fs
# Default-Start:  2 3 4 5
# Default-Stop:   0 1 6
# Description:    Save/Restore Sound Card State
### END INIT INFO
DESC="alsa-restore"
DAEMON=none
PIDFILE=none
do_start_cmd_override ()
  /usr/bin/alsactl restore
  true
do_stop_cmd_override ()
  /usr/bin/alsactl store
  true
do_status_override () :
in boot log i see this
INIT: Entering runlevel: 2
Fri Apr  1 21:26:02 2022: Using makefile-style concurrent boot in runlevel 2.
Fri Apr  1 21:26:03 2022: Starting alsa-restore: none/etc/init.d/alsa-restore: 21: /lib/init/init-d-script: /usr/bin/alsactl: not found
Fri Apr  1 21:26:03 2022: .
UPD
I search alsactl and found it only here at sbin but not bin
root@devuan:/usr/sbin# /usr/sbin/alsactl
I am replace at script "bin" to "sbin" and again apply command
But still same, at booting no errors but after booting volume is disabled
UPD2
now at boot log
Fri Apr  1 23:13:08 2022: Starting alsa-restore: none.
smile
#4 2022-04-01 19:25:13
deepforest
also i have that output
freeartist@devuan:~$ sudo pacmd list-card
[sudo] password for freeartist:
No PulseAudio daemon running, or not running as session daemon.
smile
#5 2022-04-01 19:26:55
deepforest
Its happened when i upgrade Chimaera to Ceres
smile
#6 2022-04-02 09:31:57
So was sound working under chimaera? Were your settings saved there?
#7 2022-04-02 12:40:10
deepforest
Its was working. I am upgrade chimaera to ceres and now after upgrade sound is disabled. Manually i can enable it, but i want that its auto work. How i can find settings? Sorry.
smile
#8 2022-04-03 19:30:34
deepforest
pacmd list-sinks | less
https://pastebin.com/raw/5ffkYe6m
pacmd list-sources | less
https://pastebin.com/raw/aZmVFeEg
pacmd list-cards
https://pastebin.com/raw/QR6UQrXg
smile
#9 2022-04-04 11:02:38
#10 2022-04-04 14:05:32
deepforest
Thanks.
this 2 command make audio works again. But how i can make it work automatically? Not manually enter every time after booting?
freeartist@devuan:~$ pacmd set-sink-port alsa_output.pci-0000_00_1b.0.analog-stereo analog-output-lineout
freeartist@devuan:~$ amixer -D pulse sset Master toggle
smile
#11 2022-04-04 16:41:44
Create a file at ~/.config/pulse/default.pa with these lines:
.include /etc/pulse/default.pa
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo 0
Reference: https://wiki.archlinux.org/title/PulseA … utput_sink
#12 2022-04-05 15:46:06
deepforest
Thank you very much! Now sound working good!)
smile
