Pages: 1
Hi everyone,
I see that by default the file /etc/passwd is 644
Is it not insecure that Others have read permissions ? I'm not feeling comfortable with that...
I change it to 640 but of course when I log-in with a user that start startxfce4 it's won't launch the GUI and stay in CLI...
I would like to give the correct ACL permissions to make xcfe start, but I don't even know witch account should have read acces ??
Thanks
Linux noob, plz be kind
No. The actual passwords are encrypted and stored under /etc/shadow as per passwd(5).
I change it to 640
Change it back. Many utilities use that file to map user IDs to user names. It should be world-readable.
EDIT: use pwck(8) & grpck(8) to verify the integrity and validity of /etc/passwd,/etc/shadow & /etc/group.
To obtain a root shell use su -. Using just su will result in "command not found" messages.
Thank you HOAS,
I knew that the actual password are stored in /etc/shadow.
But I found curious that any user account can list the full list of user registered on the machine..
I think alpinelinux has a way of hiding users in /etc/passwd. Im not on alpine at the moment but from memory last time i looked my user was called "linux user" in /etc/passwd but user name aka /home/username was hevidevi. Ill have to revisit alpine again to understand more.
Edit to add. Alpine linux was absent the shadow file/package from base install afaik.
Pages: 1
